Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > N54 Valve Cleaning: The Inside Story
      04-18-2014, 10:47 AM   #1
Sean@PSI
Sean@PSI's Avatar
Drives: 2021 IOMG M3 Sedan
N54 Valve Cleaning : The Inside Story of the Walnut Blasting Technique and Process
For everyone who is interested in what actually goes on during a special intake valve cleaning, here is some more information along with several other detailed photos of the process. Without further ado: the story behind it all.
When BMW introduced the N54B30 powerplant to the United States market in 2007, it was their first production turbocharged engine that utilized direct injection technology. This means that instead of traditional intake manifold fuel injection, the engines injectors are placed literally inside the combustion chamber, next to the spark plug. Direct injection boasts better fuel economy, and has proven to be a revolutionary development for the internal combustion engine. The technology is now found in nearly every new production car!
While pioneering the market with the N54B30, BMW did have their share of growing pains with this new technology. There were several revisions for the high pressure fuel pump, and many other sensors and electronics pertaining to the fuel system had their issues as well. One of the major oversights with this technology development was the intake port and valve carbon buildup.
The N54B30 has a crankcase ventilation system that is internally routed in the cylinder head. If you look down into the intake port, you’ll notice a hole on the top of the port that is used by the CCV for vacuum. The problem now is that oil that makes its way through the CCV will end up in the intake port of the cylinder head - which wouldn’t be an issue if there was an injector in each port cleaning it with fuel. Since the N54 doesn’t have any fuel injectors in the manifold, the oil residue builds up on the intake port and intake valves over time. Newer cars such as the Scion FR-S that are direct injected have a second set of injectors in the manifold to help prevent the issue of buildup that the N54 has.
Fortunately BMW recognized the issue and at the very least they have provided us with a genuine BMW tool that can be used to “blast” the carbon buildup off the port and valves.
When the cleaning of the intake valves became regular maintenance on the N54 engines, we experimented with various ways to properly and effectively clean the carbon buildup. We tried chemical cleaning, simple walnut blasting, scrubbing, etc.. After years of dealing with this issue we’ve come up with what we feel is the most effective and efficient way to get rid of the carbon.
Remove the intake manifold.
Inspect the intake port.
Rotate the engine so that the valves are closed in the port being worked on, and then fill the port with a carbon solvent.
Once the solvent has had time to penetrate the buildup, we use a variety of picks and brushes to loosen the carbon buildup, and then using the OEM BMW tool, we walnut blast the port until it is clean.
Inspect, and then clean all missed areas.
All clean!
      04-26-2014, 06:47 PM   #2
HGreen335
HGreen335's Avatar
34
Drives: N54 335i, S65 M3
Great write up. Are you guys still running a special on this? Would be willing to drive up from Naples for the day for the right price.
2009 E92 M3 Coupe DCT (Alpine White/Black Novillo) Borla Exhaust, VRSF Test Pipes, BMC Filter, Alpine Tune, ST Coilovers, Stoptech ST60
2007 E92 335i Coupe 6MT (Space Grey/Coral Red) VRSF Downpipes, BMS DCI, Bigtom FMIC, E-85, JB4 ISO/MHD
      04-29-2014, 04:39 PM   #3
Sean@PSI
Sean@PSI's Avatar
We will be in another month or two. - We will update the threads at that point.
      10-28-2015, 09:26 PM   #4
Sean@PSI
Sean@PSI's Avatar
Offering a Fall Special on Walnut Blasting!
PM me for special pricing and to get scheduled!
      10-28-2015, 09:33 PM   #5
Abax335
Abax335's Avatar
Drives: 2008 BMW 335xi 6spd
Helpful tip I have learned over the years if you drive the car and get it nice and hot before you do the carbon blasting it makes it significantly easier and quicker.
Also found the solvents I use work better after the walnuts otherwise it gums up the carbon making it harder to remove.
But whatever works for you guys. I like my method, just finished doing my own car.
      12-08-2015, 01:46 PM   #6
Sean@PSI
Sean@PSI's Avatar
Offering special pricing for the month of January - Call or PM me!
      03-24-2016, 12:00 PM   #7
Sean@PSI
Sean@PSI's Avatar
Special pricing available through March!
      03-24-2016, 09:49 PM   #8
xyaaeg234g234
happy.
xyaaeg234g234's Avatar
Drives: 2009 e90 335i
Can you shoot me some info please? I've tried to get ahold of you guys a couple times in the last month or so but I imagine yall have been busy with Fundguy1 and his rocketship.
'09 Jet Black E90 335i | BMS DCI | Forge DV | VRSF CP, DP, 7" FMIC, Exhaust | MHD Stg 2 / 93 Oct | Koni Yellow / H&R Sport | Mooooarrrrrr
this list is getting too long.....
      03-24-2016, 10:32 PM   #9
Sean@PSI
Sean@PSI's Avatar
PMed!!
bmw, cleaning, n54, valve, walnut
