01-15-2017, 01:43 PM | #1 |
Rep 413
Exact (OE) Original Equipment Equivalents - Filters, Mounts, Components, etc.
For those interested in replacing parts on their M3 with the exact original equipment (OE) parts, less the BMW stamp and with no sacrifice in quality, here is the list I was able to put together from various posts, with help from other forum members and personal experience. Plus a huge additional list from member Flipmeraz (Thanks!):
Key: L = Left or Driver's Side R = Right or Passenger's Side Engine 1 BMW E9X M3 ignition coils = No longer appear to be available with the same quality as OE from the OE manufacturer 3 BMW E9X M3 spark plugs = NGK (4471) LKR8AP 1 BMW E9X M3 head gasket = Elring 11127841560 or Elring 198624 13 BMW E9X M3 timing cover gasket = Elring 11127838162 or Elring 354.811 5 BMW E9X M3 oil pan gasket = Elringklinger 11137841085 or Elring 354.721 3 BMW E9X M3 oil filter kit (with seals and copper crush washers) = Mahle OX254D3 (also packaged and sold as Hastings LF667) 4 BMW E9X M3 oil pressure sensor = Hella 006097001 1 BMW E9X M3 alternator = Valeo 439675 1 Production date before 4/29/08 BMW E9X M3 AC/power steering serpentine belt = Continental 6K1065 1 Production date on or after 4/29/08 BMW E9X M3 AC/power steering serpentine belt = Continental 6DK1100 2 BMW E9X M3 A/C Belt Tensioner Pulley Only = INA 5320557100 3 BMW E9X M3 A/C Belt Tensioner Strut Only 4/29/2008+ = INA F-239109.01 6 Built before 4/29/08 BMW E9X M3 deflection pulley (aka idler pulley) = INA 5320418100 6 Built on or after 4/29/08 BMW E9X M3 deflection pulley (aka idler pulley) = Only available from BMW 11287841531 1 BMW E9X M3 alternator/water pump serpentine belt = Continental 6K1460 2 BMW E9X M3 Alternator Belt Tensioner Pulley Only = INA 5320342100 3 BMW E9X M3 Alternator Belt Tensioner Strut Only = INA F-239110.04 2 2008-2009 BMW E9X M3 air filter = Mahle (or Clevite) LX1667 2 2010-2013 BMW E9X M3 air filter = Mahle (or Clevite) LX1590 1 BMW E9X M3 throttle actuators = Siemens VDO A2C59506263 (Also sold as 13627838085M82) 3 BMW E9X M3 engine mounts = Corteco 11812283798 2 BMW E9X M3 oil cooler line (from engine in to cooler) = Cohline 17222284077 3 BMW E9X M3 oil cooler line (from cooler to engine) = Cohline 17222284078 1 Fuel Tank Breather Valve = Bosch 13907838281 20 BMW E9X M3 low pressure fuel sensor = Bosch 0261230348 2 BMW E9X M3 DMTL pump (aka leak diagnosis pump) = Bosch 0261222018 4 BMW E9X M3 fuel injector = Bosch 0280158164 Cooling BMW E9X M3 engine coolant/antifreeze = Rowe 21066-408-03 6 BMW E9X M3 cooling pipe o-rings (x4 needed) = Victor Reinz 11531406249 12 BMW E9X M3 thermostat = Behr 11537836155 16 BMW E9X M3 Coolant Temperature Sensor - *Sold in generic boxes and labeled "O.E.M." brand from most of the large online parts retailers. The following branded sensors are not exact equivalents: FAE/Febi/MTC/Rein/VEMO. 1 BMW E9X M3 Radiator - exact equivalent not available BMW E9X M3 engine coolant/antifreeze = Rowe 21066-408-03 2 BMW E9X M3 Coolant Reservoir Cap = Rein 17117639021 Exhaust/Emissions 3 BMW E9X M3 exhaust manifold gasket for cylinders 1,6,7 and 8 = Elring 728600 4 BMW E9X M3 exhaust manifold gasket for cylinders 2,3,4 and 5 = Elring 728610 5 BMW E9X M3 Secondary Air Injection Control Valve (aka EGR Valve) for cylinders 2,3,4 and 5 = Pierburg 11727838028 6 BMW E9X M3 Secondary Air Injection Control Valve (aka EGR Valve) for