TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > DIY: Setup BMW Standard Tools 2.12 on Windows XP > 10
      12-30-2015, 08:19 PM   #23
Venoml2k
Drives: 135i
Originally Posted by wildcatcrazy View Post
More than likely your cable is bad. What color is the PC board, and where did you get it from?
i bought it off a member on here, he said it was the onestop shop cable. it has a clear case, black cord, green board, says k+dcan usb interface (inpa compatible). the bmcarly app recognizes it, and i turned off the jb4 by putting it on 0. ill get a pic in a sec.
is the cable the only thing it could be? i see the battery and ignition on thing in inpa.
https://mega.nz/#!dlYnAb5a!6eghXHMJU...f_ohI9ZRdZsT4M
https://mega.nz/#!o5wRSDZC!x_NqhnJoF...9cZia6plSgqpbQ
      12-30-2015, 11:17 PM   #24
wildcatcrazy
wildcatcrazy's Avatar
Drives: E90 335i
2009 335i  [0.00]
Try using FRM/NFRM instead of CAS.
      12-31-2015, 03:34 AM   #25
evo97
evo97's Avatar
Drives: 335d
Thanks.
      01-01-2016, 05:56 PM   #26
JB4N
JB4N's Avatar
Drives: 2011 335i M-Sport
I finally got a working version of INPA!! Very easy step by step guide, awesome work
      01-03-2016, 03:19 AM   #27
Nicholas Bentley
Nicholas Bentley's Avatar
Drives: 2011 BMW 335i E90 LCI N55
Thank you for this post. Very handy.
      01-03-2016, 01:58 PM   #28
mrvedit
48
Drives: 2013 M3
Yes, this looks very promising, but your DATEN Link text file has a link to a Mega.nz directory in which I do not see the E90 data files.
Since you have a '09 335i, similar to my '08 335xi, what am I missing? (Or do I need better glasses?)
2017 M3 DTC * 2013 M3 Manual
2017 330i (Winter beater)
1981 Camaro Z28 - 427 LS3 - 10.94 @126mph
2006 Corvette (streetable track car)
1986 535i "24 Hours of Lemons" also streetable
      01-03-2016, 06:16 PM   #29
wildcatcrazy
Drives: E90 335i
2009 335i  [0.00]
E90 is covered by E89...
Appreciate 3
jard35.50
      01-03-2016, 08:11 PM   #30
mrvedit
48
Drives: 2013 M3
Aha, I was just about to try that. Thank you for the confirmation.
I will continue installing your "ready to use" files on my Win7 machine then.
Is this true in INPA too?
Selecting E90, I get very little info out of INPA - driver's seat, the transmission, Dynamic Stability Control DSC, and just a few others. Not even the passenger seat. I have two '08 335xi and this is true for both.
My E90.ENG file shows version 1.32. This is on my 32-bit XP machine. Should I see more? Perhaps change inpa.ini to allow selecting a E89?
      01-03-2016, 09:39 PM   #31
wildcatcrazy
Drives: E90 335i
2009 335i  [0.00]
You should have about 5-6 menu items once you select E90, with each menu having several sub menu selections to communicate with a particular module.
      01-04-2016, 02:57 PM   #32
J. Dub
Bob Saget
J. Dub's Avatar
Drives: 2010 335i e92 N54 A/T
wildcatcrazy Thank you for this.
You should accept paypal donations for this great write-up.
I'd also love to see a write-up on updating each module within our E9x's and what each update does/benfits.
Cheers.
P.S. if you ever decide to take paypal donations please advise.
In memory of Robert E. Flynn (AR)
      01-04-2016, 09:03 PM   #33
wildcatcrazy
Drives: E90 335i
2009 335i  [0.00]
Cheers.
There are several coding cheat sheets and tutorials floating around out there. Just google E90 coding cheat sheet and then NCS Coding Tutorial. Those combined documents will provide you with what you need.
Appreciate 3
      01-05-2016, 10:02 AM   #34
mrvedit
48
Drives: 2013 M3
You should accept paypal donations for this great write-up....
Agreed.
After trying on and off over the past year with cables and software from various ebay vendors, this is the first time I got both INPA and NCSExpert to run on my Win7 laptop. (I previously got INPA to run on my XP laptop.)
