Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > DIY: Setup BMW Standard Tools 2.12 on Windows XP > 10
      03-03-2021, 03:01 PM   #815
sc15
Drives: E92
Originally Posted by Joe@TopGearSolutions View Post
The link is included in the text document within the download.
Yes, the link takes me to a page showing several Exx.rar files but I can't spot an E90.rar. I assume that is what I need for an E92.
      03-03-2021, 03:04 PM   #816
Joe@TopGearSolutions's Avatar
263
Drives: BMW
E89 covers all E9x.
      03-03-2021, 03:25 PM   #817
sc15
Drives: E92
E89 covers all E9x.
Ok great, thank you for your help. I think I have a lot to learn about these BMWs.
      03-18-2021, 02:24 PM   #818
Mike K
Mike K's Avatar
Drives: 2011 e91 328i RWD
Newbie here hunting for my future e91 here in the Midwest USA. I'm planning on bootcamping an old Macbook for Windows XP (I have the disc) to do basics such as INPA, etc.
But first, I'm going to order a new SSD internal drive so any anybody tell me how big a drive I might need for BMW diagnotics and coding purposes?
I'm an old e30 guy now hankering to spend more on fuel, repairs, maintenance, etc and otherwise re-enjoy the BME experience!
Thanks!!
      03-18-2021, 03:34 PM   #819
263
Drives: BMW
Thanks!!
The size of disk really depends on how many programs you want/need to install. If all you're going to use is BMW Standard Tools (INPA), then a 256GB drive will work. Even if you want to add on ISTA/D, then that same drive should work. ISTA does consume about 20-22GB of space.
Also, I'd go with a supported version of Windows instead of XP. All of these programs will work with Windows 10.
Mike K322.00
      03-18-2021, 06:51 PM   #820
Mike K
Mike K's Avatar
Thanks alot Joe. This is the guidance I need to plan for BMW ownership. I’ll try to figure a path forward for Windows 10 as part of my plans. And maybe a 500gb drive too.
      11-13-2021, 06:25 AM   #821
Someone99
Drives: e90
Link in DATEN Link.txt doesn't work.
Could you please update? Thanks
      11-22-2021, 08:49 PM   #822
263
Drives: BMW
Sorry, haven't been on here in a while. Link updated in the referenced document. Thanks for letting me know.
      12-07-2021, 04:07 PM   #823
serc
Drives: F20 116i; E92 335i
@Joe
Hey Joe,
after following your guide, i got somehow stuck at updating the WinKFP
i get that error:
https://ibb.co/8K4GNns
Is that a problem?!
I installed it on WIN10; thanks for your help.
But all the tools are starting well;
trying to solve the issue with my FTDI chip USB Cable...
      12-07-2021, 04:20 PM   #824
Mantraxalos
78
Drives: 2006 330i Manual
2007 Z4 3.0i  [0.00]
2006 330I  [0.00]
What if you get bimmergeeks standard tools? Unless that's what you used, I never had any errors using their download.
Originally Posted by serc View Post
Hey Joe,
i get that error:
Is that a problem?!
      04-15-2022, 12:24 PM   #825
Scooterfreeride62
Scooterfreeride62's Avatar
Drives: 2008 M3 E92, 2007 335Xi E90
2007 BMW 335Xi  [0.00]
2008 BMW M3  [0.00]
offering the remote install service?
Hello, yes.
Hello, are you still offering the remote install service?
      07-27-2022, 04:30 PM   #826
alistairolsen
Drives: X70 X5
Hi everyone, I hope someone may be able to help me with an odd error!
I have followed the procedure in the OP to install the software and I'm using a silver cable from B-Cables and all appeared to be working okay.
I have just replaced the parking brake actuator (EMF module) under my 2008 X70 X5 and there is still an error on the dash. I tried to code the VIN using NCS-Expert and I can get the VIN from the CAS but the job fails when attempting to write to the EMF.
Further investigation reveals that the EMF appears in INPA, but I get a IFH-0009 No Response From Controller message. INPA connects fine to various other modules in the same vehicle.
I have confirmed with the refurbishers that the module was tested and working on another vehicle before it was dispatched to me and I have visually inspected the loom tail and plug which seems to be in good condition and checked for 12V at the main live and neutral terminals.
So, any ideas? Something funky with my cable? Daten issues? I've found a handful of references to similar behaviour but all the threads dead end without resolution.
Thanks!
      08-08-2022, 08:28 AM   #827
barthox
Drives: bmw x1
I'm looking for a ncs expert full sp-daten and with complete profiles. Would you help me?
