Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > ESS or COBB for a 335IS?
      02-28-2013, 10:15 AM   #23
BQTuning
Drives: 2012 Z4 sDrive35i M Sport 6MT
Originally Posted by stupordave View Post
First drive on the COBB tune is complete. All I can say is WOW. Easy install, no error codes, and a noticeable improvement in power. Kicking myself for waiting a year to install a tune. One the linear throttle setting, the car drives smoother for around town and has more power than the tires can handle when you get on it. Money well spent.
Upgrade your intercooler if you own the car. If its a lease then Oh Well
      02-28-2013, 10:26 AM   #24
stupordave
15
Drives: 2011 335is
It's mine. I had better start looking at options. Recommendations that require the least amount of modification?
      02-28-2013, 10:28 AM   #25
Crewchief05
SBD
Crewchief05's Avatar
Drives: 335i e90
08 335i  [0.00]
+1 cobb
      02-28-2013, 01:31 PM   #26
G8r3Series
G8r3Series's Avatar
16
Drives: ///M3
Stupordave,
Any idea what kind of numbers the 335is is putting down with stage1 cobb?
      02-28-2013, 01:50 PM   #27
2nice89
Drives: 2007 e92 335i
2007 335i  [1.00]
Originally Posted by Mike@N54Tuning.com
COBB or JB4 G5 ISO
Mike
Or both lol
      02-28-2013, 02:44 PM   #28
BQTuning
Whoever is going to install it will more than likely need some mild cutting.
Here is a photo slide of the cutting that need to be done
its best to provide the "PRO" installer this slide so they have an idea if they never worked specifically on an IS
Try to get an IC that has no more than a 0.6 PSI reduction
Also it would help, for adding more boost later with the Cobb AP, to get an IC that is close to 90%+ volume increase over the stock. This will be alomost two times the size of the stock. Most sellers do not mention this so its best to shoot them an email if you dont see it in their online specs.
Qualify the intercooler with the above first then we can move on to the final qualification
Intercooler core quality and design is also important. Usually, vendors buy the cores from a core manfacturer and just cloth them with a housing and side tanks etc for the specific car they will go on. If it gets too technical just make a new thread of the options you find so other may chime in. it may turn out to be a grudge match but you will learn from it
Keep in mind prepare to hear "cheaper" but have no idea about PSI reduction, volume sze, or core design and quality.
All intercooler are not the same. People who believe that just run after the cheapest thing they find inorder to up boost. You have a 60k car, dont treat it like a rice burner. Do it right.
      02-28-2013, 02:53 PM   #29
Black Gold
Drives: M3
Interesting post, but why do you recommend a 90% increase in volume over stock? Why not 80 or 100?
      02-28-2013, 02:58 PM   #30
BEAR-AvHistory
2020 Z4 M40i - 2022 M4C Convt
BEAR-AvHistory's Avatar
Drives: 2020 Z4 M40i - 2022 M4C Convrt
You really need to be honest with yourself as to what your goals are when choosing an FMIC. If you are not going far into modifications there are quality 5” units that will bolt in as direct replacements for the factory unit with excellent IAT control. If you are thinking about more serious mods then a tune you will need to think of cutting the plastic to fit in a bigger unit.
I would agree that the cheapest is not necessarily the best choice but neither is the most expensive. Try to see what the core design cutaway relating to heat transfer looks like in any cooler you are looking at also the quality of welds, the shape of the end tanks & included plumbing.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers
2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT
      02-28-2013, 03:59 PM   #31
BQTuning
There is no 100+ % that is a "direct replacement" for the stock. Only 84% - 93% so if he wishes to get ProTune with Cobb later perhap, even turbo upgrades, his IC will easily accomidate the new power and still run efficient thus he doesnt have to buy another IC in the furture
      02-28-2013, 04:07 PM   #32
Black Gold
Drives: M3
I guess my point was what data or theory was used to come up with 90%? What happens at 90% that doesn't happen at 80%?
And what fmic meet this threshold?
      02-28-2013, 06:33 PM   #33
mithiral67
That guy
mithiral67's Avatar
117
Drives: 2015 Cayman GTS
I have a 2011 IS and went stage 2 pretty quick, but did get a stage 1 run in for comparison. Shoot me a PM if you want more info.
FMIC had a huge impact, stock the intake temps jumped over 160 degrees, but with a helix, the temps never went abovo 100
1 is stage stage 1 and 3 is stock. 100% stock car.
