2Addicts
2Addicts
2Addicts | BMW 2-Series forum Classifieds Commercial Classifieds Suspension / Brakes / Chassis / Spacers Ferodo DS2500 Hybrid and DS1.11 Race Pad For Your F2X with sport calipers
      12-29-2022, 01:58 PM   #67
HP Autosport
Supreme Allied Commander
Drives: F80 M3
bump
      02-15-2023, 01:44 PM   #68
HP Autosport
Drives: F80 M3
Available now BMW F2x 2-series M235i M240i
DS2500
The DS2500 is currently the best hybrid track/street pad on the market. It features the moderately high bite and solid fade resistance of a track pad, with the relatively low dust and noise levels of a street pad. When used as a street pad, it can produce some squeal on certain vehicle platforms. During aggressive driving the DS2500 is known for its flat torque curve, which means as temperatures go up, the response through the brake pedal remains consistent. If you drive aggressively on the street, do some canyon runs, autoX, and maybe some light track duty on street tires, the DS2500 is tough to beat.
DS1.11
The DS1.11 is one of Ferodo Racing's latest endurance race pad offerings. It has slightly less bite at high temps. vs their older DS3000, but doesn't decompose nearly as quickly under extended heavy use on the track. The DS1.11 is known for its extremely flat torque curve, which means that as temperatures go up, the response through the brake pedal remains consistent. The DS1.11 can be thrashed all day without having it burn up or fade, it's easy on discs, and doesn't have many of the judder or vibration issues that competing products have. If you want an extremely solid, all around race pad that will perform well and last a long time, the DS1.11 is the perfect choice.
When used on fast, heavy cars on the track with race tires, pad wear rates tend to be higher than some of the full track pad compounds. Under those conditions, HPA would recommend the Ferodo DS1.11.
https://hpautosport.com/product/fero...-11-race-pads/
      04-13-2023, 06:29 PM   #69
HP Autosport
Drives: F80 M3
bump
      06-25-2023, 09:08 PM   #70
HP Autosport
Drives: F80 M3
bump
      07-10-2023, 01:48 PM   #71
HP Autosport
Drives: F80 M3
Bump
      08-15-2023, 12:07 PM   #72
HP Autosport
Drives: F80 M3
bump
      09-05-2023, 03:29 PM   #73
HP Autosport
Drives: F80 M3
Something else you should consider while upgrading to track pads:
https://hpautosport.com/product/para...blue-calipers/
      09-07-2023, 02:07 PM   #74
HP Autosport
Drives: F80 M3
Something worth doing while upgrading to track pads. Titanium brake pad shims:
      09-27-2023, 12:18 PM   #75
HP Autosport
Drives: F80 M3
bump
      11-15-2023, 01:04 PM   #76
HP Autosport
Drives: F80 M3
DS2500
DS1.11
      01-24-2024, 03:16 PM   #77
HP Autosport
Drives: F80 M3
bump
      03-28-2024, 05:51 PM   #78
HP Autosport
Drives: F80 M3
bump
2addicts