cylinders 1,6,7 and 8 = Pierburg 11727838029 1 BMW E9X M3 pre-cat oxygen (O2) sensor = Bosch 17039 3 BMW E9X M3 post-cat oxygen (O2) sensor = Bosch 16793 (limited availability - now superceded by Bosch 16421) DCT Transmission BMW E9X M3 DCT Fluid = Pentosin 1080107 1 BMW E9X M3 DCT transmission pan = Getrag SP02228 6 BMW E9X M3 DCT suction filter = Getrag 28107842828 8 BMW E9X M3 DCT transmission filter (filter only) = Getrag 28107842840 Manual Transmission BMW E9X M3 Manual Transmission Fluid (BMW MTF-LT-2) = Pentosin MTF2 75W-80 (no longer in production) 1 BMW E9X M3 clutch kit = LUK 03-102 (also sold as LUK 6223308000 and LUK 622330800) 2 BMW E9X M3 release bearing = INA F-232336.15 (also sold as LUK MC0800 and F.A.G. MC0800) 7 BMW E9X M3 manual transmission large shaft seal = Corteco 01033866B Other Driveline Components 1 BMW E9X M3 flywheel- LUK DMF148 2 BMW E9X M3 pilot bearing= NTN 11211720310 11 BMW E9X M3 differential output shaft seal with lock ring = No Exact Match Available - A very close match made by the same company, but at a different factory is Victor Reinz 33107510289 1 BMW E9X M3 centering sleeve (aka driveshaft end bushing) = Corteco 80000024 2 BMW E9X M3 flex disc (aka guibo) = SGF GAB01-024 (also now packaged as FEBI 32986 - send back the FEBI part if it does not have a "SGF" stamp directly on the part, older FEBI packages of this product were from a different supplier) 2 BMW E9X M3 rear right or left, wheel bearing (45 X 85 X 41 mm, with magnetic ring) = F.A.G. 805560A Lighting 1 BMW E9X M3 Bi-Xenon Adaptive Curve Headlight Left (driver's side) Headlight Assembly (Plastic Housing) - Automotive Lighting 63117182517 *Note: These headlights do not have text painted on the chrome surround of the headlight bulb. 1 BMW E9X M3 Bi-Xenon Adaptive Curve Headlight Right (passenger's side) Headlight Assembly (Plastic Housing) - Automotive Lighting 63117182518 *Note: These headlights do not have text painted on the chrome surround of the headlight bulb. 1 BMW E9X M3 xenon control unit (Ballast) = Automotive Lighting LRB160 (also packaged and sold as Magneti Marelli LRB160) 2 BMW E9X M3 xenon bulbs = Sylvania D1S 9 BMW E9X M3 Turn Signal Bulb with Base - Sylvania - Phillips PSY24WSV 1 BMW E9X M3 Headlight Level Sensor (front and rear are the same part) = 37146853753 *Sold in generic boxes and labeled "O.E.M." brand from most of the large online parts retailers. 4 BMW E9X M3 Headlight Washer Pump = VDO 246086001007Z Suspension - Front 14 BMW E9X M3 front tension strut right side (aka upper control arm or thrust arm) = TRW brand JTC1423 14 BMW E9X M3 front tension strut left side (aka upper control arm or thrust arm) = TRW brand JTC1424 15 BMW E9X M3 front tension strut bushing only, right and left are identical (this requires a shop press or special bushing tool for install) = Lemforder 31102283579 19 BMW E9X M3 front lower right control arm (aka wishbone) = TRW brand JTC1427 19 BMW E9X M3 front lower left control arm (aka wishbone) = TRW brand JTC1426 BMW E9X M3 front springs (non-ZCP) - Suplex 06373 5 BMW E9X M3 front wheel bearing = F.A.G. 805583A 7 BMW E9X M3 front ABS speed sensor aka dsc pulse generator = ATE 360352 or 24.0711-6209.3 or 34527853586 (1 right side and 1 left side, same part #) 6 BMW E9X M3 Front Sway Bar End Links (aka swing support bars) = Not Available (Note: TRW JTS1658 and TRW JTS1657 are not Exact OE as many other