Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > 335i brakes on 328i
      10-27-2017, 10:20 AM   #23
feuer
feuer's Avatar
Drives: wife crazy!
Originally Posted by Patrickkim1 View Post
About to do this mod on my e92 328i. With this mod does it improve braking or is it just cosmetic? Also, just to make sure I just need stock rotors,calipers (do I need to buy 335i caliper bracket or can I use my 328i) and pads to complete this? Please lmk
Buy these from Lamumba instead http://www.e90post.com/forums/showthread.php?t=1426009
      10-27-2017, 11:54 AM   #24
david in germany
Drives: 118i, 335i and 328i
Vast improvement over stock. You do need the 335i bracket, caliper rotors, trim the rear shield. The original lines will work as well. You will most likely need coding tough.
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit.
2011 328i Titan Silver M Sport "Franzel" <--Wife's car
E90Dom0.00
      10-31-2017, 12:28 AM   #25
Yassssm4
13
Drives: bmw
Hey david, You need to code to get the brakes to work?
      10-31-2017, 10:02 AM   #26
david in germany
Yes, some people say that you don't need to but in my expirences, you do.
      10-31-2017, 11:56 AM   #27
The Nightman
Cometh
The Nightman's Avatar
1090
Drives: Boy's Soul
Has anyone done the 335i fronts only? I'm curious how pedal feel, brake bias, etc are changed.
      10-31-2017, 12:33 PM   #28
david in germany
335i rears will not bolt directly to the 328i so fronts are normally the only ones done.
Without coding the bias is messed up and pedal is soft. With coding the 328 will out brake a 335i every time and has a solid confidant feel.
      10-31-2017, 12:35 PM   #29
david in germany
You guys can check out the retrofit coding discussion in this thread below.
http://www.e90post.com/forums/showthread.php?t=1317220
      07-14-2018, 02:28 PM   #30
putnampunk
putnampunk's Avatar
29
Drives: M3/4/5, E91, LeMons E30
Originally Posted by VTECaddict View Post
This is only a problem with RWD E90 325i/328i and RWD E92 328i. The 330i, E91, E93, and all AWD models all use the larger rear parking brake, so you can direct swap the 335i rear brakes on those cars and still have functional parking brakes without modification.
So for an E91 - just need the calipers and carriers (plus pads of course)?
      07-14-2018, 05:38 PM   #31
feuer
feuer's Avatar
Drives: wife crazy!
Plus rotors of course
      07-14-2018, 06:36 PM   #32
putnampunk
putnampunk's Avatar
29
Haha, true. Anything to be mindful of on brake line length? I'm due for new ones and could order either spec.
      07-14-2018, 08:01 PM   #33
feuer
feuer's Avatar
Drives: wife crazy!
They are all interchangeable.
      02-25-2022, 01:39 PM   #34
Kyle264E90
9
Drives: 2011 BMW 328i E90
So will 335i brakes fit on my 2011 e90 328i X-drive? Including the rears since it is an X-drive? Is this including the pads, rotors, and the sensors? Not the calipers
I have an opportunity to buy a 335i Zimmerman break kit with everything included. (Rotors, pads, sensors) Will this fit?
      02-25-2022, 08:05 PM   #35
eljay
1444
Drives: ///M + E91
Yes.
EDIT:
I just realized that you specifically said everything except the calipers. This discussion is about a complete brake fitment, so especially, calipers.
You need 335i calipers and brackets to fit the larger rotors and pads.
P.S. It's a brake kit. When brakes break, you have a problem and need a break.
      02-25-2022, 09:00 PM   #36
feuer
feuer's Avatar
Drives: wife crazy!
If parking brake us 185mm yes. I’m not sure all e90 xdrive do. It’s been a while. I think for e91 xdrive yes. Just check in realoem with your vin.
      03-08-2022, 10:13 AM   #37
3DIRTY8
9
Drives: E90 LCI
Whoops 😅 I forgot to code my 335 fronts when I did the swap. Gonna have to look into doing this
      03-13-2022, 05:14 PM   #38
edycol
Drives: 2011 328i xDrive
XDrive is 185mm.
      02-06-2024, 04:36 PM   #39
augustus maximus
Drives: e90 06 330XI, e92 07 328XI
My 06 330Xi boasts the same size rotors as the 335i. I'm converting my 07 328Xi to full 335i calipers and rotors, front and rear. It's all plug and play. Everything bolts up and no hand brake problems.
      02-27-2024, 11:48 PM   #40
Tescot808
Drives: 2011 BMW 328i Touring
2011 E91 to 335 Brake swap - Reservoir -Master Cylinder
I have a 2011 US version E91 328i (not xi). Just checked realoem and saw my rear parking brake is in fact 185mm
Have another question about doing this mod... Does the master cylinder need to be upgraded? Are they the same on the 335, is there enough fluid, do the calipers use the same size fluid housing?
      03-06-2024, 02:20 PM   #41
Onizukachan
Great Teacher
Onizukachan's Avatar
1088
Drives: 06 e91 325ix
2006 E91 325ix  [10.00]
2006 Mini r53 JCW  [0.00]
2005 Mini r53  [0.00]
As per the diy and faq on this website about this, same master. Direct swap.
‘06 e91 manual 325ix BarriqueRot
over Terra (one of 1), Nav, Sport, L7
A few OEM+ mods:
MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come…
brake 328i, brake 335i, caliper paint, rotors
