2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Work Wheels Fitment Chart help
      02-23-2018, 04:09 PM   #1
ausfahrt
33
Drives: 2001 325i Touring
I need your expert help. I 'm looking at wheels and I don't understand this offset thing. I want the middle Concave for the front and Deep Concave setup for the rears. If I have to go with Semi Concave for the fronts because of offset issues than I'm ok with it. With the Chart, which offset and size can I go with? I don't Have BBK and I'm lowered on H&R springs. Thank You.
      02-23-2018, 06:00 PM   #2
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
First it really helps to know which Works Wheel you're getting?
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~
Follow me on Instagram: lsturbointeg
      02-24-2018, 08:39 AM   #3
ausfahrt
33
Sure man, it's the Zeast ST1. It looks good on this M5.
      02-24-2018, 02:07 PM   #4
ausfahrt
33
Here's another.
      02-24-2018, 04:19 PM   #5
ausfahrt
33
Will the highlighted
20x9.0J -I guess the offset is 27
20x11.0J -I guess offset is 42
      02-24-2018, 10:05 PM   #6
lsturbointeg
For the rears i would run 20x11 38mm. You can see how flush it is. Or run 40mm and it'll push it in 2mm
Fronts 20x9.5 25mm. Mine here is 30mm but you can see i probably could have went with a 25mm to push the wheels 5mm out more
This would be for a flush look without running spacers
      03-26-2018, 10:00 AM   #7
Corven
Corven's Avatar
Drives: BMW F10 525d (2016)
Question
I have a question about offset for F10 non-m
Front 20x9 ET20 ( 245/35/20 or 255/35/20 )
Rear 20x11 ET40 ( 295/30/20 )
1. Rub ?
2. Front 245/35/20 or 255/35/20 ?
Thank you
5post
