TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X6 Forums > X6 Photo/Video/Audio Gallery
      09-18-2015, 08:25 PM   #89
igorbmwx6
igorbmwx6's Avatar
Drives: 2016 BMW 328i F30
Originally Posted by m3 guy View Post
That's some good info right there. Thanks for posting the coding stuff, I'm sure it will help many of us out!
Btw do you do remote coding by chance if we provided the obd cable?
Normally I do not. For me, it is just a hobby, not a business. I don't mind sharing the info with anyone, but don't want to turn it into a business of coding BMW's remotely, etc ...
      09-21-2015, 08:32 AM   #90
fasternu
fasternu's Avatar
Drives: AW E92 M3
I just bought my 2013 X6 50i. I want to change to the led headlights. Do I need the retrofit wiring harness for my model year? Would it be an easy plugin, recode, and play?
      09-29-2015, 07:38 PM   #91
Gatoferoz25
BeastM3r
Gatoferoz25's Avatar
Drives: M3 COMP
Originally Posted by igorbmwx6
Originally Posted by theonesupreme View Post
You did everything yourself?
Yea...it looks so sick
Yes, I did it all myself Coded all myself as well I can answer any question related to this retrofit, since I did it all myself. At first I was a little skeptical about it and asked my local BMW stealership for a price quote to install it. They refused to do it. It is not available in USA only in Europe. I am actually glad that they refused, saved me at least $1500 in installation fees
Hey brother sorry to bother u but I recall u said something about helping ppl out with questions about led retrofit.
So now it's the time I have everything wired as the last retrofit instructing with SA524.
Now I have some issues and errors on my screen saying that left and right turn signals aren't working properly plus adaptive headlights errors
So this is what OkEE codemycar told me
RSMC
LSMC
Adaptive headlight modules that are showing no communication.
Can u give me some advice about his issue since u already did it and everything is working just fine. Any help is welcome thanks very much
MORR WHEELS - VORSTEINER HOOD - FRONT LIP-CF REAR DIFFUSER - LED HEADLIGHTS - BREMBO BRAKES - Kw SUSPENSION - EISENMMAN - JB4 - SPORT STEERING WHEEL..!
      09-30-2015, 02:21 AM   #92
xpl0sive
28
Drives: bmw
RSMC
LSMC
Did you code the FRM module with the new FA codes?
      09-30-2015, 02:23 AM   #93
xpl0sive
28
Drives: bmw
Originally Posted by igorbmwx6 View Post
Below are the coding instructions. Nothing too complicated:
LED Lights: I just modified my VO String in NCS Expert to add option $552 and delete $522, $524 to my CAS and FRM module
Change production date to #0412
Remove $522 and $524 (AHL if you have) and add $552 to CAS & FRM and code car.
If you are not comfortable coding the whole car then just code CAS, KOMBI and FRM with expert profile.
REMOVE:
$522 - FRM//Xenon light
$524 - FRM//Adaptive Headlights
ADD:
$552 – FRM//Adaptive LED headlights with Anti-Glare High-Beam Assist, incl. variable light distribution and cornering lights
Installing new FRM module:
coding FRM module step by step:
A:
1.open NCS expert
2.File-Load profile
3.select EXPERMODE
4.press F1
5.press F3
6.select E70<for E71>
7.press BACK
8.press F3<CHOOSE ECU>
9.select NFRM
10.select FA_WRITE from CHANGE JOB
11.press F3<EXECUTE JOB>
B:
1.open NCS expert
2.File-Load profile
3.select EXPERMODE
4.press F1
5.press F3
7.press BACK
9.select NFRM
10.select SG_CODIEREN from CHANGE JOB
Here are the coding instructions he posted before
      09-30-2015, 10:29 AM   #94
igorbmwx6
igorbmwx6's Avatar
RSMC
LSMC
It all depends if you previously had adaptive option or not. LED retrofit allows you to add adaptive if you did not have adoptive before. It is in the instructions manual. Make sure that you FRM3 module is the latest or one before the latest part# (look in realoem)
      09-30-2015, 10:31 AM   #95
igorbmwx6
igorbmwx6's Avatar
Yes
      10-15-2015, 01:24 PM   #96
xpl0sive
28
Drives: bmw
When you order the complete headlight assembly, does it come with the bulb/fan, etc...? I know it doesn't come with the modules
do i need to order parts #3,4,5,6?