FYI - The ebay cables were flaky. The $40 cable from bimmer software ************** works perfectly. Plugged it in and Win7 was able to find the drivers on its own.
Be happy to send you $25 via Paypal and I suspect many other recognizing what you have greatly simplified will too.
My only suggestion is to include the recent DATEN files in your directory images. The e89.rar file is a monster 4GB download, which then expands to 11GB, but it appears only about 300MB actually get copied to the various data directories.
Thanks again.
      01-05-2016, 01:30 PM   #35
wildcatcrazy
Drives: E90 335i
2009 335i  [0.00]
Agreed.
FYI - The ebay cables were flaky. The $40 cable from **************.com works perfectly. Plugged it in and Win7 was able to find the drivers on its own.
Thanks again.
Pm sent.
I can't include the DATENs in the same download because they are constantly changing, so the next best thing is to provide the active link in my download files.
      01-06-2016, 07:56 PM   #36
Banana Clipper
Jewel Runner
Banana Clipper's Avatar
Drives: G01///G20///I20
Just want to confirm a couple things here. Will this work on a Parralles VM of Win 7 and will this allow for the Alpina TCU flash?
I already have BMWhat so I ONLY want the TCU flash. All other DIY's have failed me.
      01-06-2016, 07:59 PM   #37
wildcatcrazy
Drives: E90 335i
2009 335i  [0.00]
Yes and yes. This is a hefty install to only get the Alpina, but it will serve your purpose.
      01-06-2016, 08:15 PM   #38
Banana Clipper
Jewel Runner
LOL
Honestly at this point, with all the fails and near triumphs I've had I'll do whatever it takes to get the TCU flash done. I'm already on JB4 and running E85 and it gets better? I'm hooked, was up till 2am last night trying and failing but OH SO CLOSE with each and every try. My wife says I'm "cracked out on the car".
I would also like to learn how to do the JB4 BB pump flash if thats possible with this software set as well but I'm new to BMW and havent even had the car a month so I'm sure something I just said was wrong.
I agree with the others, even if just for 'donations' you should allow for users to PayPal you as a sign of appreciation unless you're fine with a good 'ol fashioned 'Thank You'
      01-06-2016, 08:27 PM   #39
wildcatcrazy
Drives: E90 335i
2009 335i  [0.00]
LOL
If this set up doesn't work, it's hour cable. Also don't forget to put JB4 in map 0.
      01-06-2016, 08:35 PM   #40
Banana Clipper
Jewel Runner
One final question and please forgive me if this is a 'dumb' question, but, when I perform the TCU flash am I ok to use the Daten files you've provided or should I use the 53.0 supplied in the tutorial?
      01-06-2016, 09:46 PM   #41
wildcatcrazy
Drives: E90 335i
2009 335i  [0.00]
I see some chatter about the 'color of the board' in the cable. Mine is green and says INPA compatible (I know, the internet never lies either right) and if you dont mind taking a look in my Google Drive at the pictures of it I sure would appreciate your input on whether or not its legit. Link to Google Drive is - https://drive.google.com/folderview?...VE&usp=sharing if not I totally understand. You've already been the single most helpful person to me on this board.
Happy New Year!
Appears to be a legit/working cable. Good luck.
      01-07-2016, 01:07 AM   #42
Banana Clipper
Jewel Runner
No luck with the TCU flash my dude. I press 'Program' and get this:
Any advise or you think its the cable? I even tried loading the 53.0 files as per the instructions in the Aplina DiY thread and get the same thing. Just wasnt meant for me...lol
      01-07-2016, 06:26 AM   #43
atirad82
Drives: F32
I use Window 8 and I can not install BMW standard tool in step 4
it said Only Window Xp and NT 4.0 are supported
Did I do something wrong or Windows 8 is not supported
Thank you
      01-07-2016, 07:10 AM   #44
cryptomit
Drives: 320d 2012
Right click on installation file, click Properties, go to Compatible tab and select Compatible mode Windows 7.
Click "Appreciate" if I helped you.
Appreciate 3
coding, inpa, ncs, tool32, winkfp
