BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > F30 N20 1/4 Mile Thread
ARMA SPEED
      06-24-2013, 01:46 PM   #23
QQ
JB4 King
QQ's Avatar
South Africa
Drives: 2012 BMW 125i MSPORT F20
Originally Posted by Jamesons Viggen View Post
So that is 300whp and 327ft lbs. What was the cars stock crank rating? Stock car, just BMS stage 2 at +4psi and a mix of E85?
Car made 168kw and 319nm out of factory on the same dyno - factory figures are supposed to be 160kw and 310nm.
Car is stock yes. Only BMS Stage 2 with Map 1 = 20psi. (This is +3 psi, as stock is 17psi). Map 2 is 21 psi (+4psi) and map 7 is 23 psi (+6psi). I need the flex fuel wires for more boost than map 1, as the car is running slightly lean on map 1 with my fuel mix.
20% ethanol 95/E5 and 80% 95RON pump fuel. The ethanol is the same grade we use here in our gas appliances. We do not have E85 in our country.
      06-24-2013, 03:32 PM   #24
Jamesons Viggen
Drives: '98 M Roadster stg 2+ S/C
Wow, for just +3 psi those are very good results.
Do you happen to know the weight of your car? It can't be much more than 100-150lbs lighter than an F30 328 which is 3350-3450lbs.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc)
'15 Buick Regal "T"(wife)
'06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc)
      06-24-2013, 06:00 PM   #25
Alpine F31
Alpine F31's Avatar
Drives: MB E350 4MATIC Estate
Hi
I did VBOX testing on my 125i Auto with BMS JB4 stage 2. Standard tyres - M-Sport mixed 18" Bridgestones. I ran a 12.7sec 1/4 mile @ 111mph. I did 0-60mph in 4.3 secs.
Your 125i ran almost the exact same times as a 2013 Porsche 911 Carrera 4 PDK; 0-60 mph 4.2 Quarter Mile 12.7
That's unbelievable!
      06-25-2013, 11:41 AM   #26
QQ
JB4 King
QQ's Avatar
South Africa
It weighs 1365kg..... about 3009lbs. I have a quite a lot of extras on my car as well.
      06-25-2013, 11:42 AM   #27
QQ
JB4 King
QQ's Avatar
South Africa
Unbelievable but TRUE!
      06-25-2013, 06:08 PM   #28
rustyminded
rustyminded's Avatar
248
Drives: BMW 328i
I don't have Ethanol here too, so can I use normal Ethanol, if so how much should I put with RON92 and will it damage my system ? my mods are bms st1, afe dry filter and scoop
      06-26-2013, 01:45 AM   #29
QQ
JB4 King
QQ's Avatar
South Africa
I would just start with a 20% mix with not more than +4psi on Stage 1. That's what I used to run when I only had stage 1 and it worked fine. I would not mix more than 20% on Stage 1 with more boost, as you can run the risk of running way too lean AFR.
      06-26-2013, 08:53 PM   #30
bnekic
20
Drives: 2013 328i xDrive Sport Line
So I think I did pretty bad with the mods I have...
2013 328i xDrive with sport auto tranny
BMS Stage 1
aFe Cat-back Exhaust
aFe Intake
aFe Intake Scoop
I put the car in Sport + and tranny in sport auto. It was around 85 with high humidity. I'm the left side...that was my best time of the night.
Based on the stock times I've seen from magazines, the mods I put on my car pretty much did nothing. Stock this car runs 13.8-14.1 at 97.7-98.2!
      06-26-2013, 10:55 PM   #31
Jamesons Viggen
BMS Stage 1
aFe Intake
aFe Intake Scoop
Your trap speed is near stock for an 8spd Xdrive, 98mph or so, the ET would be about 14.0 stock. The magazine times you saw were for RWD cars, RWD will trap a bit better, Xdrive will ET a bit better.
The heat and humidity did you no favors.
But what about launching the car and shift points?
I am guessing you did not launch at a very aggressive RPM.
The intake, scoops, likely do nothing. The catback is worth maybe a few hp, you are relying all on the BMS basically which should net a 3-5 tenth improvement.
You had less than an ideal environment. I would say your car driven to its potential in better weather should net a 13.4-13.6 at 102-104.
      06-27-2013, 02:01 AM   #32
QQ
JB4 King
QQ's Avatar
South Africa
+1
Agreed..... Launch is everything. When at the strip again, try running 20% ethanol mix with +6psi boost and you will see a noticeable difference. Standard my car made 169kw and 319nm. With BMS Stage 1 my car made 189kw and 389nm with +3.5psi and 95RON pump fuel only. With the 20 %ethanol mix and +6psi, the car made 204kw and 404nm.
