06-17-2010, 08:04 AM | #1 |
Rep 1,230
Z4 (non-M) Definitive Wheel Spec Thread
I noticed the Z4M thread and thought I'd start one for the other Z4's. I've searched high and low and am having a tough time finding much information on wheel offset options, hopefully you all can help me fill in the blanks! Please specify which model it is (if it matters). I apologize if there's already one of these, but I didn't find one.
-Stock Z4 SI 18" Wheel Offsets -Front = 8" et = ? -Rear = 8.5" et = ? -Front Weight = ? -Rear Weight = ? -How aggressive have you got with offsets and tire sizes? Last edited by JD3; 06-17-2010 at 08:47 AM.. |
06-17-2010, 08:36 AM | #2 |
Rep 1,224
Factory 203 wheels
18x8 et 47 wgt 26.3 lbs 18x8.5 et 50 wgt 26.5 lbs D-Force Empower wheels 18x8.5 et 40 wgt 19.2 lbs 18x9.5 et 43 wgt 20.9 lbs Sport suspension OE tires sizes: F-225/40 R-255/35 No rub, good clearance Weights determined on a postal scale. And because it is regularly asked: Wheel Bolt Torque = 120 nm +/- 10 (81.1 - 95.9 ft lbs) (120nm = 88.5 ft lbs)
If you can't take the time to teach a kid something good, someone will take the time to teach them something bad.
westunion200718.00 |
06-18-2010, 12:11 AM | #3 |
Rep 1,349
For Non-M on stock suspension, 19x8.5 ET30 and 19x9.5 ET40 should give you pretty flush stance.
If the car is lowered then it all depends on your supsension setup. But 19x8.5 ET35 and 19x9.5 ET43 should work really well if your suspension is not extreme. |
06-18-2010, 12:11 PM | #5 |
23
Rep 374
im running VMR CSL reps
19x8.5 with 40mm offset up front and 19x9.5 with 45mm offset in the rear. fronts have 235/35 and rears have 265/30 im lowered on eibach springs and koni shocks and i have absolutely no rubbing whatsoever even with a second passenger |
06-23-2010, 02:36 PM | #6 | |
Rep 1,230
What's the most offset one can run with a 9.5" wheel? Some of the e90 guys run 9.5" with 25 offset. Would that basically push the wheels out about another inch and a half over stock? Is that offset acceptable on the Z4, or is it too aggressive? |
06-23-2010, 03:43 PM | #7 | |
John 14:6
59
Rep 588
You can run with a 19X9.5" rear wheel with a 35 offset. On my last set of wheels (Miro Type 366s) i ran a 19X8.5" front and 19X10" rear with a 35 offset all around. I recall someone running a 32 offset in the rear. Keep in mind that these measurements are with 265/30/19 rear tires.
Mods: Eibachs/Konis, Eibach camber kit, JTD RSMs, 19" WedsSport SA67, Hamann headlight trim, Aero front bumper, Aero sides, AC Schnitzer side deflectors, Hella euro taillights, Hardtop, Dinan strut & supplemental bars, RD Sport intake, Dinan Stage 2 Software, RPI scoop, Bastuck catback exhaust, Radenergie CF engine cover... |
06-23-2010, 04:35 PM | #8 | |
Rep 1,230
Thanks, that helps a lot. So if you're running a 35 offset on a 10" then you should be safe with as low as 29 I'd say on a 9.5". At least that's what my math would say. 25 is probably still too aggressive, even with 265/30's. |
06-25-2010, 10:41 AM | #9 |
John 14:6
59
Rep 588
A 29 offset may be pushing it . IMO, I would go no lower than a 32 offset.
02-28-2011, 07:06 PM | #13 |
Rep 409
bump for a great thread!
i've noticed a lot more questions and posts coming in for non-///m wheel and tire fitment, so i'm hoping to get this thread to "sticky" levels soon. these specs are for getting the wheel out flush (not past) the fender line on stock suspension and little need to add negative camber front or rear. for the front... 8.5" width = et35 8.0" width = et29 for the rear... 9.5" width = et42 9.0" width = et35 8.5" width = et29 i'm personally running... style = oem style 313 (stock, off an E92 335is) please excuse the crappy camera phone pics... specs = front = 18" x 8.0" et34 with 225/40r18 rear = 18" x 8.5" et37 with 255/35r18 weights = front = 22.1 lbs ( +- 0.3 lbs, according to the scale mnfr ) rear = 23.4 lbs ( +- 0.3 lbs, according to the scale mnfr ) suspension = ZSP stock (for now) 04.09.2011 - !!!UPDATED PICS!!! now, i know a bunch of you... dubbedown, ljs, stigj, misterawa, oh fo sho, mister roger, dadoke... all have aftermarket wheel setups. get your specs in here and we'll give the mod's a reason to keep this thread on the first page! and don't forget to post pics!!!
| v3.0si | | '08 Z4Coupe 3.0si | BMW Aero | BMW Performance |
03-01-2011, 12:48 AM | #15 |
Rep 509
Current setup:
Front: 9x19" ET44 with 235/35-19 (Yokohama Advan Sport) Rear: 9x19" ET44 with 255/30-19 (Yokohama Advan Sport) Lowered 35mm with H&R springs. No alignment done yet... A little rub in the front just behind the side reflectors in the inner wheelwell. New wheels are purchased but not on the car yet. Will post the specs when it on the car.
My Hellrot '06 BMW Z4 3.0si Coupe and My Mineral Grey '14 F30 (sold) New daily: Sunset Orange 330E G20 Instagram: @StigJ77 & @bmwe86driver |
03-07-2011, 01:08 PM | #17 |
Rep 409
check out my updated pics in my first post...
please excuse the truely crappy cell phone pics!
03-07-2011, 01:53 PM | #19 |
Rep 12,567
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
Just to add, I'm currently running:
Volk RE-30 in 18x8.5 et42 on all 4 corners No rub whatsoever, and that's with a 12mm spacer on the rear, effectively giving me a 30mm offset 225/40-18 tires but will be upgrading to 255/35 shortly |
03-07-2011, 03:46 PM | #20 |
Rep 409
i don't have anything on mine yet... it snowed here this morning, and we're to get more wednesday. oh well.
in the mean time, "rlc" has the same offsets. use your imagination to lower the car down to ZSP height... http://www.zpost.com/forums/bpgarage...o=view&id=2207 and here is a chop with 313's on it... (best viewed from about 6+ feet away from your monitor, don't ask me why... it just works)
04-05-2011, 10:16 AM | #21 |
60
Rep 72
Drives: i3
I'm still curious as to what the difference between the rear of an M vs non-M really is? as far as I can gather the sheet-metal is the same for the two vehicles and the front offsets are essentially identical. Does the M have a different offset because the axles/hubs/brakes? or something that is drastically different?
04-05-2011, 10:26 AM | #22 | |
Rep 12,567
