Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Instrument Cluster - MPG, Gas Gauge, Tach do not work
      09-16-2011, 05:13 PM   #1
HomeBrew
Drives: 2017 BMW M3
2017 BMW M3  [0.00]
2006 BMW 330i  [0.00]
The tach, gas gauge and mpg gauge all work for about 3 seconds, then fall to their resting positions (0 - empty, 0 rpms, 99 mpg).
Any coding has been undone. No errors were reported during coding.
Anyone have any ideas what would cause this?
2017 BMW M3 - Tanzanite Blue with Full Silverstone Interior
      09-16-2011, 05:21 PM   #2
onebadmofo
onebadmofo's Avatar
346
Drives: 2008 E90 M3
Daten files are too old.
      09-16-2011, 05:39 PM   #3
Elliott@DetailAddict
Drives: E90
Not to come across harsh but have you searched? This is the most common error people come across and has been highly documented. I'm sure even searching "malfunction" in the coding section will show a bunch of threads.
      09-16-2011, 05:51 PM   #4
HomeBrew
Drives: 2017 BMW M3
2017 BMW M3  [0.00]
Yep, did search.
      09-16-2011, 05:52 PM   #5
HomeBrew
Drives: 2017 BMW M3
2017 BMW M3  [0.00]
Searched again (less specific terms).
are ISTA V2.41 still the latest files?
      09-16-2011, 05:53 PM   #6
Drives: E90
Searching malfunction yielded these 3 out of a small number of threads. (One of them is almost the same exact title as yours)
Very detailed responses are in each thread. Happy coding.
http://www.e90post.com/forums/showth...ht=malfunction
      09-16-2011, 05:54 PM   #7
Drives: E90
42 is out but you should be golden with anything from 40 up
      09-16-2011, 06:13 PM   #8
HomeBrew
Drives: 2017 BMW M3
2017 BMW M3  [0.00]
First time this happened, it was at a dealer, with the dealer coding the car.
So I (mistakenly) assumed that it was something serious...
      09-16-2011, 06:14 PM   #9
HomeBrew
Drives: 2017 BMW M3
2017 BMW M3  [0.00]
If it is so common, which apparently it is, why isn't it a sticky?
      09-16-2011, 07:03 PM   #10
Drives: E90
It happened with a dealer?! Crazy.
There's no sticky because Mods aren't as active in here or I would make a few stickies myself. Just because somethings common with coding doesnt mean there will be a sticky in here lol. This here is no mans land
      09-16-2011, 07:13 PM   #11
DESI4life10
DESI4life10's Avatar
201
Drives: Coding: Desi4life10@gmail.com
+1
      09-16-2011, 07:41 PM   #12
HomeBrew
Drives: 2017 BMW M3
2017 BMW M3  [0.00]
Yep, as I was leaving noticed the cluster issues.
OK, so...
Copied and replaced the files in the folders from 2.42. But now, I get the wonderful 'VIN is faulty' error.
I know this cable works (unless it broke in the last hour)... so what's going on? (although I never disconnected pin 8, found that by searching )
      09-16-2011, 09:11 PM   #13
._.
74
Drives: BMW
did you make a backup of your files before updating them, so you can restore them and try again? did you follow the instructions on how to update the files correctly? many have done it without issue so it's clearly a user related issue.
Hopefully you can restore your files and attempt to update them again. BTW, I had the same problem, I searched, found the solution and applied with no issues at all. Maybe you can find someone in your area that knows what they are doing to fix it for you?
BTW, what was the dealer doing in the KOMBI module?
      09-16-2011, 09:58 PM   #14
HomeBrew
Drives: 2017 BMW M3
2017 BMW M3  [0.00]
Yes, I have a backup and have tried again, still same the same issue w/ the cluster.
Is there a write up somewhere on how to update 'correctly'? Is it more than just copy / replace?
I know what I'm doing, I've coded this car many times, this is the first issue. Just haven't needed to update the files before.
Any help on updating the files is appreciated.
Thanks.
      09-17-2011, 06:51 AM   #15
HomeBrew
Drives: 2017 BMW M3
2017 BMW M3  [0.00]
Wire-up?
From another post:
Originally Posted by jyono
Update:
Solved my issue using ISTA v41 Daten Files.
1. Copied and pasted new daten files to [ C:\NCSEXPER\DATEN\E89 ] and ran laden.bat
2. Copied and pasted new sgdat files to [ C:\NCSEXPER\SGDAT ]
3. Copied and pasted new ecu files to [ C:\EDIABAS\Ecu ]
This time NCSexpert worked fine, no "Faulty Chassis" message!