      06-27-2013, 07:15 AM   #33
bnekic
20
I launched around 1,500, brake boosting. Like I said I put the tranny in sport mode and made the runs in fully auto. The car was shifting near redline.
      06-27-2013, 03:05 PM   #34
Jamesons Viggen
1500rpm is a pretty modest/soft launch. The magazines that test drive X-Drives and get those great numbers-they do much harder launch. I think the torque converter maxes out lockup at 3100rpms.
Even a 6mt RWD car gets launched at higher than 1500rpms. The point of Xdrive being FASTER in 0-60 is by taking advantage of the traction at launch. If you do not, your times will be slower than a RWD car. With your low RPM launch and hot/humid weather, your car would have done more like a 14.4+ with out the tune. So it helped. But to get full benefit and get 13's, you are going to need a more aggressive launch.
But hey, at least you made it out to the strip. Most talk about their mods and how fast the car is and never dare to make a single pass.
N26Ghost496.50
      06-27-2013, 04:57 PM   #35
David328M-Sport
Australia
101
Drives: F30 M-Sport 328i Estoril Blue
You will get the same times even in EcoPro mode with WOT.
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
      06-27-2013, 05:39 PM   #36
bnekic
20
^ moving the shifter to the left puts the tranny is sport mode which holds the revs longer. When you track your car you put it in Sport + and move shifter to the left.
      06-29-2013, 02:31 PM   #37
SmokeShank
Drives: 328xi M-Sport
Your 2.0 60's are hurting you.
I ran my 328xi (Msport, non sport trans) the other weekend and was cutting 1.8 60' on the stall (~3k).
My best run was 13.93 @ 98mph. My worst 60' was 1.98. Almost a 1.8x every time. That was BMS stage 1 tune at +3psi only. stock intake, exhaust only has a axle back race pipe which has no power gains.
      06-30-2013, 05:39 AM   #38
bnekic
20
I just hate brake boosting auto cars, seems like lots of stress on the tranny. I know I need to get it down, with my Evo I'd be doing 1.7 60 foots.
      06-30-2013, 11:36 AM   #39
Jamesons Viggen
A tenth off your 60 is worth two off you ET, so if you got the same 1.8 posted above you would have a 13.6 or so.
Your auto can handle it
      06-30-2013, 02:00 PM   #40
fgalanda
fgalanda's Avatar
Drives: 2017 F30 330i M Sport EBII
2002 BMW 325i  [0.00]
2006 BMW 325i  [0.00]
2013 BMW 328i  [0.00]
2015 BMW 328i  [0.00]
2017 BMW 330i  [0.00]
I did 14.003; no tunes; however i still have those shitty stock run flat potenzas! With little thread left on them :/ going to get new ones in 5k miles, should be a lot better. Hopefully bmw performance chip will come out soon.
      07-01-2013, 08:27 PM   #41
Jamesons Viggen
Can you post up your slip and or all the times?
14.0 dead for a bone stock car is pretty good. Share with everyone your launch technique.
      07-08-2013, 02:31 AM   #42
QQ
JB4 King
QQ's Avatar
South Africa
Just to let you all know....
With 224kw and 444nm I did that 12.7 1/4 mile time. After installing my flex fuel wires and using map 7 on the JB4 stage 2, I managed an awesome 239.7kw and 508nm.
I am doing a 1/4 mile event in 3 weeks time and will see what my 1/4 mile time is with the added power.
N26Ghost496.50
      07-09-2013, 07:23 PM   #43
fgalanda
fgalanda's Avatar
I will tonight If I find them all. All of my stock cars were faster than the exact same stock cars lol. This might sound stupid, but I heard from many people who drive hard, that the harder you drive the faster car gets. I also had 113 octan leaded gas in it. Few days after runs my 2 out of 4 injectors failed ...so bmw replaced all of them with upgraded units. (Weird but my gas mileage improved after it from like 23 to 31 -average mpg) I dont know if it was due to the leaded gas or not... Usually it would mess up the cat and o2 sensors... Anyway bmw took care of me... I brake tourqed to the highest rpm without spinning and just let go... It was my first time on track ever too... And I had wheel spin due to tires...
      09-28-2013, 06:48 PM   #44
JSillaway
Drives: 2013 328 N26
My 2013 N26 with BMS stage 2 70/30 E85 mix on map 1 13.53 1/4 mile. I will post times when I run with my 4" catless and M performance exhaust on map 2.
My buddies 2013 M sport N55 BMS stage 2 map 2 12.70 1/4 mile
This is at 1200 ft Above sea level and 75 deg