TRW suspension components are, these are lower quality aftermarket pieces) Suspension - Rear 2 BMW E9X M3 rear trailing arm bushing = Lemforder 3058201 or 33326763092 3 BMW E9X M3 rear ball joint for wheel carrier right or left = Lemforder 3642601 or 33326792553 13 BMW E9X M3 rear lower rearward control arm with bushings right and left (aka track struts) = TRW JTC1432 or 33322283549 17 BMW E9X M3 rear left, upper rearward control arm with bushings = TRW JTC1428 or 33322283545 17 BMW E9X M3 rear right, upper rearward control arm with bushings = TRW JTC1429 or 33322283546 18 BMW E9X M3 rear left, upper forward control arm with bushings = TRW JTC1430 or 33322283547 18 BMW E9X M3 rear right, upper forward control arm with bushings = TRW JTC1431 or 33322283548 19 BMW E9X M3 rear right or left, ABS Wheel Speed Sensor = ATE 360118 or 24.0711-5191.3 or 34526870077 6 BMW E9X M3 rear upper shock mount (lower section) right and left = Lemforder 33506771738 7 BMW E9X M3 rear upper shock mount (upper section) right and left = No Exact Match Available - A very close match by the same manufacturer that is constructed of one foam piece vs OEM 2 piece foam = Lemforder 33506771737 BMW E9X M3 rear springs (non-ZCP) - Suplex 06342 6 BMW E9X M3 rear sway bar end link (right and left side) = Lemforder 33556764428 2 BMW E9X M3 rear Forward subframe bushings - Lemforder 3779801 or 33312283382 3 BMW E9X M3 rear Rearward subframe bushings - Lemforder 3779701 or 33312283383 Steering BMW E9X M3 power steering fluid = Pentosin CHF 11S 1 BMW E9X M3 Power Steering Reservoir - ZF Lenksysteme or ZF 32416851218 *Note: Does not have green ring painted on reservoir cap. 1 BMW E9X M3 power steering pump = ZF Lenksysteme or ZF 32412283002 6/25 BMW E9X M3 one time use (crimp style) hose clamps = Oetiker, model number varies by size 21 BMW E9X M3 power steering cooler = Modine 17117522119 BMW E9X M3 multi-use, spring style hose clamps = Mubea, part number varies by which of the clamp sizes 4 BMW E9X M3 front full tie rod assembly right = Lemforder 3190401 4 BMW E9X M3 front full tie rod assembly left = Lemforder 3190301 5 BMW E9X M3 front tie rod end only right = Lemforder 32106767782 5 BMW E9X M3 front tie rod end only left = Lemforder 32106767781 Brakes BMW E9X M3 brake fluid = Pentosin DOT 4LV (1224116) 4 BMW E9X M3 caliper guide bushings = ATE 260098 or ATE 34116758707 5 BMW E9X M3 caliper guide pin cover - ATE 990052 or ATE 34111154979 6 BMW E9X M3 upper brake caliper pins = BMW only, OEM equivalent not available 7 BMW E9X M3 front lower brake caliper pins = ATE 250153 or ATE 34116757036 8 BMW E9X M3 anti-rattle clip for front caliper - ATE 390447 *Note: These are unpainted steel so they have a silver colored appearance vs BMW black painted OEM. 12 BMW E9X M3 front pads- Textar 2331207 13 BMW E9X M3 left front pad sensor- BOWA A059091 13 BMW E9X M3 right front pad sensor- BOWA A059092 *Not Pictured - BMW E9X M3 Performance Front Brake Pads (NOTE: THESE ARE TRACK PADS, NOT THE OEM PADS THE CAR WAS DELIVERED WITH) = Pagid 8053RS19 1 BMW E9X M3 front left rotors - VNE 34212283801 1 BMW E9X M3 front right rotor - VNE 34212283802 6 BMW E9X M3 brake caliper pins (set of 4) = FTE K10005 8 BMW E9X M3 rear caliper guide bushings = ATE 260009 or ATE 34216869617 9 BMW E9X M3 anti-rattle clip for rear caliper = ATE 390445 *Note: These are unpainted steel so they have a silver colored appearance