Re-coded with a blank .MAN file and functionality my the analog gauges (rpm/mpg/fuel) were restored!
this one doesn't mention a laden.bat:
This guide was originally posted by FAL, I just redid the images and created the entry in this wiki!
To update your system properly it is highly recommented that you use the tool Total Commander. There is a 30 days trial available.
If you copy the files manually - without Total commander - you might overwrite newer files with old ones. That's the difference between updating and doing it properly...
What you need checklist:
Total Commander
v40/v41/newer/older ISTA/P files, includes
daten - folder
ecu - folder
sgdat - folder
common sense and basic knowledge in computers
Difficulty: easy
Make a copy of your EDIABAS, EC-APPS and NCSEXPER folders. It's always good to keep some backups...
Start Total Commander
In the left window of Total Commander, head for your new daten-folder. In the right window, move to C:\NCSEXPER\DATEN\E89 (or another model you want to update). Now your screen should look like this:
Click on 'Mark' > 'Mark newer, hide same files'
As you can see on the following pictures, the newer files on the left will turn red. Drag one of these red files to the right windows and drop it there.
A windows will come up, just confirm it with 'OK'
Another window will pop up, now comes the clue: Here, select 'Overwrite all older'. All newer files will now replace the old ones, while equal versions or even newer files stay untouched.
Bibidi, babidi, boo - else updating is poo
Repeat this with the following folders:
C:\EDIABAS\ECU
C:\NCSEXPER\SGDAT
I'm not sure which is correct...
      09-17-2011, 09:53 AM   #16
HomeBrew
Drives: 2017 BMW M3
2017 BMW M3  [0.00]
Ok, followed the second quote from above (using tool commander).
Worked perfect. Simply re-coded the cluster and all is well.
Thanks for the help!
      09-17-2011, 10:16 PM   #17
Peertwelve
Peertwelve's Avatar
781
Drives: Silverstone E92 M3
2008 BMW M3  [3.00]
Second one worked for me
From another post:
Thanks all for the help
2008 SSII E92 M3 | LCI CIC, Apps, Tails| MPE | BBS Ch-R
1990 325i
Sold- 2011 335i Sedan | 6MT | Wavetrac | Eibach Pro | CDV delete | Cobb | BSW
Sudden death - 1970 BMW 2002
      12-02-2011, 06:11 PM   #18
Drives: E90
Thanks for the sticky mods
      12-05-2011, 09:56 AM   #19
HomeBrew
Drives: 2017 BMW M3
2017 BMW M3  [0.00]
Nice!
Thanks for the sticky!
      08-16-2012, 08:01 AM   #20
FlashMonkey929
I Shoot People For Money
FlashMonkey929's Avatar
1024
Drives: 2023 Portimao MSport X1
2003 BMW 330i ZHP  [0.00]
2023 BMW X1  [10.00]
I'm hoping one of you can help me, I've tried and tried but I can't get this damn error to go away. I've googled, searched, prayed, and no matter which thread I reference I still can't get my cluster to function normally.
I'm running Ediabas v6.4.7, though I have downloaded 7.0.x. I'm on a Netbook running Windows XP 32 bit, and I'm running v46 of the daten files, and when I do a check the in INPA, the Kombi module checks out okay but the error still remains on the cluster.
I originally coded the car using the files in the sticky DIY above, first the FRM module for the roll up windows with FOB and LED Corner delete. I then moved on to the Kombi to do the digital speedo and that's when I got the error.
The RED "car on lift" icon popped up and checking the code, it is CC-ID 60 (Speedometer failure). The tach, fuel, and temp gauges do not work.
I then did more research and figured I had outdated daten files and proceded to update via the many threads. I'm hesitant to update EDIABAS because I've read there may be compatibility problems with NCS Expert. I've reflashed it back to the original settings via Expert Mode in NCS and this still won't go away.
Someone please help me! Am I missing something?
      08-16-2012, 11:22 PM   #21
neilvosko
neilvosko's Avatar
Drives: 335i e92 FBO
You have to copy all the files from the files into appropriate directory including ediabias and bin
      08-17-2012, 12:54 AM   #22
FlashMonkey929
1024
2023 BMW X1  [10.00]
I've done that already, any other possibilities?
2008 335i Alpine White Coupe -sold-
2011 335i Alpine White Sedan PPK -sold-
2020 430i Estoril Coupe MSport -returned-
2023 X1 Portimao, Msport, Premium
2003 330i Imola Red ZHP 6 Speed