      09-22-2022, 12:25 AM   #828
PeteO
Drives: BMW e90 325i
download bmw standard tools
thanks for the thread I will attempt to follow your instructions and put it into my laptop
pete
      12-03-2022, 03:57 AM   #829
Kedadus
Kedadus's Avatar
Drives: E91 320D xDrive 08
WinKFP and tool32/NCS
Hey!... so i got it installed but i got some "problems"
NCS only have Factory Reset and Feature Coding in the profile..
WinKFP i get error
Error 1:
CoapiKfInit: Initialization error!
Tool32 is in german.. the one i had in the past was in english menu and german rest
      01-01-2023, 08:35 PM   #830
markvw_3ser
Drives: 2010 328i
BMW Coding Tool - Invalid Picture Error
Originally Posted by AutoEngBM95 View Post
Everything goes smoothly until I get to step 14 and 15. There is no NCSExpert. On step 16/17, when I go to run the coding tool program, I get INVALID PICTURE, despite having changed compatibility for windows 7. How do I fix this?
If you are seeing this error, you may have an invalid value specified in your TMP and TEMP environment variables. This is likely due to conflicting installation instructions which guided you to update those values. Undo that update by removing ";C:\EDIABAS\Bin" from those variables and the error should go away. That's what worked for me. Good luck!
      09-13-2023, 10:58 PM   #831
ryanalex
Drives: e90 325i, e84 X1 28i xDrive
Originally Posted by wildcatcrazy View Post
Many have asked for the easy way to install BMW Std Tools, and I have developed a proven method that can be done in less than 15 min depending on the processing power of your machine.
The only requirement for this install is Windows XP through Windows 10, 32 or 64 bit version and a working KDCAN cable. Instead of writing a lengthy detail in this post, I generated the instructions that's included in link below.
If this install has assisted you in achieving a working set up, please click the appreciate link, thanks!
MediaFire: https://www.mediafire.com/folder/a7jvirbs559ib/Software
NOTE:
For everyone who's having issues setting the default folders, it is because some of the downloads excludes "empty" folders. Therefore, make sure your folder structure on the C drive are as follows (if you're missing a particular folder, create an empty one):
C:\EC-APPS\INPA:
BIN
CFGDAT
DEMO
DOKU
english
english.met
HELP
PRT
SGDAT
source
C:\EC-APPS\NFS:
BATCH
BIN
CFGDAT
DATA
DOKU
FORMAT
KMMDAT
SGDAT
TRACE
WORK
C:\EDIABAS:
API
BIN
DOKU
ECU
HARDWARE
HELP
SIM
TRACE
TUTORIAL
C:\NCSEXPER:
BIN
CFGDAT
DATEN
PFL
SGDAT
STDAT
TAB
VERPLATZ
WORK
Chassis family guide for choosing your proper DATEN: http://www.e90post.com/forums/showthread.php?t=642883
Edit 1: Added F series files for INPA. Added support files for N47.
Edit 2: Added working copy of NCS Dummy.
Edit 3: Updated DATEN link.
Edit 4: Added notes about setting default folders in BMW Coding Tool.
Edit 5: Updated DATEN link to 60.0.
can't believe only 147 appreciates. thank you! (I had a friend send me the files - I wonder if there's a torrent or something that has them now that the hosting is gone?)
      09-15-2023, 03:53 PM   #832
Nuke335i
Nuke335i's Avatar
Drives: '08 335i e92 BSM
Link no longer works. Anyone have a current link to download the software? I need to do a ABS/DSC module brake fluid bleed, and seems like activating the pump usong INPA is the only real way to do it right. Thanks
      09-18-2023, 12:38 PM   #833
Ioakeim
Drives: Mini Cooper R56 2009
I also i am also searching for it if I find anything i will say
      03-22-2024, 03:45 PM   #834
gia1
Drives: BMW E46 325i
Hi i know this is an old thread but can i get a copy of this installation for my 2010 e93 bmw 335i n55 thanks for any help.
      04-17-2024, 04:48 PM   #835
Reiver
Reiver's Avatar
Drives: 2008 E93 330i
INPA & ISTA+
I have INPA & ISTA+ which work fine on my 2008 E93. However, I can't get either to work on my friends 2007 E83 X3.
Neither application will recognize the X3. Even manually entering the chassis number doesn't work.
Do I need some specific data files for the E83 ?
We have fitted a passenger seat occupancy bypass but still have the airbag light on.
Any suggestions ?
      04-17-2024, 11:39 PM   #836
inobu
Drives: 335i
Any suggestions ?
I'm just starting out myself. Here's what I have seen. There are a number of INPA versions out and each seems to have a different listing. 5.00 verses 5.06
You might have to hunt down the right versions.
Try to hunt down BimmerGeeks INPA version.
Inobu
coding, inpa, ncs, tool32, winkfp