vs BMW black painted OEM. 11 BMW E9X M3 rear pads- Textar 2373001 12 BMW E9X M3 rear pad sensor (only 1 needed on rear passenger's side, no sensor on rear driver's side) - BOWA A059080 *Not Pictured - BMW E9X M3 Performance Rear Brake Pads (NOTE: THESE ARE TRACK PADS, NOT THE OEM PADS THE CAR WAS DELIVERED WITH) = Pagid 8021RS19 1 BMW E9X M3 rear left rotors - VNE 34212283803 1 BMW E9X M3 rear right rotor - VNE 34212283804 5 BMW E9X M3 front brake lines (hoses) = ATE 83.7751-0502.3 7 BMW E9X M3 center (mid car) brake lines (hoses) = ATE 83.7850-0180.3 11 BMW E9X M3 rear brake lines (hoses) = ATE 83.7752-0236.3 8 BMW E9x M3 brake vacuum pump = Hella 8TG 009 383-101 Climate 1 BMW E9X M3 A/C Compressor = Denso 471-1559 5 BMW E9X M3 A/C Pressure Sensor = ACM 0155.1023 (also packaged and sold by large online parts stores as generic "O.E.M." brand) 1 BMW E9X M3 HVAC Blower Motor = ACM 0157.0052 (also packaged and sold as Valeo 64119227670) 2 BMW E9X M3 Blower Motor Resistor = ACM 0155.1027 (also packaged and sold as Valeo 64119265892) 1 BMW E9X M3 A/C Expansion Valve = ACM 0151.0025 (also packaged and sold as Egelhof 01510025) 1 BMW E9X M3 A/C Condensor = Behr 351302611 2 BMW E9X M3 A/C Condensor Dryer Insert ($61) - Vemo V20-06-0073 Miscellaneous 1 BMW E9X M3 cabin filters = Corteco MicronAir CC1377 (80001029) 5 BMW E9X M3 hood struts (interchangeable right or left) = Stabilus 016717 (Also sold or listed as ST016717 or 4B-016717 or UPC# 194879005508) - *Note: While Stabilus 9669ZC (Also sold or listed as ST017917 or 4B-017917 or STB-9669ZC or SG402058 or UPC # 708609328968) will fit, it is not an exact match as it outputs 330NM of force vs 200NM of force for the original strut, it is not intended for the lightweight M3 hood, it is for the normal 3 series. This part is incorrectly cross referenced on some websites. 7 BMW E90 Sedan M3 ONLY - trunk struts = Stabilus SG302063 7 BMWE92 Coupe M3 ONLY - trunk struts = Stabilus SG302066 1 BMW E9X Boot lid/tailgate pushbutton (aka trunk handle) = MOCW 51247118158 5 2008-2010 BMW E9X M3 TPMS = Huff RDE008 5 2011-2013 BMW E9X M3 TPMS = Huff RDE012 7 BMW E9X M3 TPMS valve stem caps (silver or black) = ALLIGATOR Ventilfabrik, part number varies by quantity ordered Fluids: Can't definitively prove these, but could possibly be an exact match to the OE version: BMW 75w-140 Limited Slip GL-5 standard differential fluid, aka SAF-XJ (2007-2016) = Rowe Hightec Hypoid EP SAE 75W-140 S-LS (same style small cone caps for both BMW branded and Rowe branded) BMW 75w-140 Limited Slip GL-5 differential fluid with extra friction modifier, aka SAF-XJ+FM (2007-2016) = Castrol Syntrax SAF-XJ 75w-140 (exact same design for the cap on both of these bottles, green cap for the BMW branded oil and red cap for the Castrol branded oil) BMW 75w-140 Limited Slip GL-5 rated differential fluid with extra friction modifier, aka SAF-XJ+FM (red cap bottle 2016+) = Shell Spirax S6 AXME 75w-140 BMW M TwinPower Turbo 10W-60 oil = Shell Helix Ultra Racing 10W-60 BMW E9X M3 DCT Fluid = Pentosin 1080107 BMW E9X M3 Manual Transmission Fluid (BMW MTF-LT-2) = Pentosin MTF2 75W-80 (no longer in production) BMW E9X M3 Brake Fluid = Pentosin DOT 4LV (1224116) BMW E9X M3 engine coolant/antifreeze = Rowe 21066-408-03 BMW E9X M3 power steering fluid = Pentosin CHF 11S BMW E9X M3 washer fluid = Rowe Hightec 21104001003 Lubricants and Threadlockers: BMW E9X M3 driveshaft