TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > Tab repair kit for broken headlight tabs?
      05-01-2012, 01:21 PM   #23
DBee91
Drives: BMW e90 MSport
Can these be bought anywhere in the UK?
      05-03-2012, 09:48 AM   #24
sea335i
Drives: 2008 335i Coupe
http://www.bmwmercedesparts.com These guys sell kits for about 20$ not sure if they ship to UK.
      09-14-2012, 03:56 PM   #25
chuddism
Drives: 328xi
so what do you do if the complete bracket is broken off and the two holes the repair kit is supposed to screw into is in your hand?
      03-17-2015, 06:50 AM   #26
cdgatti
cdgatti's Avatar
255
Drives: e90 328i
bumping this old thread. looking for part number for the e90 headlight repair kit. i think the number in this thread is for e92/93.
I found these clips for the e90
63117175227
63117175228
63117175229
63117175230
But they appear to be only the clips that mount on the tabs, not the tabs themselves.
OEM Black grill and Blackline tails - LCI halogens with Lux V2 coded as DRL - 3M Crystalline - BMS PBX - OEM Euro Airbox with K&N - Hardwired CTEK - Bilstein B6 w/OEM springs and SP perches - Conti DWS06 - HiFi-Helix DSP - JLAudio HD/XD-Morel - CD changer trim - AE optical out
      11-13-2016, 12:47 PM   #27
xxirish83x
Drives: 2011 335i xdrive
Bumping this old thread to share that these clips do an amazing job of fixing my shakey headlamps caused from broken clips. It comes with 2 clips per package. Each headlamps will require 2. Once fixed you can't even tell that it's been modified unless you know what you're looking for.
https://www.ecstuning.com/ES172042/
triax37130.00
      10-11-2017, 02:58 AM   #28
WOODZBMW
Drives: BMW 320D MSPORT E90
Originally Posted by Ndx View Post
Weld the plastic ... i fixed my lci .. tabs they are super strong solid ..
This plastic is great for welding ..
If you will have any questions let me know.
you screw the tab in ... can you see two holes just below snapped bracket ... thats how you mount them ...
Hi
i know this is an old thread but im really hoping you see this and can help. How do i go about fitting the repair kit? Does the headlight have to be removed from the car or can it be fitted with the headlight still attached?
Many Thanks
      12-02-2019, 08:48 AM   #29
xxirish83x
Originally Posted by WOODZBMW View Post
Hi
Many Thanks
replying to an old ass comment... it bolts right up to the installed headlight. would take a few minutes to complete the install
      01-23-2020, 08:25 AM   #30
P@shencia
Drives: BMW X1 x20d 2010
E90 have two different headlights type
-ZKW
-Valeo same tabs for E84
and tabs are different for this lights. Each sold separately and without screws, made from metall.
I do it from plastic with OEM screws. It's work more than 3 years for Valeo headlights
e92 also different tabs and cheap
      02-09-2020, 11:12 AM   #31
drawz
drawz's Avatar
Drives: 06 330xi 6MT, 08 535xiT 6MT
Where do the plastic tabs come from? The OE sedan repair tabs don't even include screws.
Anyone repair the tab on the underside of the headlight?
      02-11-2020, 03:20 AM   #32
P@shencia
Underside don't have official repair kit, but ebay have it
upper tab I do from plastic because it's safely for headlight
      11-14-2023, 04:45 AM   #33
Knuppel
Drives: E91
Tabs from bulb cap
On my E91 the previous owner broke off a tab from the bulb cap (on both headlights). I now have moisture in my headlights. Is there a repair kit for these also?
