M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > BMW M5 (F10) General Forum
      01-09-2019, 07:42 AM   #1
ZANDERZA
South Africa
17
Drives: F13 M6; E60 M5; F10 M5
Unhappy
Hi guys
I have been reading quite a few horror stories of late, from people who have had catastrophic engine failures.
From spun rod bearings, to bent rods right through to big gaping holes through the block.
This makes me wonder, how many problem-free high mileage
F10 M5 are there that obviously still has their original engine?
How many people have had their engines replaced due to failure?
      01-09-2019, 07:52 AM   #2
Lmaiuri
64
Drives: 13' Sapphire Black M5
Take it with a grain of salt.
People who grenade their motors are (mostly) playing with unsafe tunes and power levels that are way out of scope for what the platform was designed to handle.
It happens on every forum. For the amount of blown motors there are hundreds if not thousands of M5's running without a hiccup.
boots623.00
M5Rick60148.00
      01-09-2019, 10:22 AM   #3
M5Dan
M5Dan's Avatar
Drives: M5 Competition Package
2019 BMW X7   [0.00]
2016 BMW M5  [10.00]
The S63tu is a very reliable motor. I have 75,000 miles on my M5 and plan on keeping it well past 100,000 miles. Just keep up on regular maintenance service intervals and keep an eye on your oil consumption (if you have any) and you should be good. There are other members on here who have over 100,000 miles on their M5 and they're still going strong.
      01-09-2019, 10:40 AM   #4
ZANDERZA
South Africa
17
Originally Posted by M5Dan View Post
The S63tu is a very reliable motor. I have 75,000 miles on my M5 and plan on keeping it well past 100,000 miles. Just keep up on regular maintenance service intervals and keep an eye on your oil consumption (if you have any) and you should be good. I believe @ [boots](contact:182778) has over 100,000 miles on his M5 and it's still going strong.
Thanks.
Should they not be using oil? Or what are acceptable levels of oil use?
      01-09-2019, 12:23 PM   #5
bmwdinan5
26
Drives: Dinan5
Bad assumption.
      01-09-2019, 12:40 PM   #6
ZANDERZA
South Africa
17
Originally Posted by bmwdinan5 View Post
Bad assumption.
Do you have any bad experience with the motor?
      01-09-2019, 05:48 PM   #7
luv135i
luv135i's Avatar
60
Drives: White
Bad assumption.
Elaborate
      01-09-2019, 05:57 PM   #8
mister2d
Drives: F10 M5
Bad assumption.
Very bad.
      01-09-2019, 11:10 PM   #9
q8kamikaze
q8kamikaze's Avatar
Kuwait
103
Drives: 14 M5 F10 moonstone/SO
35.000 miles with 0 issues
      01-09-2019, 11:54 PM   #10
tqbmw
95
Drives: 2013 F10 550
38k miles. Have her for 4 years. Replaced AC condenser under warranty and currently has coolant lines leaking (from top under engine cover). That's a common problem. It's going to dealership Friday. Otherwise zero issues.
      01-10-2019, 11:40 PM   #11
boots
Curve Thrasher
boots's Avatar
623
Drives: 2013 Bmw m5..White/Blk.
there is already another thread on this. I'm tired and won't elaborate. search button will assist you. but over got 129k plus on my heavy modes 13m5. no issues to report.
2013 Bmw M5-Alpine White/Black-Oem gloss blk powder coated wheels-Expel clear bra-35% tint-Rpi Gtm Exhaust-Rpi Downpipes-Rpi Scoops-Halim Cazimi Performance Tune-KwV3 coilovers
Country run
      01-11-2019, 01:41 AM   #12
INFURNO
167
Drives: F10 M5
About 88,000 miles now.
Leaky turbo coolant lines as others have mentioned. $50 diy repair. Just had the engine inspected.. everything reported as solid.
My in-tank fuel pump failed at 70k miles. Weird.
BMW just extended the warranty on the high pressure fuel pumps to 10 years or 120,000 miles. That seems to be the known flaw.
      01-11-2019, 03:23 AM   #13
M5Rick
General
M5Rick's Avatar
60148
Drives: M5 F10 DCT Gunmetal
Originally Posted by ZANDERZA View Post
Hi guys
Hello there!Perhaps you can update us if you had your engine or g/box noise rectified.Last time you were on here it was sounding like an anchor chain being hauled up a ship.
      01-11-2019, 03:49 AM   #14
ZANDERZA
South Africa
17
Hi guys
Hi
I turned out to be this part: 28102284678
All good now. Ill update the post soon
M5Rick60148.00
94jedi830.00
      01-11-2019, 08:57 AM   #15
Lmaiuri
64
Originally Posted by mister2d View Post
Very bad.
Yeah? How so?
Do you have data aside from a few personal experiences on the board where folks run that terribly designed carbon fiber intake system that sits in the grille? Or running a bad piggy back tune that tries to retard the ECU into believing different target HP/TQ numbers resulting in pulled timing, inconsistent performance, and engine damage?
Forums have always been and will always be a bitch fest for people who do bad things to their cars to come and get consoled for doing such. For every 10-15 m5's that blow their engine, there are thousands more running happily throughout the United States and the rest of the world.
Appreciate 3
M5Rick60148.00
      01-11-2019, 09:44 PM   #16
mister2d
Drives: F10 M5
Yeah? How so?
I believe you are ranting on about the same thing I'm in agreement with.
      01-14-2019, 11:38 AM   #17
Lmaiuri
64
Sorry homes. Read post #5 and you'll see that he quoted me and said I made a bad assumption.
      01-27-2019, 05:40 PM   #18
94jedi
Drives: 2009 e92 M3
Hi
Sounds insulation pad? Was it rattling or loose or something?
      01-30-2019, 09:43 PM   #19
G-M5
159
Drives: 2015 M5 , 2019 M5 , 2022 X5 M5
14,500 miles
      01-30-2019, 09:44 PM   #20
Herofmine
Herofmine's Avatar
Drives: E92M3, F10535i, 15 M5,340i,X5M
2015 X5M  [10.00]
20k
      01-31-2019, 01:41 AM   #21
Phatcat
Drives: BMW M5, X5M
12000km.
      01-31-2019, 12:45 PM   #22
SapphireM5
SapphireM5's Avatar
711
Drives: 2013 M5 Sapphire Black
9000
'13 Black Sapphire Metallic - BPM Stage 1 Tune - RPI Exhaust - KW HAS Kit - 12mm spacers all around- Carbon Fiber front lip - High Kick Trunk Spoiler - Rear Roof Spoiler - IND Kidney and Fender Grills - 20% Tint all around 50% Front Windshield - PPF
m5post
