Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > All E90 OEM Wheels (images and specifications)
      02-08-2022, 12:54 PM   #287
doomfull
Drives: 2006 325i
thank you
      05-30-2022, 11:55 AM   #288
NorthernDancer
850
Drives: 08 Sedona 128 & 06 330xiT 6MT
Joining the E9x group, in 10 days
Do I have this right, 162 wheels?
18 inch, staggered, 335 sport pkg, OE BMW
16 & 17 inch 162s are replicas only
      03-23-2023, 04:14 PM   #289
racerbruce
racerbruce's Avatar
3854
Drives: 21 X3 & 13 335is E93
Style 313's
Love my Style 313 18 in rims....
Name:  Red Rocket Garage Pic 1.jpg
Racerbruce
Appreciate 4
POBEP367.00
tcphoto3537.00
      03-23-2023, 04:20 PM   #290
racerbruce
racerbruce's Avatar
3854
For the Style 313 rim owners....I've seen posts and pics of the 19 in rims severely cracking; it's apparently related to run flat tires as their sidewalls are intensely rigid that it is causing rim cracking when making contact with potholes, etc....is this true??
Racerbruce
      03-23-2023, 05:37 PM   #291
racerbruce
racerbruce's Avatar
3854
Anyone powder coated their BMW OEM rims?? Cost?? Durability??
Racerbruce
      03-23-2023, 09:15 PM   #292
GnomeChild
IN54NE
GnomeChild's Avatar
324
Drives: e90 335i LCI M-Sport
2010 BMW 335i  [0.00]
I found a local place that does refinishing for wheels at $150 a pop. I've seen their work firsthand and they use OEM grade paints/shades so the wheels come out nice. I have a spare set of rough 193s sitting on the side of the house I've been meaning to refinish so it would be $600 for the set. Basically the cost of a whole extra set of 193s but this way they come out minty fresh and ready for more curbrash
Tl;dr it depends, call around. You should have a local place that does wheel refinishing. My place is about 20 mins away from my house
racerbruce3853.50
      03-24-2023, 01:28 AM   #293
POBEP
POBEP's Avatar
Drives: E70 E90 E91
My guess that most 19"'s with such a low sidewall are prone to cracks.
I bought a set 313 18" with a non-air-leaking hair crack.
Local shop has done a great weld and pain job - it hold up against BayArea minefield well.
racerbruce3853.50
      03-24-2023, 08:50 AM   #294
tcphoto
tcphoto's Avatar
Drives: E92 335i 6MT Coupe
I want so badly to replace my 189's with either 225's or 269's but the roads in Nashville are a mess. I like a little more sidewall and went with 235/40/18 and 265/35/18 PS4S' but I'm not sure that this strategy would work with those 19" wheels. Those 18" 313's would look great and I could transfer the tires but I haven't seen much in the used market.
racerbruce3853.50
      03-24-2023, 06:42 PM   #295
POBEP
POBEP's Avatar
Drives: E70 E90 E91
tcphoto are you running PS4S 235/40/18 and 265/35/18 on stock 189's? I am thinking about same tire size.
Everything I read was that rear sock 8.5 rim is "too narrow" for 265/35/18.
How's it is working out for you? can you post a picture?
My E90 sit on B8's - a bit low for my taste (this is what I got as 4th owner).
I wonder if I'll get any rubbing with 265/35/18
Previous owner had 235/40/18 in the rear with spacer - it was rubbing against fender on some turns. I since then switched (rears) to stock 255/35/18 PS4AS, no spacer, no rubbing.
      03-25-2023, 07:07 AM   #296
tcphoto
tcphoto's Avatar
Yes, 235/40/18 and 265/35/18 and it's worked for the past five years.
      08-01-2023, 07:31 AM   #297
BMW Team Casi
BMW Team Casi
Drives: BMW 328 Ci
Thanks for posting those pics. Really helpful.
      08-01-2023, 07:34 AM   #298
BMW Team Casi
BMW Team Casi
Drives: BMW 328 Ci
I have a 19 in set and they have all either cracked or warped.
      08-01-2023, 07:37 AM   #299
BMW Team Casi
BMW Team Casi
Drives: BMW 328 Ci
I live in the Toronto, Canada area and my 19 in set have all either cracked or bent. The ride is extremely harsh. I am now looking at replacing the set with 18 in but wow does it change the look. I wish I had gone with the 18 in from the beginning.
      10-15-2023, 09:26 AM   #300
BK - BMW
Drives: 2010 BMW 335d
2010 BMW 128i  [0.00]
Thumbs up Wheel Chart
Outstanding information. This makes it easy for size comparisons. Thank you for posting this.
      12-02-2023, 08:31 AM   #301
jwrag2000
Drives: Bmw 330d e93
I've just fitted 245/45 r18 on the rear of my 07 330d e93. It should actually run a 255/35 r18 which is 1.7 inches less in diameter. My reason for doing this is to improve ride quality by increasing the side wall height. I've also noticed that in one way it does actually make the car appeared lowered if you look at the wheel well - the tyres fill up the space more, despite there being 0.85 of an inch more ground clearance. My question is are there any down sides? No rubbing so far....
