N55 2BDE limp mode
03-29-2024, 05:31 PM | #1 |
Rep 29
N55 2BDE limp mode
Hey guys, I was doing a pull in my car earlier today and mid 3rd gear pull I got a limp mode/ reduced power notification, the car ended up dying and would not restart. The only code that was present was 2bde Fuel pressure on enabling of injection' pressure too low. That's the first time I've seen that code come up, after trying to reset fuel adaptations and trying to start for a few minutes with no luck, the only real thing I did was let it sit there for a few minutes while my buddy showed up to tow and then it started back up and ran pretty much like normal. That's new to this car, its never just died and wouldn't start before. Now thinking back earlier this week I had one morning that it was bucking and hesitating pretty good a round 10-20% throttle with no real load but hasn't done anything like that since other than completley dying on me today.
Recently though this car has been in the process of being tuned by Wedge, is it possible that the new tunes are putting extra strain on the hpfp and causing it to cut out? When I was trying to start it back up on my mhd app the fuel pressure wasn't doing anything while I was cranking it over. Does anyone have any thoughts on this, had any similar issues with the code or hpfp problems? And is that code even directly linked to the hpfp, i don't want to just throw a pump in it if its not the issue. Also it does have a precision 2.5 bucketed pump, but I have not upgraded the pressure regulator, does anyone know if the in tank pressure regulator works with both systems or just the low pressure one in the tank. Let me know what you guys think, I don't have much to go off of other than that single code as of right now Thanks!! |
03-30-2024, 03:14 PM | #2 |
Rep 707
Do you have any logs to share? What type of fuel are you running, and what boost did the limp mode trigger on? Do you have the older n54 style hpfp or the newer piston style one?
03-31-2024, 12:22 AM | #3 |
Rep 29
I wasn't running a log when this happened, I have previous logs though that I can attach, now I'm starting to question my hpfp and regulator. It's on 91 octane and it was mid pull in third gear, I'd say only about 13-15 psi. And I'm not exactly sure what style pump I have, is there a way to easily identify it? Thinking back I'm not sure if it went into "limp" mode because the car completly shut off, but it did have the reduced power light along with the low fuel pressure code.
I've been trying to research the EKPM3, from what I've read they overheat easily and can shut off, after upgrading the lpfp, but Ive had that pump in my car for a few months now and hasnt had any issue so far but I pulled my seat cover and had the car idling for about 15 minutes and I would say that thing was unusually warm to the touch. Have you heard of issues with these before? I was wanting to try to replicate what it did and catch it in a log but I don't want to do any more damage/ overheat the epkm3 than I already have if that even is part of the problem. Not sure if this would help but if got a startup/idle log from yesterday, few hours after the breakdown, and a log from last week. https://datazap.me/u/sleeper90/log-1...28-29-30-31-32 https://datazap.me/u/sleeper90/50-2?...28-29-30-31-32 |
04-03-2024, 10:12 AM | #4 |
Rep 674
I was troubleshooting a similar issue with 2BDE code before I totaled my car not so long ago.
Never had it shutdown on me or throw a limp because of that though. All it would do would have long cranks on startup but then rail pressure was super healthy so I was doubting that it would be HPFP. I read up a bit and decided to change the fuel pressure regulator but it didn't fix anything. Was there any other codes when it limped? It's odd that it didn't start for a few min but when you let it rest (or cool?) it then worked. Potential cause as you pointed might be overheating electronics? Would the LPFP install request higher current loads making the EKPM3 heat up quickly?
TOTALED | 2011 E90 335i xDrive - BMS Cold Air Intake - ETS Charge Pipe - ETS 7" FMIC - MHD Stage 2+ - GFB DV+ - PE Mod - VRSF Catless Downpipe - xDelete - xHP Stage 3
2015 E84 X1 35i M-Sport |
04-03-2024, 11:18 AM | #5 |
scotthilly
84
Rep 118
Other threads have experienced this and said a new HPFP was the solution. Your aftermarket one may not be syncing up perfectly? Not entirely sure. Good luck though and keep us posted.
04-03-2024, 01:00 PM | #6 | |
Rep 707
With that fueling and boost level, you should be within the capability of either style HPFP (assuming it's in good shape). |
04-03-2024, 09:20 PM | #7 | |
Rep 29
04-03-2024, 09:26 PM | #8 | |
Rep 29
04-04-2024, 03:31 AM | #9 |
28
Rep 72
My car is still in the garage having various parts replaced, but I recently had the LPFP, LPFP regulator/filter and HPFP replaced. Here's the thread:
https://www.e90post.com/forums/showt...highlight=2bde |
04-04-2024, 05:51 AM | #10 | |
Rep 707
04-04-2024, 09:50 AM | #11 |
Rep 707
Here's a thread with some info about the EKP, just replace the "xx" with "oo":
https://www.spxxlstreet.com/threads/...ng.8765/page-2 If you search EKP over there, you'll find a lot of good threads about various ways people cool the stock ones, and some aftermarket upgrade options. |
04-07-2024, 08:19 PM | #12 |
Rep 29
Okay, So I did a little bit of work to the car this week. i installed te ArcTerminator cooling shroud, that thing is a pretty sweet little setup honestly. All i had to to was use the fuse jumper and add it to the fuse box, remove the old cover and snap the new cooling shroud on and that it, there is a definite difference to the touch now, id say the epkm3 is staying cool now. Also i replace the fue pressure regulator and fuel pressure sensor whi;e i was at it. Ive got about 250 miles on the car since then and havent had anymore of the issues i was having before, i do still have a shadow low fuel pressure code but im pretty sure that has come and gone since ive had the car. Anyways, no real difference in fuel pressure but heres another log. Hopefully that solves that issue!!
https://datazap.me/u/sleeper90/55-du...28-29-30-31-32 |
wrevilo28.00 |
