Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > For Help with NCSExpert Errors
      03-07-2012, 06:45 PM   #23
Elliott@DetailAddict
Drives: E90
Without personally seeing your files, it seems to me youre having the same issue that people do and end up switching between their old files and new files to access the NFRM.
I'm not quite sure what they do incorrectly and my recommendation would be to start fresh and re-update the new installation following directions in the forum to the "T".
      03-08-2012, 03:25 AM   #24
Sabor
22
Drives: 09' e93 335i
I have error in babg module. Was trying to code my seatbelt chime and had a faulty coding. It then gave me a airbag warning. I cant get through this. Please help. On v42 daten.
Here is the error code:
ERROR! Modul: A_PL2MRS.IPS, Proc: Cod, LineNr: 107, ErrorNr: 2060
COAPI-2060: coding faulty (general)
ACSM2, C_C_AUFTRAG: ERROR_VERIFY
This is the popup box i receive:
Error in CABD! Look at Cabi.err and Error.log!
      03-09-2012, 12:27 AM   #25
dluke
Sh!t happens... Deal with it
dluke's Avatar
Drives: '06 Alpine 330i
'06 BMW 330i  [0.00]
hey Grant ive already successfully coded the windows and mirror w/ fob and digital speed but im getting a faulty coding error when trying to delete the legal disclaimer. when i add the 'nicht_' in front of 'aktiv' for the LEGAL_DISCL and try to write it to the car it throws me the error about 30 sec. after executing the job, but then if i change it back to just 'aktiv' and write it to the car it finishes error free. (attached is the log for the error).
Thank you for any advice you have
      04-05-2012, 12:40 AM   #26
martinlag
Drives: E91 M-Sport and F30 M-Sport
Hey Grant, I skipped the airbag test and went to NCS directly...
When I try to get it to read my VIN, all I get is:
ERROR! Modul: CDHINT.CPP, Proc: CDHIntSetScriptFile, LineNr: 02, ErrorNr: 1060
COAPI-1060: error in coding discription file
A_E65CAS
>> ERROR! Modul: COAPI2.CPP, Proc: coapiRunCabd, LineNr: 02, ErrorNr: 1000
A_E65CAS
>> ERROR! Modul: COAPI.CPP, Proc: coapiReadFgNr, LineNr: 04, ErrorNr: 1000
FGNR_LESEN: A_E65CAS
Thanks in advance for your help man!
      05-01-2012, 07:29 PM   #27
Snyperx
Drives: 2006 325i (SOLD)
2006 BMW 325i  [0.00]
So I have been having an issue being able to read modules other than FRM with NCSexpert. In the log this is what I am seeing:
ERROR! Modul: SW_ARRAY.C, ProcNr: 07, LineNr: 01, ErrorNr: 43.
>> ERROR! Modul: LFCDHDIA.CPP (A_E65.IPS/IPO), Proc: CDHapiResultText, LineNr: 01, ErrorNr: 2000
BIP-0009: BEST VERSION ERROR
>> ERROR! Modul: COAPI2.CPP, Proc: coapiRunCabd, LineNr: 06, ErrorNr: 2000
CODIERDATEN_LESEN
Any ideas? I recently updated to the v45 daten files.
Regards,
SnyperX
      05-02-2012, 11:07 AM   #28
icucCoding
Drives: X5, ALL4S
This is a version mismatch issue and follow the daten update procedure to update the Daten files.
      05-02-2012, 02:24 PM   #29
Tyetiger
32
Drives: 07 335xi MperorTuning Stage 2
Hi Guys,
I did the airbag test and that worked with out an issue. I was able to save and load the a profile in NCS, but after i load the profile, choose the chassis e89 for my e90, My Chassis shows (E89), My VIN shows up in FG, but the FA is blank an i get a pop error. Im not sure what i may have missed. This is what i have in my error log:
ERROR! Modul: AT_PROC.C, ProcNr: 31, LineNr: 01, ErrorNr: 114.
Mark Not Valid: $6FL
ERROR! Modul: COAPI4.CPP, Proc: coapiSetAuftrag, LineNr: 03, ErrorNr: 1180
COAPI-1180: Fahrzeugauftrag ist ungueltig
      05-02-2012, 02:26 PM   #30
Drives: E90
Did you edit your VO to add $6FL? It's hitting an error on that?
What version daten files? Did you update them correctly?
Also if you're tuned make sure to turn it off.
