03-27-2016, 01:31 PM | #1 |
Rep 1,297
Jb4 map 2 on stock charge pipe ?
So I know this isn't recommended on the e series but was wondering if the f series is any better I already bought the downpipe and charge pipe and because I don't have the patience nor am I mechanically involved im going to have to pay labor for both which comes out to about 480
It's pretty shitty that you have to take off the inter cooler to get this charge pipe on so I was thinking of just having the downpipe done my car only has 3000 miles would the charge pipe break day 1 or what anyone running stock with jb4 with no issues?
2022 M3 xDrive Comp
2020 M2 CS (retired) 2018 M3 Comp (retired) 2015 335i (retired) |
03-27-2016, 01:38 PM | #2 | |
Rep 5,776
2013 335i Msport Black sapphire/Coral red. MHD. stage 2--e30 VRSF DP, ER CP, Dinan Shockware. VRSF 12mm/15mm spacers. Cobra dashcam. Various codings.
Last car: 2011 335i Msport. JB4. Vrsf CP |
03-27-2016, 01:42 PM | #3 |
37
Rep 131
The FMIC doesn't have to come out but I imagine it'll make the pipe come out much easier. I just did the install today without removing the intercooler.
As for map 2 on a stock car, that's up to you. Most wouldn't recommend it without a DP at a minimum. |
03-28-2016, 02:08 PM | #5 |
24415
Rep 191,324
I recommend replacing the CP , that being said the F chassis CP is much better than E chassis
03-28-2016, 02:11 PM | #6 |
Rep 5,776
We are seeing posts of them breaking with stock boost with some regularity now...it's like Russian Roulette.
03-28-2016, 02:23 PM | #7 | |
24415
Rep 191,324
Thats why i said i recommend changing replacing it
03-28-2016, 02:31 PM | #8 | |
4927
Rep 116,006
If you have it you should get it installed. I can't imagine the shop would charge that much more if you are getting the downpipes installed at the same time. Mike |
03-28-2016, 02:38 PM | #9 |
24
Rep 167
Ive had my 335 for close to 2 years and i consider myself pretty aggressive driver. My luck that i have jb4 map1 w/ stock cp and no issues, yet. Thanks to mike x-hp i ordered er cp and er dp for a good deal last year. Just waiting to get my letter regarding smog test (which should be any day now) so i can get those parts installed IMMEDIATELY and switch the map2 with some e85. Also have a bms intake that should be arriving today. See what all the hype is about but I'm so looking forward for that time to come.
Either way, i would swap out stock cp just for peace of mind. You don't want it to fail on you, get stranded, towed and waste your whole day over something you kind of knew was bound to happen and could have avoided. |
03-28-2016, 02:44 PM | #10 | |
37
Rep 131
03-28-2016, 02:53 PM | #11 | ||
24
Rep 167
03-28-2016, 02:59 PM | #12 |
37
Rep 131
Yeah the CP, to me, was the most important after I had mine replaced under warranty.
As for E85 use on EWG cars, this is from BMS: "7) As a general rule EWG cars are not very E85 friendly. If reliability is a concern no more than 30% E85 should be used and the highest map used should be map 2. Using map 5 or map 7 with E85 mixtures may result in boost running high enough to exceed your fueling capacity triggering various codes and/or JB4 safety map 4 switches. If you are more experienced and able to analyze your own logs you are welcome to play around, but we've instructed technical support NOT to provide assistance or advice to anyone exceeding map 2 when using E85 with the EWG platform. If you run map 5 or 7 on E85, run in to problems, and ask for help, you'll get the company line of "for E85 use no higher than 30% and map 2". For more power consider race gas instead of E85, or add in a methanol kit allowing use of map 3." So, I guess map 5 with E85 is up to you. |
03-28-2016, 03:28 PM | #13 | |
Rep 5,776
I just saw in the other thread you have a 2014. You shouldn't need a smog for awhile.
03-28-2016, 03:53 PM | #14 |
Rep 1,782
Currently using map 5 with e85 on stock CP. I am thinking of order an ER CP soon though for when I break this one hahah
13' 335i M Sport. EBII/Coral Red 6MT. RPI GT exhaust, Resonator delete, PS1, GFB DV , BM3 Stage 2, ER CP, VRSF DP, VRSF 5.5in Stepped FMIC, Dinan Shockware. Carbon M Performance rear diffuser. M4 trunk lip. Conti DWS06 225/40/19 and 255/35/19
03-28-2016, 04:16 PM | #15 | ||
24
Rep 167
03-28-2016, 05:30 PM | #16 |
Rep 5,776
Here in CA, cars will not need a smog test in the first 6 years of the model year. You will only pay smog abatement fee. So, your 2014 will not need a test until 2020. That's why I went with a DP--my car will not need a test until 2019, so that gives me a few years until I have to swap.
03-28-2016, 06:31 PM | #17 | |
24
Rep 167
03-28-2016, 06:38 PM | #18 |
2087
Rep 2,649
I'm about to place an order for the ER CP soon as everyday I drive the car, I fear that my CP will just up and go. Replacing the CP will get rid of that, and I'll only have to worry about what tune I want to get next
03-28-2016, 06:45 PM | #19 |
Rep 5,776
03-28-2016, 06:47 PM | #20 |
94
Rep 389
Drives: '13 F30 335i MSport
Good idea. My stock CP failed on map 1.
2013 GSM 335i MSport
03-29-2016, 11:18 AM | #21 | ||
Rep 1,782
03-29-2016, 12:15 PM | #22 |
4927
Rep 116,006
