Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Hoping for a quick/easy headlight fix
      03-27-2024, 11:58 AM   #1
moosebrew
moosebrew's Avatar
Drives: 335xi, Z4 3.0i, 328xi, 325xi
2011 335xi, xenon lights
Driver side Xenon bulb shows as out on the dash. Bulb works, then goes out. Switches back and forth from working to not working while driving. Angel eye stays on when bulb goes out.
Bad bulb itself? Dielectric grease needed on the connection? Some kind of relay or switch?
What do you think would fix it?
      03-27-2024, 12:02 PM   #2
lowrydr310
Robot
1686
Drives: 2006 330i, 2007 E93 335i
Only way to find out is to open the light and inspect! Check the connections. Also check the ballasts for any damage - any condensation or moisture inside the housing? If all check out OK, replace the bulb.
      03-28-2024, 05:00 PM   #3
moosebrew
moosebrew's Avatar
Thanks, I'll look into it
      03-28-2024, 06:01 PM   #4
Nando_e90
El Salvador
108
Drives: 2006 E90 330i
Could be the ballast. You can first try swapping the ballasts, the one on the right headlight to the left and viceversa.
Had similar symptoms when mine went bad. Sometimes the passenger side xenon worked and sometimes it went out. The ballast was the cause.
If not, you will have to check the inside connections as stated above, but take into account that the wiring isolation could be already cristalized and with little movement it starts to fall apart. You will need to rebuilt the isolation if so. Happened to me too lol.