      05-02-2012, 03:38 PM   #31
Tyetiger
32
i verified that i Currently have the latest version 46.1 that got from http://www.e90post.com/forums/showthread.php?t=634863.
Tune is turned off.
Where would i edit my VO? I dont think ive done that.
      05-02-2012, 03:57 PM   #32
Drives: E90
Does your car have 6FL? The Y-cable for ipod in your armrest?
It's not liking something about that.
      05-02-2012, 04:06 PM   #33
Tyetiger
32
I do have a usb cord plugged in it is not connected to anything.
      05-02-2012, 05:46 PM   #34
Tyetiger
32
I did check the VO and it does have $6fl there. The usb port is stock so I haven't made any changes.
      05-09-2012, 09:00 PM   #35
Mark_h
Drives: BSM e90
Getting these errors only when trying to connect to BrianMN's 08, everything works fine on my 07. (DATEN files are updated to V45/46.1)
Mark Not Valid: +MUS2
COAPI-1180: vehicle order is invalid
      05-30-2012, 12:43 PM   #36
Giovanni3808
Drives: 320D E91 06/06
Please do NOT just post the error dialogue that pops up at the time of the error.
For example, posting JUST this WILL NOT HELP:
Click OK on that error, and the go to VIEW and the ERROR LOG:
Post what is in there for answers.
As you can see from my example, the error log shows me that when editing my WL_NSW line in the NFRM, I entered in an incompatible value.
Cheers
Hello!
Please can you help me?
I would like to change something in my DSC SG. Changes in CAPPL or FRM or others are OK. Error always comes from NCSExpert when i try to read from DSC, EGS, PDC SG.
The Error Log is below
error.log
ERROR! Modul: LFCDHDIA.CPP (A_PL2DSC.IPS/IPO), Proc:
CDHapiResultText, LineNr: 01, ErrorNr: 2020
COAPI-2020: SG antwortet nicht
IFH-0009: SG nicht angeschlossen oder meldet sich nicht
ErrorNr: 2020
CODIERINDEX_LESEN
ErrorNr: 2020
CODIERINDEX_LESEN
Can you tell me what is wrong?
Sorry for my bad english! ;-)
Thanks, a Guy from Austria called Hannes
      05-30-2012, 02:01 PM   #37
Drives: E90
Make sure you've updated the SGDAT folder when upgrading your daten. See if that helps.
Also make sure that you are running an updated EDIABAS as well.
Mark_h, make sure you have also correctly updated your files and are on a newer version of EDIABAS
      05-31-2012, 02:20 AM   #38
clara_zz
Drives: BMW 320 E90
Hi Grant,
I edited my VO to add $6FL,when I chose the chassis E89 for my E90,my VIN showed up in FG,but the FA was blank and I got a pop error.I`m not sure where the problem is.Here is my error log:Name:  1-vert.jpg
      05-31-2012, 12:31 PM   #39
Drives: E90
Have you properly updated daten and ediabas? lol I know I keep saying that, but it isn't recognizing -OSNU in your VO and is giving you an error.
Proper update is one main thing to try.
      05-31-2012, 10:48 PM   #40
clara_zz
Drives: BMW 320 E90
Thanks to you advise,I have updated daten and ediabas.The FA problem is solved,and there comes another error when I try to written $6FL into NFRM.
      07-03-2012, 09:58 PM   #41
DUI Elite
///M at Heart
DUI Elite's Avatar
90
Drives: 06 SGM E90, 15 BSM E84
Did halogen to xenon conversion but still get an error. Just to make sure, What values do i change after adding $522 to the vehicle order?
CAS and FRM both show together having 0522, so its not a discrepancy between the modules
      07-04-2012, 01:27 PM   #42
Drives: E90
Did you process the car in expert mode after updating the VO?
      07-14-2012, 11:25 AM   #43
cn555ic
cn555ic's Avatar
Drives: 335i
Anyone that get this error, make sure you guys empty your man.file before you code another car...Just a friendly reminder for all you coders out there!
      07-14-2012, 11:33 AM   #44
DUI Elite
///M at Heart
DUI Elite's Avatar
90
yeah. thats the only way I've ever done it.
it won't let me change these values (to the ones I put under them)
blinkimpuls_warnblk
wert_03
blinkimpuls_crashblk
wert_03
pwm_anst_fl_bixenon
wert_01
wert_01
auto_lwr_enable
nicht_aktiv
