03-25-2014, 07:11 PM | #1 |
Rep 952
Anyone know what the inside of the PE muffler looks like?
I bought a spare muffler.. decided to cut it apart and make a project out of it. I pulled all the glass out of it.. not sure if I want to try it like that, or try to weld solid pipes in place of the perforated pipes.. I figure that is probably what the difference is with the PE..
13 X1 35iX, 98 Z3 2.8, 01 M Coupe, 96 Z3 1.9 DASC, 95 318ti, 13 smart fortwo
03-25-2014, 09:47 PM | #2 |
133
Rep 261
I have been interested in doing something similar because I want the sound of the performance exhaust but not the price haha. I believe there was a post awhile back where someone cut open a bmw performance exhaust on a e92 335i. I'm sure there is difference between the 335i perf exhaust and the 135i perf exhaust, but maybe you can take some ideas from that. I'll try to find it. Good luck with though
04-03-2014, 09:50 AM | #3 |
Rep 952
Thought I'd update this in case anyone's interested. A friend with an e92 M3 gave me the idea of wrapping the perforated pipes instead of welding. Much easier and fully reversible.. sounds much deeper, the video does it no justice, and got cut off for some reason..
135i N55 OEM muffler mod: Today I was able to look inside the pipes of a PE with a boroscope, turns out that it has the small perforated pipe intact, but the pipe with larger holes is just straight. Explains why mine is a bit louder and deeper than the PE. |
04-03-2014, 11:58 AM | #5 |
Civil Rights Activist
115
Rep 949
That sounds very very good! Nice work!
I know it's back together already but this would be a wicked good DIY for people who want to get that sound! Did you put the glass back in? How did you close the muffler back up, just welded it?
E88 Crimson Red Vert MSport 6MT - Listing your mods in your signature is lame. BMS DCI/MHD E30 Flash!!/AA Sport FMIC/VRSF CP w Tial BOV/VRSF 3" DPs/550i clutch w SPEC SMFW/Apex EC-7s/Whiteline RSFB/E92 M3 FCAs/Bilstein B12 Pro Kit/VRSF inlets |
instroke19.00 |
04-03-2014, 12:32 PM | #6 | |
Rep 952
edit: and yes, I did stuff all the glass back in. Figured it might sound gross without it..
04-04-2014, 04:23 PM | #9 |
115
Rep 949
I love things like this. I think that is so cool. It's the type of thing that could become a cult DIY mod for E8x. "Quick, everyone grab up all the spare N54 and N55 mufflers!" hehe
04-05-2014, 10:32 AM | #11 |
Rep 952
Yep. I used stainless clamps that you would use for headers, but if I were to do it again I'd just use worm clamps. It would be easier and probably tighter. And yes if you just wrapped the pipe with large holes it would sound just like PE
04-05-2014, 12:57 PM | #12 |
Rep 647
Awesome thanks! Is the pipe with the large hole dimpled/dented or is that just from the angle of the picture? Also did you just use a grinder and cut off wheel to cut it open? Would you recommend I cut off the whole lid or just the center section?
04-05-2014, 07:23 PM | #13 |
Rep 952
Probably just the angle of the pic.. I'd just cut the center section out, only reason I cut the whole thing was to see what's going on in there. One thing though, one of the holes is in a tough spot right at the bend, and it's impossible to cover the whole thing... might be able to get someone to weld that one up if it's a worry.. also I'd make sure to do the golf tee mod with this.. if the flap closed, the backpressure in the pipe may cause some damage to the wrap.
04-07-2014, 02:02 PM | #14 | |
Rep 647
04-07-2014, 02:20 PM | #15 |
European Editor
10624
Rep 22,992
@e36addict sorry I have never seen pictures of the inside of the PE. But a friend of mine cut open his 1M's mid pipe resonator. He was gonna weld up the resonator - for a louder exhaust note. When he cut it open he found that BMW beat him to it! This is why the 1M has so much drone and why when you install N55 mids on a 1M, the drone goes away.
Matticus913482.50 |
04-07-2014, 10:46 PM | #17 | |
51
Rep 210
'11 135i M-Sport DCT, M3 RSFB, PPK, CP, BMS intake, Agency Power Axle Back, VRSF 5.5" FMIC, FSB, M3/M1 Front + Rear Control Arms, Ground Control Coilovers, Ground Control Camber Plates, E92 M3 Front Seats, VMR 701's Squared 255's, E92 M3 Steering Rack - Daily Driven, Occasionally Tracked - 157k miles <SOLD> >2021 HS M2C Manual
04-08-2014, 05:17 PM | #18 | |
Rep 952
Haha yep, I had been looking for a spare for a while to make a project out of as if I don't already have enough projects...
04-08-2014, 07:43 PM | #19 |
Rep 647
Started on it today. Dropped muffler, cut the lid. Wrapped just the pipe with the large holes. Brought it to the muffler shop. Have one other quick mod I'm going to have him do when I go pick up the muffler. Driving around without a muffler currently. It's actually not THAT loud.
04-08-2014, 11:19 PM | #20 | |
Rep 952
04-08-2014, 11:57 PM | #21 |
Rep 647
I see you already deleted your resonator, so for you it won't be of any use. But when I removed the muffler I could see inside the resonator. The only place it looked like it had holes was after the y junction in the straight piece. So my plan is to either have him tack all the holes. Or slide in a piece of very thin pipe so exhaust flow isn't affected to much inside the res and tack into place to block all the holes. Hoping it works out and sounds very similar to the PE.
04-09-2014, 11:13 AM | #22 | |
Rep 952
