Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > OEM 359M 9J Square-setup on E90/E91?
      02-21-2024, 07:55 AM   #1
braziers
Drives: 2015 F22 M235i, 2012 E91 335i
Is anyone running, or has run, the above square-setup (OEM 359M wheels, 19x9J +31 front and rear) on an E90 or E91?
Thinking of going down this route for my E91, rather than trying to squeeze the staggered setup (with the 10J rear) on the car and having to do arch mods or rolling to make it work.
Was thinking the square-setup in 9J could work, with either a 225/35 or 235/35 up front, and a 255/30 or 265/30 in the rear.
      02-22-2024, 04:25 PM   #2
vester86
92
Drives: BMW 330D '08
why would you go staggered tyres on square rims? i know that it is possible but why would you?
      02-22-2024, 07:36 PM   #3
mattanderson
192
Drives: 2007 E92 328i
With some negative camber, 245 or 255 shouldn't be a problem up front. That offset is perfect for a little front camber.
      02-22-2024, 09:29 PM   #4
M-technik-3
Drives: E30 M3, E36 M3, 328iT, 335i
1995 M3  [9.00]
2007 E91  [7.25]
1988 M3  [9.50]
https://www.e90post.com/forums/showthread.php?t=1516086
the op mounted 359Ms
      02-23-2024, 02:38 AM   #5
braziers
Maximise tyre width on the rear, while keeping the front tyres in check without rubbing up front.
      02-26-2024, 11:55 AM   #6
braziers
Originally Posted by M-technik-3 View Post
10 years ago I would have been all over this , but I'm not sure about the coilover and stretched route these days.
225 on a 9j is within ETRTO limits, but 255 on a 10j is not, so I wouldn't want to go down the stretched out of spec route.
Having said that, it does look damn good.