CV joint grease Optitemp HT LF1 = Castrol Molub-Alloy 370-2 BMW E9X M3 flexible disc centring and centring pin of the gearbox output flange grease Optimol Olistamoly 2 L584LO = Castrol Olistamoly 2 BMW E9X Anaerob Drei Bond 1385 threadlocker for differential pinion nut = Permatex High Temperature Threadlocker Red 27200 BMW E9X M3 grease for drive axle splines Unirex S2 Grease = Exxon/Esso/Mobil Unirex S2 BMW Branded Specialty Tools: BMW 21mm strut removal tool part # 83300491931 = Hazet 2593-21 BMW strut sleeve spreader part # 83300491930 = OEM Only - Not Available in Equivalent Form (This part is custom machined for BMW from a 23mm Stahwille 509/2 1/2" drive extension bar - a very nice piece!) BMW Smart Battery Charger (61432358315) = CTEK 56-864 BMW Torque Angle Tool#00 9 120 sold as BMW Part# 83300490504 - Hazet 6690 Exact Equivalents Not Available: BMW E9X M3 deflection pulley (aka idler pulley) Built on or after 4/29/08 - not available BMW E9X M3 Wiper Blades - not available BMW E9X M3 Adaptive Headlight Control Unit - not available BMW E9X M3 A/C Belt Tensioner up to 4/29/2008 - not available BMW E9X M3 Radiator - not available BMW E9X M3 Water Pump - not available BMW E9X M3 Water Pump Pulley - not available BMW E9X M3 Front Strut Assemblies - not available BMW E9X M3 Rear Shocks - not available BMW E9X M3 Engine Oil Level Sensor - not available BMW E9X M3 ZCP front springs - not available (non-ZCP version is available) BMW E9X M3 ZCP rear springs - not available (non-ZCP version is available) BMW E9X M3 oil cooler - not available BMW E9x M3 18", 19" and 19" ZCP wheels - not available BMW E9X M3 front, lower brake caliper pins = BMW only, OE equivalent not available BMW E9X M3 exhaust hangers - not available BMW E9X M3 exhaust gaskets (headers to x-pipe) - not available BMW E9X M3 Front Sway Bar End Links (aka swing support bars) BMW E9X M3 ignition coils = No longer appear to be available with the same quality as OE from the OE manufacturer Looking for exact equivalent to the OE components for any of the following: differential pinion seal? radiator hoses -are these Rein brand? interior and exterior bellows repair kit (aka cv boot repair kits)? wheel bolts? rear axle nut? (It's not Febi brand) front strut bearings, are these even available in OE form for purchase? Special thanks to the following members for additional items and corrections: Flipmeraz - huge contribution! JsL geoffreyaugusto M3MPH1S doogee FLAMES Drv4fun seevin Hoosier_M3 Mvy Deansbimmer ItsGary Davisca455 Ant Man BayAreaE93 LKN624
50
flipmeraz208.50 dparm3852.50 Atomicteal_M3750.00 Obi Wong Kenobi34.50 tdott3956.00 Nickdm316.50 Banana Hammock3771.00 roastbeef11591.50 jjw233153.50 6ixSpd6030.50 blue-mw217.00 oolas3388.00 FogCityM3500.00 e92zero212.00 trm005334.00 M3MPH1S592.00 dreamspeed262.00 SYT_Shadow11501.50 Law6386.00 buddalun682.00 K-M390.50 Nairb167.50 xwilkinx49.50 jmeek8337.00 8500RPM152.00 Solo_M_Tech1687.50 marcster19.50 asif16398.50 Timujin352.50 volkrays15.50 XKxRome0ox1589.00 Mvy541.50 SVH152.00 Postie6e9.00 testdriver25.50 wanna325i23.50 linkexplore0.00 Scharbag2634.00 |
01-16-2017, 05:25 AM | #3 |
Rep 4,430
Great info. Thanks
ModeCarbon V1 CF lip/PF AG CF SS ext./ARKYM CF Diffuser/OSS AE's/B&G Springs/CF Performance Spoiler/V2 Led Performance SW/Meisterschaft GT exhaust
01-16-2017, 07:42 AM | #4 |
17
Rep 235
Drives: M3 E92 Black & White Edition
Nice post !