Cheers,
James
2015 - Cayman GTS - Stock
2011 - 335is e92 - Cobb PTF E40/Rob - Beck/AR/Helix (458 rwtq and 479 rwhp) - Retired
2007 - 911 Turbo - EP1/AMS (617 awtq and 500 awhp) - Retired
2008 - 335i e92 - Cobb/AR/Helix/OSS (384 rwtq and 356 rwhp) - Retired
      02-28-2013, 07:04 PM   #34
BQTuning
I used 90% as a standard guide being that the majority of the maintream N54 intercoolers are either just below or just above 90% percentage of volume increase over stock that will fit
More air volume + greater PSI reduction = better heat exhange coefficient / lower IATs = better timings
less air volume + less PSI reduction = not enough heat exhange per the increase of power / higher IATs = more timing pulls
So in other words we dont want to go too large nor too small with our tiny stock turbos.
Helix seems to be a good 1st candidate, or the HPF Intercooler
      02-28-2013, 07:40 PM   #35
type rrr
type rrr's Avatar
Drives: 335i coupe
Cobb
Cobb
Cobb
Cobb
Cobb
Cobb
Cobb...
2007 335i coupe AT-- I80AS--FBO -stock turbos--COBB v402 beta stage 2 + ATR-- NITTO'S 275-40-17 NT05R --- 12.025 @ 120 mph -- full weight
      02-28-2013, 07:59 PM   #36
Black Gold
Drives: M3
Thanks for clarifying.
I understand why fmic are good for the car, I was simply wondering where you came up with 90% more volume.
My understanding would be that fmic don't force more volume of air into the car, but more oxygen dense air by lowering iat.
A larger core would simply be more resistant to heat soak and be able to cool more air. Negatives would be pressure drop bc the volume is large and slows down the air velocity going from the turbos into the intake manifold.
Please correct me if I am wrong.
      02-28-2013, 08:19 PM   #37
stupordave
15
Drives: 2011 335is
Originally Posted by G8r3Series View Post
Stupordave,
No idea but it will get squirrely on a flat road with the traction control off. You can feel it pull much harder as it gets into the RPMs. Like BurQ said, I spent some money on the car and not interested in ragging it out at this point so I'm still a bit hesitant to drive it too hard. Almost tempted to drop back to the Sport map for longevity since I don't have an upgraded IC.
      02-28-2013, 08:41 PM   #38
TTurbo335
TTurbo335's Avatar
Drives: BMW 335i
I use the Procede Rev3- the power is unreal. I also use meth for bonus fun. I'm not a mechanic and the install was a breeze.
      02-28-2013, 11:10 PM   #39
BQTuning
Pretty much we are on the same page just explained differently
      03-01-2013, 03:29 AM   #40
tinnsoldaten
tinnsoldaten's Avatar
Norway
34
Drives: e92 335i coupe
I have ESS on my FBO 335i and I am happy with it. No issues ever!
Unloading and loading of maps is 15 minutes with the flash reader/writer tool.
If I was to choose , I would simply go with the one that is closest to you.
There is no COBB where I live so the ESS is my only option.
ESS is one of those who have been in the 335i N54 world the longest if I am not mistaken. They used to deliver very agressive tunes in the early days , but now they marked only more mild tunes on their standard package online. That is maybe why people choose other tunes over them. Custom tunes is of course available there too. Im going there for a custom tune when I get new turbos and cylinder head. + meth
Vargas S2 turbos|VAC S3 Cylinder head|RR DPs|RR MPs|Supersprint X pipe|Remus Quad Sport mufflers|aFe Stage 2 Si with scoops|Forge DVs|ER CP|BMS meth elbow|Aquamist HFS-4|Walbro 450 E85 LPFP|AA FMIC|BMS OCC|MHD|P3 Boost Gauge|Ohlins Road & Track + camberplates|M3 sways F/R+ Ground control endlinks|Vorsteiner v303 19"|Michelin PS2 sport|Quaife LSD|Vorsteiner V35 CF hood|CF CLS trunk|Duke Dynamics quad diffusor
      03-01-2013, 10:16 AM   #41
BEAR-AvHistory
Do you have the Vargas installed or on order?
Kevin
      03-01-2013, 10:59 AM   #42
tinnsoldaten
Norway
34
its on order , dont think any of us who have on order have got it yet. we are all waiting...
And my stage 3 head from VAC is also on order. My guess is that I will start the install this spring then drive to ESS in early summer and get the tune sorted.
      03-01-2013, 11:32 AM   #43
boostaholic786
boostaholic786's Avatar
40
Drives: E92 N54 with MHD Custom flash
COBB!!
[SIZE="2"]Crimson Red E92 335i M-sport 6-speed with MHD custom stage 2+ flash only , 40% E85/93 mix,+ HRE P40S wheels, KW Clubsport, M3 sways,+BMW performance CF Mirrors, BMW Performance CF deck lid spoiler,+ CF interior trim, p3 vent boost gauge,+ LUX angel eyes (11.73@124mph on street tires)
      03-01-2013, 12:46 PM   #44
BEAR-AvHistory
Sounds good, best of luck with the system.
Kevin
cobb, ess, tune
