Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Software - Help yourself
      03-01-2020, 12:35 PM   #45
Hary09
Drives: Bmw 316d 2010
Thanks alot
Originally Posted by J0K3R5 View Post
Thank you manage to download it got it working but wouldn’t let mw do anything once i click on engine model no which is N47 says mismatch n47*** can someone help me sort it remotely or just check injectors flow rate as i give you up from last three days non stop i am trying to get this inpa working firstly it wouldn’t show my N47 engine now with above copy of inpa i can see my model engine but it wouldn’t read the engine so i can see or adjust injectors flow rate as it mis matches
      03-01-2020, 12:57 PM   #46
sdbmwcoding
Drives: BMW M3
Use ISTA/Rheingold
      03-01-2020, 01:28 PM   #47
Hary09
Any link please
Originally Posted by sd********* View Post
Use ISTA/Rheingold
Any link or direction to download it would be highly appreciated
      03-02-2020, 01:34 PM   #48
CarAbuser
CarAbuser's Avatar
469
Drives: Z4 35i DCT / E92 335i DCT
This is the version from the Bimmergeeks site: https://mega.nz/#!a1wUmYCD!G0C3_Hsg9...o9uQ4EpxjI8oZs
      03-02-2020, 05:21 PM   #49
ctuna
Drives: 325xi 06 wagon MT
If you have the diesels or the 4 cylinder's you may have to get
the a Daten that contains those and integrate it into the setup.
You might also try the Ista D install and see if that program supports
it.
      03-21-2020, 01:56 PM   #50
brtrvu
Drives: 335i
DEAD LINK
PLEASE!!
      03-21-2020, 02:56 PM   #51
J0K3R5
J0K3R5's Avatar
Vatican City State
406
Drives: BMW
yes all links are down, mega removed all my software.
Looking for a better place to host the files
Help yourself Software part II, read post 1 : https://www.e90post.com/forums/showt...7#post27890067
      03-22-2020, 01:18 AM   #52
Phill_k
Drives: BMW M235i
It would be great if you could PM link when you have found a better host. Cheers
      03-23-2020, 04:07 PM   #53
dwashy
65
Drives: 2006 E90 330i
Thumbs up
Thanks, I had a download still going through the MEGA desktop client. Appreciate it
N52 | +1mm MILVs | Catless | 3-Stage IM | BPC Tune | 3.64 diff | AirLift Performance 3H | M3 Control Arms | SPL Parts BumpSteer Correction | UUC Evo 3 Shifter | CCV Delete | Valeo SMF Flywheel | CSF Aluminum Rad | VAC Front Hub Extenders | BMS Cowl Filter Delete
      03-23-2020, 07:08 PM   #54
J0K3R5
J0K3R5's Avatar
Vatican City State
406
Drives: BMW
Im busy uploading at the moment to another mega account, what where you downloading ?
new link: https://mega.nz/#F!0l5XkCja!hhmwooDMxmL52IOw8P9ZDg
      03-24-2020, 08:49 PM   #55
dwashy
65
I was going folder by folder, looks like I didn't finish the Software one.
      03-24-2020, 08:56 PM   #56
Johnkwick
24
Drives: F10 LCI
Thanks for the link but I got a little bit confused here.
Which ISTA version that you have uploaded? ISTA-D/Rheingold, or ISTA-P? All I can see is ISTA 4.22.x and I'm not sure which version is that.
Anyway, thanks for the monumental effort to upload all these things. Kudos to you, sir
      03-25-2020, 12:25 PM   #57
nagaraj.veeraiya
Drives: BMW
Hi,
The link which you have posted in one drive doesn't work. Can you please check and provide me the new link? Mega link works fine!!!
Thank you
      03-25-2020, 07:56 PM   #58
J0K3R5
J0K3R5's Avatar
Vatican City State
406
Drives: BMW
ISTA_v4.22.22.19912
PSdZData v4.20.20
SDP_4.22.25
BLP_4.22.25
SQL 4.22.20
Rheingold 4.15.16 will be finished uploading later today - Meant to be stable for E/F models
Next upload will be Rheingold 4.19.15 - Meant to be stable for E/F models
Im slowly working through the list
6ixSpd6015.50
      03-29-2020, 12:05 PM   #59
J0K3R5
J0K3R5's Avatar
Vatican City State
406
Drives: BMW
All software has been uploaded and even more added.
      03-29-2020, 10:56 PM   #60
Johnkwick
24
Drives: F10 LCI
ISTA_v4.22.22.19912
PSdZData v4.20.20
SDP_4.22.25
BLP_4.22.25
SQL 4.22.20
Hi, thanks for the explanation. Looks like I really need to have a dedicated laptop just for this considering the Rheingold and Esys will take a lot of my SSD's space.
As for E-sys it self, I've seen lot of files that have similar name. I'm not sure which one I have to download for myself? Are there any other files required?
I apologize for asking tons of question because I'm new to this coding stuff.
Thank you
      04-02-2020, 04:47 AM   #61
J0K3R5
J0K3R5's Avatar
Vatican City State
406
Drives: BMW
ISTA-P 3.67.0 + 3.67.1 / PSDZDATA FULL V.4.22.31 / ISTA 4.22.32 / DATEN FILES V.67.1 all added to account
6ixSpd6015.50
      04-04-2020, 11:07 AM   #62
pjm21
Drives: E90 330d M Sport Auto
I don't suppose anyone can shed some light on how to download it on to a hard drive?
I've done a MEGA account but just want to save it in case it's lost
Cheers
      04-04-2020, 11:30 AM   #63
ctuna
Download the mega app setup a Mega Folder on your PC.
      04-04-2020, 12:15 PM   #64
pjm21
Legend, download in progress!
      04-04-2020, 12:49 PM   #65
J0K3R5
J0K3R5's Avatar
Vatican City State
406
Drives: BMW
Ive been requested to get hold of Rheingold 4.10.
Im busy downloading the torrent as Im posting this, hopefully it will be uploaded onto mega in the next day or 2
Ive also got DPF EGR 2016 V3.0 if its any use.
Just that its not shared at the moment, just ask if you want it
      04-09-2020, 02:53 AM   #66
teeRecks
Drives: BMW E92 335i
Thank you - this is awesome! So much so that I made an account here just to come tell you how awesome you are.