BMW M3 E92 Black & White Edition | BMWP Kidneys | Carbon Spoiler/Lip/Diffuser | Akrapovic Evolution + Delete R | OEM Black ZCP Wheels
Honda S2000 04' - Bilstein B14 | Aero Kit | HKS Spec-L | KN FIPK |
01-16-2017, 12:20 PM | #5 |
Stop the hate, get a V8
3853
Rep 8,625
For the most common maintenance items, there can be multiple suppliers at once such as Mann and Mahle. The parts are functionally identical but sometimes the packaging or minutia can be different. Similarly, some of these big OEM suppliers have multiple sub-divisions as you alluded to (Wix, Hastings, Baldwin, etc).
In the end, as long as you buy from one of the big OEM suppliers, you should be fine. I have used a variety of those brands over the years on my BMW and on previous cars and there has never been an issue with fitment or performance.
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP Last edited by dparm; 01-16-2017 at 12:32 PM.. |
01-16-2017, 12:31 PM | #6 | |
3853
Rep 8,625
Brake wear sensors: I have used multiple different brands such as Bowa, Vemo, Febi, Bremmen, and ATE. They are all identical other than different colors for some of the connectors or wires. It's a pretty simple part used by tons of BMWs so I would just get whatever is cheapest. Heck, local auto parts stores typically have them in stock or can get them within a day. I suspect BMW uses multiple suppliers since this is a common maintenance item for all of their cars. Brake pads: Textar/Pagid and Jurid supply OEM pads to BMW. The specific ones you got from the factory versus the parts counter may vary, especially over the years. Front and rears might not even be the same supplier. Brake fluid: OEM is probably Pentosin or Continental/ATE, both are huge OEM suppliers.
Past: 2011.5 M3 sedan ZCP Last edited by dparm; 01-16-2017 at 05:43 PM.. |
01-16-2017, 12:46 PM | #7 |
Rep 535
I'll try and add some more later.
BMW E9X M3 front pads- Textar 2331207 BMW E9X M3 rear pads- Textar 2373001 BMW E9X M3 left front pad sensor- BOWA A059091 BMW E9X M3 right front pad sensor- BOWA A059092 BMW E9X M3 rear pad sensor- BOWA A059080 BMW E9X M3 thermosat- MAHLE THD179 BMW E9X M3 water pump- GEBA 11517838201 BMW E9X M3 clutch kit- LUK 03-102 BMW E9X M3 flywheel- LUK DMF148 BMW E9X M3 pilot bearing- INA 6002.2RSR BMW E9X M3 release bearing- LUK MC0800
01-28-2017, 04:49 PM | #15 | |
3853
Rep 8,625
I can always find at least two or three auto parts stores within a few minutes of me that have them in stock. Extremely common part.
Past: 2011.5 M3 sedan ZCP |
01-29-2017, 11:29 PM | #18 |
Rep 12,736
is there any kind of reading material where it is easy to lookup torque specs for every bolt on the car?
Instagram; @roastbeefmike
01-30-2017, 10:53 PM | #19 | |
Rep 413
roastbeef11591.50 |
04-13-2017, 11:27 PM | #21 |
Rep 1,263
Heads up that BMW E9X M3 post-cat oxygen sensor Bosch 16793 has been superceded by Bosch 16421
I just installed 16421 on my car and it works fine. They look identical as well. Last edited by JsL; 04-17-2017 at 11:25 AM.. Reason: Add Pic |
04-14-2017, 07:02 PM | #22 |
Rep 413
