10-31-2014, 04:26 PM | #7525 |
General
10445
Rep 40,769
PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 10-31-2014 at 04:38 PM.. |
11-01-2014, 08:53 AM | #7526 | |
Rep 13
Thank for help me. I take a look on FA of my car, have this: 1CA,1CB,216,230,249,258,2A6,2PA,2XE,320,420,423,42 8,431,481,4AD,4AE,4DL,502,507,520,521,522,544,548, 5AC,606,698,6AC,6AE,6NS,6S3,6VB,7AC,889,8KA,8S3,8S M,8V1 As you can see, the car have 5AC but not 552 (have 522!). I search for 522 and found this in another topic: - "High beam assist (5AC), adaptive xenon headlights (522 / 524) are all standard on Canadian F30 / 335's" Ok, so my car really have 5AC (factory) and the 522 (factory) should be the "adaptive xenon headlights" It's a lot of terms to light: - 522 = Adaptive Xenon Headlights - 5AC = High Beam Assist - ??? = Active High Beam Assistant - ??? = Variable Light Distribution So the the last two of this list are something different of my car have? |
11-01-2014, 12:39 PM | #7527 | |
Rep 1,892
I don't see any specific enable codes for VLD or no-dazzle high beams. As far as I can see, you have everything you need to have these enabled. |
11-01-2014, 01:46 PM | #7528 |
Rep 13
11-02-2014, 12:40 PM | #7530 |
General
10445
Rep 40,769
PM sent.
11-02-2014, 01:35 PM | #7532 |
General
10445
Rep 40,769
PM sent.
11-02-2014, 05:40 PM | #7533 |
Rep 1
Hi. I currently have a 2014 F30. I have esys 3.23.4 and my token is more than a year old and has expired. Can you point me to where I can purchase a new one? My car is still at F020-13-07-503 which is what it was when I coded it last year. I assume that I don't have to change my esys or data versions? Thanks in advance!
11-02-2014, 08:02 PM | #7534 | |
General
10445
Rep 40,769
PM sent.
11-03-2014, 11:36 AM | #7535 |
Rep 19
Hi, i have the base audio in Europe and i just upgrade de spreakers and add front tweeters, i want the equalizer in the display so i have to code the FA and add the 676 option, does anyone know what more a i have to code?
Thanks |
11-03-2014, 02:48 PM | #7536 |
Rep 532
I tried to find on google, but could not find a answer for sure...
but is it possible if i normal lock the car ( with a single click on the key fold ) or with a single touch on the comfort key ( ribble ) to automatic lock the windows and sunroof ? ( code it ) or do i always have to push 2-3 seconds for it ? thanks and greets from Holland Kriszty |
11-03-2014, 06:45 PM | #7537 |
General
10445
Rep 40,769
There will always be some delay, and a need to hold the button but you can minimize it by coding FEM_BODY => KOMFORT_SCHLIESSEN => Werte=00.
11-04-2014, 02:34 AM | #7538 |
Rep 19
Yesterday i try to change the konfortclima to the last memory but someting goes wrong the ventilation speed is on don't turn off, i try to load the original CAFD file and code fdl but the ventilation is on.
Please help |
11-04-2014, 03:05 AM | #7539 |
Rep 532
11-04-2014, 04:05 AM | #7540 | |
Rep 122
Drives: F30 320D Sport
Garage List 2006 325iA E90 Sedan [0.00]
1999 320i E46 Sedan [0.00] 1991 318i E36 Sedan [0.00] 2012 320D F30 Sport ... [0.00] |
You can't get an equalizer without adding amplifier connected via MOST bus. |
11-04-2014, 08:22 AM | #7541 |
Rep 19
I think I made a mistake in coding because the ac vent does not turn off, I have the backup files on a usb stick, can you please explain me how to replace the original encoding(step by step please)
The coding is done in the IHKA module. Thanks Last edited by PSILVA; 11-04-2014 at 08:31 AM.. |
11-04-2014, 10:25 AM | #7542 | |
General
10445
Rep 40,769
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Right-Click on IHKA (the ECU itself not the underlying CAFD) => Select CODE.
11-05-2014, 03:43 AM | #7543 |
Rep 32
Hello,
I am owning a 2014 F30 335Xd. Start/stop is getting on my nerve but my dealer in France is not too helpful... I would love starting some coding. Could you please tell me were to get recent PSDZDATA Files, E-SYS and token ? Thanks ! Best regards, Jean-Marc |
11-05-2014, 04:23 AM | #7544 | |
General
10445
Rep 40,769
