BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Radiator fan removal help!!
proTUNING Freaks
      02-23-2020, 06:25 PM   #1
LetMeMakeYouTaco
Drives: 2015 435i Xdrive
Hello kind bimmer fellas
I have 435 Xdrive automatic
I am trying to remove radiator fan and I am having quite a bit of difficulties removing it.
Basically I am following this service manual
https://www.newtis.info/tisv2/a/en/f...ement/IJDZ6vvr
The transmission cooler is attached to the fan cowl and it is blocking the way of the radiator fan.
The manual says to remove it in upward direction and I tried but the radiator hose is blocking the way. Any other direction it won't move.
I even tried to disconnect the radiator hose, but it won't budge (I unclipped, wiggled it, pried but none worked)
Does anyone know how to successfully remove this radiator fan???
Any advice would be appreciated
In the picture
1 = transmission cooler
2 = radiator hose
☆ = where the radiator hose blocks the transmission cooler
      02-24-2020, 11:03 AM   #2
jparnes1
jparnes1's Avatar
248
Drives: 2016 340i, 2012 Z4 35i
For the hose, unclip it and gently use a screwdriver to lever the plastic connector off the rad as you wiggle it with your hand. Be patient and it'll come off.
For the cooler, I had this same experience with an X3 recently. First push down in the cooler to release it then pull up.
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA.
      04-09-2020, 03:30 AM   #3
pw0n
43
Drives: BMW 435i
In the picture
2 = radiator hose
Did you get this figured out? Also trying to remove the radiator fan in order to crank the motor by hand. I also tried to follow the newtis guide, but it's far from accurate. Do I need to unscrew or unclip something from the underneath the car?
Any help would be greatly appreciated
      07-26-2021, 07:30 PM   #4
Polo08816
Drives: 2014 335i M Sport
I had to disconnect #2 in order to get the clearance to move the transmission cooler out of the way.
      01-10-2023, 12:18 AM   #5
arnas
Lithuania
Drives: BMW 435xi F33
You do not have to disconnect hoses, I was able to do it by pulling the cooling fan sideways. It bearly fits through cooling hoses but you have to be gentle.
The procedure is described quite well in these two videos:
2:42
3:50
fan cowl, n55, radiator fan, transmission cooler
