Can't quit that long roof... New E91!
12-14-2023, 12:08 PM | #45 | |
Rep 814
Someone who's more conversant in coding and the various modules than I am can probably explain and offer more insight. I was able to ultimately reset the module and take care of this myself through software. |
E93Seattle (Racerbruce)799.50 StradaRedlands4949.00 |
12-14-2023, 06:57 PM | #46 | |
Rep 3,011
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.21]
2009 BMW 328i Touri ... [7.90] 2013 BMW X5 35i [7.63] 2011 BMW 528i [8.75] 2006 Mazda3 [5.50] |
E93Seattle (Racerbruce)799.50 |
12-15-2023, 12:42 AM | #47 |
Rep 3,011
It's official, I have some work ahead of me! VCG, OFHG, and radiator/hoses/stat/pump.
But I think that'll be it for the most part. Ha, that's funny... Side of the valve cover: The supposedly in good condition, but obviously not in good condition OFHG: And the failing radiator that I honestly wasn't expecting: Last edited by StradaRedlands; 12-15-2023 at 01:18 AM.. |
Cal122181.00 E93Seattle (Racerbruce)799.50 |
12-15-2023, 01:21 AM | #48 |
Rep 553
I had no idea these fail. I guess time will tell
StradaRedlands - congrats (on "new" project) If time comes for you to get 4th E91 and it will be from SF-area - let me know, I can go check it out for you in person (anywhere in SF-Sacramento-Tahoe) corridor. Should you need tail lights - consider euro version. There are couple UK BMW dealers that have new, factory set on ebay. It is cheaper than new or used US version, and IMO looks better. I actually made a small net profit after selling my US 10y+ factory ones Not a basic build - CA, NAV, PDC, ski bag, etc - very nice! 2009 E91 is the only LCI that had a net behind front seat. I actually swapped one into my 2011 E90
12-15-2023, 01:35 AM | #49 | ||
Rep 3,011
And yeah, those flappers were always broken on my other E91s. I replaced one, and just ignored the other! Quote:
Gotta' get the trans and brake fluid changed on the X5, then I can move it out of the way on starting focuing on the blue bomber! |
12-15-2023, 01:39 AM | #50 |
Rep 553
Mine GM is at 111,111 - shifts super smooth when "cold" (In SF "cold" is +3C)
StradaRedlands4949.00 E93Seattle (Racerbruce)799.50 |
12-15-2023, 02:09 AM | #51 | |
Rep 553
E91 https://www.ebay.com/itm/182690216025 I got mine E91 & E90 from Lloyd BMW MINI Colne It comes as a "kit" in a BMW box.
12-15-2023, 02:23 AM | #52 |
Rep 553
Based on the picture belt is sliding off of the tensioner pulley - replace tensioner with belt while you there with OFHG.
And mickey mouse flange of course
12-15-2023, 02:37 AM | #53 |
Rep 553
Take the CIC HDD out and make a backup (just dd entire drive block device to a file)
The drive will fail one day. Last partition has certificates registered to your CIC unit that you do not want to loose. I failed to backup my E70 CIC HDD - the recovery was very painful and time consuming A CF adapter with decent CF card will make a solid upgrade: https://www.amazon.com/gp/product/B0036DDXUM/ https://www.amazon.com/gp/product/B00NUB2TWI
Cal122181.00 johnnyorange52.50 |
12-15-2023, 08:45 AM | #54 | |||
Rep 3,011
OK, you stumped me on this one... this is approaching scary land for me. First I've heard of it, is this a pretty good guide? https://www.e90post.com/forums/showthread.php?t=1426773 I can swap OFHG and radiators all day, but I hate stuff like this... |
12-15-2023, 09:07 AM | #55 |
92
Rep 149
Looking at your valve cover, it may just be dirty from people spilling oil when pouring it in. I too thought I needed to do the valve cover gasket. I cleaned and flipped the seal on the oil cap and now everything has stayed clean for 6 months
Maybe VCC are getting replaced due to leaky oil caps?. |
12-15-2023, 09:58 AM | #56 | |
Rep 3,011
Efthreeoh17318.00 E93Seattle (Racerbruce)799.50 |
12-15-2023, 12:09 PM | #57 |
Rep 462
Drives: Break My Wallet
One of the first things I did when I got the car. Except I got OE Magneti Marelli with rear amber signals.
12-15-2023, 12:13 PM | #58 |
Rep 462
The GM transmission was not super smooth to begin with. I noticed it likes to hold the gears in particular 1 to 2 shifts when the trans fluid is not warmed up yet. Then it seems to get better as the car warms up.
12-15-2023, 04:43 PM | #59 | |
1208
Rep 2,835
https://www.schmiedmann.com/en/cata-ol?q=63217289431# https://www.schmiedmann.com/en/cata-ol?q=63217289432# https://www.schmiedmann.com/en/produ...t=B61319169416 Last edited by Greyfox; 12-15-2023 at 04:49 PM.. |
12-15-2023, 08:10 PM | #60 |
Rep 3,011
Most import issue has been addressed!
Bonus finding out that windshield washer pump(s) leak... hooray! |
E93Seattle (Racerbruce)799.50 johnnyorange52.50 |
12-15-2023, 10:10 PM | #61 |
1208
Rep 2,835
TIP... before attempting to put washer tank/pumps back in the fender... pull the side turn/marker light out of the fender. Makes it so much easier to get the tank back in correctly. You don't even have to disconnect the light... just let it dangle.
12-16-2023, 09:21 AM | #62 |
General
17318
Rep 18,742
My E90 mileage is now down to <5,000 miles per year
Greyfox1207.50 E93Seattle (Racerbruce)799.50 |
12-16-2023, 07:27 PM | #63 | |
Rep 583
for the unlearned (that would be me), please describe the damage to the part in the last pic and what is that part?? |
12-16-2023, 07:38 PM | #64 |
Rep 583
StradaRedlands4949.00 Efthreeoh17318.00 |
12-16-2023, 08:26 PM | #65 |
1208
Rep 2,835
From my having to replace the main hose that you see, I'm thinking it's the driver side (left) top of the radiator and that crack has been peculating a long time.
12-16-2023, 08:28 PM | #66 |
1208
Rep 2,835
