Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Tires rubbing on 335is
      08-02-2012, 10:06 AM   #1
NeweraM2
Drives: 2018 M2 MG
Hey Guys,
I recently replaced the stock RFTs on my 335is with 313 rims. I put on a set of Michelin PSS 235/35/19 in front and 265/30/19 in the back. Now it seems when I reverse and turn sharply on pavement that is not perfectly flat I hear what sounds like wheel rubbing from the wheel well. It seems to be when the wheel is turned completely to the right when I am backing out of a parking spot usually. I haven't seen any sign of rubbing on the outside of the tire.
Has anyone else experienced this with the Michelin Pilot Super Sports?
Thanks
      08-03-2012, 01:50 PM   #2
NeweraM2
Drives: 2018 M2 MG
Bump
Any ideas? Alignment issue?
      08-03-2012, 02:06 PM   #3
LonestarState
Drives: Silver e92
Shouldn't be... I just did the same thing you did, replaced my rft's on my e92 cpe with Michelin PSS's 235/35/19 front and 265/30/19 rear and 0 rubbing. Wheels are AG M359 19x9 +35 front and 19x10 +38 rear. Are you running stock suspension or lowered?
"All bad precedents begin as justifiable measures."
-Julius Cesar
      08-03-2012, 02:07 PM   #4
LonestarState
Drives: Silver e92
Have an idea on what side of the vehicle? What are your offsets?
-Julius Cesar
      08-03-2012, 02:38 PM   #5
remmib
General
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
So it only rubs in the front?
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      08-03-2012, 03:54 PM   #6
bmw325i
Drives: 2006 BMW 325i
It's probably rubbing on the inside fender liner. Look to see if there are any marks.
      08-03-2012, 04:02 PM   #7
#Tee
#Tee's Avatar
557
Drives: yes
Ive been monitoring your advise and responses these past 3 months and im like wow hes good.
You can follow my builds on IG: Tee212
      08-03-2012, 04:30 PM   #8
bmw325i
Thanks! I didn't know I was being watched lol
      08-03-2012, 04:32 PM   #9
#Tee
#Tee's Avatar
557
Drives: yes
haha, it soo cools...youre putting out fires all over the place....keep it up!
      08-03-2012, 06:09 PM   #10
SilverII
Drives: '11 335IS
2011 BMW 335IS  [9.66]
are you running spacers?
      08-03-2012, 10:15 PM   #11
NeweraM2
Drives: 2018 M2 MG
Thanks for the responses guys.
Everything is stock including the suspension. No spacers or any other mods, I just upsized the tires and I had expected no issues because I hadn't heard of any.
I think BMW 325i is right. I cranked the wheel all the way to the left and right and the tire seems really really close to the front fender. It may explain why it only happens when reversing typically, and usually on uneven pavement, and seems to be worse with a passenger in the car.
I am not sure if it is coming from the left or right wheel well or both.
Could it be that the 335is has a little less room in the front of the wheel well because of the extra air flow?
I forgot to mention that I had these same tires mounted on my previous e92 335i without a problem and no rubbing. The only other difference was that they were on style 230 rims instead of style 313.
      08-03-2012, 10:20 PM   #12
#Tee
#Tee's Avatar
557
Drives: yes
its a combo of larger tire diameter on the fronts and as youre in reverse the front squats down a bit. Its probably grazing the vent slits.
      08-03-2012, 10:29 PM   #13
NeweraM2
Drives: 2018 M2 MG
I think you are right StretchNpoke, it is probably rubbing on the vents.
I guess the only thing to do is down size the fronts to 225/35/19 or live with it.
Thanks
      08-03-2012, 11:12 PM   #14
CamelBiscuit
Drives: 11 E92 335i
2011 E92 335i  [10.00]
You could throw some 16 inch Dayton's on there and call it a day.
      08-03-2012, 11:59 PM   #15
VTECaddict
Where'd my VTEC go?
VTECaddict's Avatar
Drives: 06 330i 6MT
I was going to say the vent slats too. If it's only happening occasionally in extreme conditions, I would just live with it. If it was happening every bump then I might be more inclined to do something about it.
If you're bored one day just take the wheel off and look around for marks or melted plastic if you want to figure out exactly where its rubbing.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit
M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear
      08-05-2012, 07:14 PM   #16
Thumperx
Drives: 335I coupe
The PSS have significantly more or a shoulder compared to my previous owned PS2 tires. This applies to front & rear. This is more than likely your rubbing issues
Name: Blanca | 07 E92 | AW-Blk | ZSP | Alcon BBK | M3 Bits | VM RR Links | Koni | UUC Sways | V5 | Dinan CAI | ETS IC | Fge DV | ER CP | Cyba | Raden. Exh | Mod Step | Trunk Drawer | Perf LED Wheel | Illum Dr Sills | IS Shifter | Parrot | Philps D1S | 6000k fog | MTECH RR | CSL Trunk | Aero | Roof Spoiler | PSS on BBS RS-GT 19s
      11-23-2012, 08:13 PM   #17
stupordave
15
Drives: 2011 335is
I have the exact same rubbing on my is...running SS on VMR wheels. Only in reverse with the wheel cranked to the right about 3/4 of the way. The shoulder is hitting the well vents slats right by the bolt, parallel to the hub center. It seems the driver side well is a little tighter than the passenger side. Haven't fixed it yet but I'll likely try disassemble and pull in the vents a bit at this spot for more clearance.
      11-24-2012, 04:24 PM   #18
Erockdaface234
Erockdaface234's Avatar
Drives: 2016 340 AW/IR Msport
2011 335is  [10.00]
2011 335is  [10.00]
2011 335is  [9.00]
I run same set up on my IS on 19in 313s and have no rubbing issues whatsoever.
      01-14-2013, 09:01 PM   #19
Hootsama
Hootsama's Avatar
Drives: 2011 335is
Nervous about doing this set up now. Should I go 225 up front and 265 rear on 19" 313s to avoid possible issues? Thx.
      01-15-2013, 01:20 PM   #20
Mavus
Mavus's Avatar
2030
Drives: E90 335i, F80 zcp
Originally Posted by Newera335is View Post
Hey Guys,
Thanks
Without any alignment details it is hard to tell honestly what is going on. You shouldn't have any issues if the rim offsets are correct. I would check alignment and max out camber up front, although stock arms won't give you much.
I run 255 square for track without issues but have negative camber.
      01-16-2013, 07:26 PM   #21
guru_method
Eating M3s for breakfast
guru_method's Avatar
46
Drives: AW 09 135i M
I had the vent slit issue and resolved it by using a black(so you can't see it) zip tie to pull the liner forward a bit.
      01-16-2013, 07:38 PM   #22
BQTuning
Drives: 2012 Z4 sDrive35i M Sport 6MT
I am running Nitto NT550 235/35/19 front, 275/30/19 rear, No rubbing. I even have more room for 245/35/19 front, 285/30/19 rear.
335is, michelin pss 235/35/19, tire rubbing
