TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X5 Forums > General BMW X5 (E70) and X5M Forum (2006-2013)
      10-24-2020, 11:23 PM   #23
Dawgz
2022 M4 Comp Xdrive
1016
Drives: 2022 M4 Comp Xdrive
Originally Posted by milarsky View Post
Terrific descriptions and great job. I am in NYC and was wondering if I need some help might you be nearby to advise? If you are not comfortable answering I totally get it, no worries.
best,
jeff
Yea just let me know if you run into anything.
      10-29-2020, 12:16 PM   #24
Dave00
Drives: 2013 BMW X5M
Dawgz - First off, I want to give ALL the credit where credit is due and tell you thank you for putting this up and sharing your experience and guidance for this setup and installation. I finally completed mine and copied your setup and cleaned it up a bit by adding Fiberglass heat sleeve to the tubes with heat shrink to seal it all up. I have to admit, you weren't joking that putting the tube over the VC and intake connections was a real PIA and took heating the tube up with a heat gun to soften the rubber and then lots and lots of pressure and pain - LOL. Setup came out nice and even just after a few miles it's already capturing vapors and I was impressed how much oil was in the crossover tube when I first removed the stock piping and I only have 20K miles on my X5M.
Here's some pics of my setup as well:
      10-29-2020, 01:01 PM   #25
Dawgz
2022 M4 Comp Xdrive
1016
You did great!!! Glad it worked out for you, just keep an eye on the can via the dip stick and drain it frequently.
      10-29-2020, 03:52 PM   #26
0-60Motorsports
0-60Motorsports's Avatar
Bahrain
792
Drives: BMW M3 JB 04 Coupe
Nicely done
Current Mods:
2004 E46 M3cs JB/CSL
2010 E70 X5M AW/BLACK
2011 VW Golf R DSG White/Black
IG: @060Motorsports
      11-01-2020, 02:50 PM   #27
Dawgz
2022 M4 Comp Xdrive
1016
Results of just 80~ miles.
      11-01-2020, 02:55 PM   #28
0-60Motorsports
Bahrain
792
Wow thats crazy! Thanks for posting the results.
Current Mods:
IG: @060Motorsports
      11-01-2020, 03:07 PM   #29
Dawgz
2022 M4 Comp Xdrive
1016
Originally Posted by 0-60Motorsports View Post
Wow that's crazy! Thanks for posting the results.
no problem. Its amazing how much gets collected. Imagine though, these vapors coating the valves and head over time....the intercoolers, etc. Everything just gunked over time. So surprised that they went with this design on a direct injected motor.
      11-01-2020, 08:46 PM   #30
Dave00
Yeah, a lot of that looks to be condensation as when I first completed it and drove her around 5 miles I had probably 20cc's of water in the cans. Emptied them and haven't had any since, but they are definitely working as I pulled the passenger side canister tonight after around 60 miles of driving and had a few drops of pure oil and no condensation.
      11-02-2020, 08:58 AM   #31
S.W.G.
Drives: 2009 335i, X5 35I, 2012 X5M
Any reason why the two inlets to the baffle couldn't be teed for one larger canister vs. dual cans? I have a larger Mighty Mouse sitting around here that needs to go in something.
      11-02-2020, 10:44 AM   #32
Dawgz
2022 M4 Comp Xdrive
1016
You could, the stock system does merge at a section.
Just make sure your catch can of choice has appropriate baffles or you won't catch much of the vapors.
      11-02-2020, 01:04 PM   #33
Jax_415
13
Drives: 2013 X5M
The catch cans: http://www.radiumauto.com/Universal-Dual-Catch-Can-P189.aspx
You'll need 10AN fittings for the catch can. I would get two 90 degree bends and two straight connections.
You'll need 6-8ft of 5/8 hose.
As for the engine cover, the piece that goes over the turbos may need to be cut on the right side so it clears the catch can. I don't run the covers anyway.
Can you post links to where to bought all the items for install?
      11-02-2020, 01:50 PM   #34
Dawgz
2022 M4 Comp Xdrive
1016
The link to the cans is already in that post. All you have to do is google the rest of the hoses and fittings via the sizes I posted.
      11-02-2020, 02:16 PM   #35
Dave00
I bought EVERYTHING on Amazon (including the cans) as they were about $20-25 cheaper with Prime shipping!!!
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I needed the 22 and 25mm clamps:
3 of these:
4 of these (come in 2 packs):
4 of these:
This hose is 25 foot so it gives you plenty to work with and spares for the future:
Appreciate 5
      11-24-2020, 04:50 PM   #36
Dawgz
2022 M4 Comp Xdrive
1016
Updated the routing for the bank 1 hoses.
I didn't like how the hose was kinking on the intake and the intercooler.
Used the following:
• 45 degree 5/8 Barb to 10 AN male
• 10 AN female to 5/8 barb
pjfox2336.00
      06-18-2021, 04:22 AM   #37
AdamLee
Drives: E70X5M
Used the following:
Thanks for sharing. In progress of this upgrade.
Dave0037.00
      06-18-2021, 12:53 PM   #38
argento
argento's Avatar
538
Drives: 2013 X5M
Awesome work in this thread, well done!
$0.02 I can imagine why BMW designers didn't add catch cans, imagine REQUIRING weekly (or even monthly) maintenance by owners to empty the cans. Curious, is there a solution in more recent engines or is this something that's a nice to have?
      06-18-2021, 07:25 PM   #39
Dave00
Catch cans are still the go to and especially even more important in newer motors with the DI setups and no valve wash effect. Honestly, after seeing all of the valves on DI setups in various motors and manufacturers, I truly think that catch cans should be installed from the factory to keep those vapors out of the intake. I agree that the normal (don't care about car maintenance or opening the hood) owner will not want to deal with it, but as an enthusiast, I wouldn't mind emptying them once in a while and would prefer the OEM look.
      07-11-2021, 03:21 PM   #40
xqizitm
14
Drives: E70 X5M
This thread helped. Thanks to the originator for creating it. Things I did differently was add push lock connectors but still adding clamps for peace of mind. I've since them pop off on the race track before. Also, I hate putting too much effort into stuffing the 5/8" hose on the VC and return hose. I used 3/4" hose and added a 3/4" to 5/8" connector. Makes life easier.
Link to pics: https://drive.google.com/drive/folde...aj?usp=sharing
pjfox2336.00
      07-12-2021, 01:33 AM   #41
Dawgz
2022 M4 Comp Xdrive
1016
Glad it helped!
      03-27-2022, 05:46 PM   #42
pjfox23
36
Drives: X5 35i, X5M
Awesome parts list, advice, and setup on this thread. Followed it, and below is my setup (I paid 6 extra bucks for the blue and red connectors ... ha). I was even able to get the PCV lines that go lower on the block.
      03-31-2022, 09:28 AM   #43
Dawgz
2022 M4 Comp Xdrive
1016
Very nice!
Came out pretty clean.
pjfox2336.00
      04-13-2024, 12:02 PM   #44
ParmR
Drives: 10, X5M
Hey Dawgs, what’s the reason to connect the 2 pipes from the intake manifolds?
xbimmers