      10-15-2015, 01:58 PM   #97
m5 guy
m5 guy's Avatar
Drives: 2020 M5 Comp
It comes with 5 and 6. It does not come with 2, 3, 4, 7, 8, or 9. You also need 9 as one of the modules does not come with mounting hardware.
What I did for the corner light is ordered the cover, 4, but used bimmian's new led corner bulb. Bulb is awesome. No yolk look, bright amber when on, and no error codes. The last thing I was going to do was put an oem halogen bulb in my brand new $$$ led setup lol...
Link to bulb:
https://bimmian.com/WTS/70
2020 F90 M5 Comp Oxford Green Metallic II-Aragon JOURNAL
2016 F10 M5 Space Gray-Black SOLD
2012 E70 X5M Monte Carlo Blue-Silverstone SOLD
2001 E46 M3 Oxford Green Metallic II-Cinnamon SOLD
      10-15-2015, 02:04 PM   #98
Gatoferoz25
BeastM3r
Drives: M3 COMP
Link to bulb:
Word bro
Did the same With my turn signals
      10-15-2015, 11:11 PM   #99
xpl0sive
28
Drives: bmw
Word bro
did you get your lights working?
      10-20-2015, 07:56 PM   #100
Gatoferoz25
BeastM3r
Drives: M3 COMP
Word bro
Not yet bro I'm pissed off I can't get them to work properly
      10-27-2015, 05:50 PM   #101
xpl0sive
28
Drives: bmw
As per my PM, i think the issue most likely is that these headlights were never an option on a non-M X5. You may need to change your coding to make your car think it's an X6... maybe then the issues will go away
      10-27-2015, 06:03 PM   #102
Gatoferoz25
BeastM3r
Drives: M3 COMP
Idk what to tell u brother I have try both ways of wiring I changed the FRM3 twice I change the adaptive SMC modules I don't know anymore Codding showing no communication on SMC both sides.
But there is x5 M-Sport here that did this no issues at all he's is diesel tho I don't know is that has something to do with wiring or different FRM :
      10-28-2015, 09:29 AM   #103
gixxerboy63
Tanzanite Blue II X5M Pilot
gixxerboy63's Avatar
1050
Drives: M3, M4, X3 M40i, X5M
2017 m4  [0.00]
2010 BMW X5M  [10.00]
Ooooh! I didn't think of that.
That could be your issue since it appears that every other option has been exhausted.
2020 X5M - Tanzanite II
2012 M3 - Alpine White
      10-28-2015, 12:15 PM   #104
Gatoferoz25
BeastM3r
Drives: M3 COMP
The guy that does the Codding "OKEE" have done many of this LED retrofit CODDING the problem it's not there but I juts swap the SMC modules again from my old headlights to c what happen later after Codding but I'm 100% sure this is gonna work please keep ur fingers cross
      10-29-2015, 11:09 AM   #105
Gatoferoz25
BeastM3r
Drives: M3 COMP
Thanks God And OKEE everything is working 100% on my LED headlights
OMG what a PITA
      10-29-2015, 12:52 PM   #106
m5 guy
m5 guy's Avatar
Congrats!!!!!!!!!!!!!!!!!!!
What was the solution?
      10-29-2015, 06:09 PM   #107
Gatoferoz25
BeastM3r
Drives: M3 COMP
Freakin SMC modules I ended up taking them off to swap with my old ones from original XENON headlights and one was Unpluged after I put everything back together they worked just fine Thanks for the help Brother u always there for me appreciate that
      01-07-2016, 08:16 AM   #108
Martin12345
Drives: F10 520
2012 BMW X6  [0.00]
Hello, I`m new to this forum and i have some question for you. Does the headlights and the tail lights would fit the e71, i mean i have x6 2012, and i want to make your upgrade but i have question would i have to change the whole bumpers etc, or will they just fit at the same place. I would not ask for coding now.. Thank you very much.
      01-26-2016, 06:56 AM   #109
igorbmwx6
igorbmwx6's Avatar
You will not have to replace the bumper. Both led headlights and tail lights will fit into place without any adjustments to the bumper.
      02-15-2016, 08:05 PM   #110
frankenm
frankenm's Avatar
96
Drives: 12' X5M, 99 M3
Only $3k you say???
headlights, led, tail lights, x6m
xbimmers
