10-05-2016, 11:38 PM | #1 |
21
Rep 164
PFC Z rated or Ferodo DS2500
Looking for a very good street pad and it sounds like I'm torn between these two. I do maybe 1-2 track days a year with the car. It's a weekend car for me so I don't want to spend the money on track pads, I can deal with a little fade on track since it's rare I make it to an event. My main track car is a spec miata. Curious as to which one to go with now? I thinking I'm leaning more towards the Ferodos unless I'm proven wrong. Thanks.
10-06-2016, 06:33 PM | #3 |
21
Rep 164
10-06-2016, 07:05 PM | #4 |
Stop the hate, get a V8
3853
Rep 8,625
DS2500 is fine for the street. It'll handle some light track usage, too.
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP |
10-14-2016, 10:37 PM | #5 |
Supreme Allied Commander
3885
Rep 54,481
Drives: F80 M3
Z rated is more or a street leaning pad and DS2500 is more of a track leaning pad. Z rated is perfect for street use whereas the DS2500 may produce slightly more dust and some noise(not always though).
10-17-2016, 10:17 AM | #6 |
Rep 518
I've had the Ferodo DS2500 on previous daily drivers that I also tracked and they seemed to fair okay on the track. What pad is the next level up pad in terms of trackability but still similar in street performance? A little more dust is fine but squealing isn't.
2003 M3 | SMG | KW V1 | Apex ARC-8s | 3.85 LSD | Cobra Nogaro | S2R Tuning Sunroof Delete | Billy Boat Section 3
10-17-2016, 10:39 AM | #7 | |
3853
Rep 8,625
The DS2500 is pretty much the best you'll find when it comes to a hybrid. They'll work fine for a street car that gets onto the track once in a while. Some here do speak highly of the Endless or Project Mu pads but those are expensive and hard to source for what might be a very negligible change. My only complaint about the DS2500 is that they do get a little noisy in the colder months, but it's far better than running a track pad on the street (ridiculously loud, chews rotors up, and pads don't last long). I have run the DS2500 on my old B6 Audi S4 and now on my M3 (StopTech BBK). I've been very happy with it on both cars.
stefan_e36316.00 DrFerry6730.00 |
10-17-2016, 10:43 AM | #8 | |
3885
Rep 54,481
Drives: F80 M3
10-17-2016, 12:17 PM | #9 | |
Thread killer
646
Rep 1,896
11-02-2016, 12:54 AM | #10 |
21
Rep 164
So tried them out this passed Sunday and FADE! I kind of figured that would happen though. They were much better then the oem pads though. These cars are just too fast and heavy for the crap oem brake setup. Car needs a bbk. Eh luckily I barely track this car.
11-02-2016, 03:31 AM | #11 | |
Rep 12,733
2500's did fine with the bbk, just didn't last long.
Instagram; @roastbeefmike
11-02-2016, 07:53 AM | #12 |
///M Powered for Life
11500
Rep 10,333
If you want more track-oriented pads, the PFC12 I've run this last season is a full endurance track pad which is incredible quiet on the street.
If I did a couple days a season I would just swap. The car works fine without a BBK, but you need proper pads |
DrFerry6730.00 |
11-02-2016, 09:31 AM | #13 |
3853
Rep 8,625
If you wait for a sale/promo, you can get the basic StopTech ST40 kit for under $2500. That's what I did.
11-02-2016, 06:25 PM | #14 |
Rep 513
DS2500 don't really handle track duty well. They're a good street pad though, in my opinion.
I'm about to try the new Hawk HPS 5.0. I used to run HPSs before, and I thought they were great on the street. the 5.0s seem to be an even bigger improvement. I think if you're going to track though, you have to go for a DTC-70 equivalent or more IMO. |
11-03-2016, 07:24 AM | #15 | |
Rep 1,179
I recently performed a number of consecutive, emergency brake tests (activating the ABS each time) at high speed 70mph to zero and there was no fade. (At a track - not the road) Given their temperature range is far higher than the stock pads, using them primarily for fast road use and a few track days is a good fit. As with most non-race pads, any fool can abuse them at a track day! I find with a little thought and care, it is easy to keep a pad within its operating window by simply incorporating 'cooling' laps with the fast laps. |
11-03-2016, 12:07 PM | #16 | |
3853
Rep 8,625
My DS2500s do just fine on the track (StopTech ST40 kit up front).
11-03-2016, 07:29 PM | #17 | |
Rep 513
I've used DS2500s on a track before, and I don't think they held up too well, just my own personal experience! Went to Hawk DTCs, can't remember which number, and I thought those were much better. However, DTCs are awful daily pads, they squeel, they dust, and the initial bite isn't great. |
11-06-2016, 09:36 AM | #18 | |
3853
Rep 8,625
I ran them on Autobahn CC's full/combined track.
11-19-2016, 11:38 AM | #19 |
17
Rep 81
I run the PFC Z pads all around with SS lines, and for a street pad, they are still my absolute favorite... dust is reduced by at least 1/2 and the temp range for fast street driving is much better than stock. I've put them on every BMW i've owned, except my E39 M5 because unfortunately they only make the pad shape for the rear. That being said, I think the Ferodo is more track oriented. I've used the PFC on a very short track with decent success, but if I was on a more traditional track that was fast like COTA or Watkins Glen, they would definitely not make it.
I recommend PFC Z for daily and swapping out the fronts for one of their track pads before heading to the track. If the Ferodo was as low dust as the PFC, I'd probably do what you're thinking and run them as a good compromise option with Cryo'd rotors and brake cooling kit. just my opinion of course, many swear by hawk and carbotech etc, but none of them come close to the PFC Z for a street pad. |
07-24-2018, 10:32 PM | #20 |
Rep 744
bumping this old thread, but did you guys experience any soft pedal swapping from OEM to the ferodos? My calipers are flexing more with my Ferodos than my worn OEM pads, less stiffness in the brake pedal itself. I've swapped back and forth and back again, isolated to something with the pads
07-25-2018, 12:26 PM | #21 |
3552
Rep 2,824
^ Proper bleeding? That is not something I've heard before. I've had DS2500s on a Brembo GT BBK (E46M) and loved the pads, particularly the feel/modulation/consistency.
07-25-2018, 12:38 PM | #22 | |
Rep 744
I also noticed the DS2500s have nubs on the back, the oem pads don't. i'm going to look closely to see if the nubs are making contact with anything - doubt it, it looks like there's space but i'm reaching for answers here |
