330i Rear Diff Swap with AT 3.64 diff questions (Updated video)
05-27-2015, 02:16 PM | #23 |
Rep 7,215
no.. the DSC controls the speedometer, and that's read from individual wheels, not the diff. There hasn't been a BMW that needed the cluster coded for a diff change since they stopped using cable driven speedometers (which I don't know that they ever have).
The DME does use the diff ratio to figure out what gear you're in but the effects of that should be pretty minor. but why a diff swap and no performance tune? they really go together.. |
05-27-2015, 08:53 PM | #24 | |
80
Rep 234
Interesting to know that it calculates MPH from the ABS system... (Presumably) O/T - I guess you're a machinist, that runs Haas CNC machines? |
05-28-2015, 06:08 AM | #25 | |
Rep 32
Is this a DIY project, did it take long? What is the stock gearing on MT 330i? Edit: Is this the diff you used?
E90 M-Sport 330i N53 272hp w Dynomax VT Muffler & Mod. OEM airbox w Ramair filter Last edited by Benan; 05-28-2015 at 06:55 AM.. |
05-28-2015, 08:31 AM | #26 | |
Rep 7,215
I was thinking of the shorter gearing, then I realized some of the corners I like to take, I'd have to shift in the middle of the turn - with the stock gearing, I can wind out 2nd and shift when I'm going straight. it would only work (for me) if the gearing was substantially shorter (maybe 3.91 or 4.10) so I could be in 3rd gear instead of 2nd, but then that would be no good for the street. heh, no - although I did work in a CNC shop (and on a Haas 4 axis mill) like 20 years ago. it's an "auf deutch" play on 1989's PHM... |
05-28-2015, 08:31 AM | #27 |
1268
Rep 2,957
Stock gearing is 3.15. I did a 3.64 from the auto at the same time I did the AA Software tune. I don't see why you couldn't just do the diff upgrade by itself though.
05-28-2015, 08:34 AM | #28 | |
705
Rep 2,605
Drives: 06 330i E90, 18 530xe G30
Chalk up front wheels, jack the rear end from the diff and put the car on jack stands under the rear lifting points. Remove the exhaust, it was easier for me as I already had the PE with pipe clamps which made the job easier. If you have the OEM exhaust it may be more difficult. Removing the drive shaft and half shafts are self explanatory. Dropping the diff is just a matter of having the jack under after you unbolt it and having a buddy help you lower it out. Total time should be about 4-5 hours if you take your time. |
05-28-2015, 08:36 AM | #29 |
705
Rep 2,605
05-28-2015, 08:39 AM | #30 | |
705
Rep 2,605
05-28-2015, 08:46 AM | #31 |
Rep 7,215
I believe it. It's just that for where I drive, it would actually make the corners slower, because shifting 1/2 of the way through a corner at speed isn't a good idea. so I'd either have to shift up earlier (and be out of the power band), or ride the rev limiter until I exit the corner.
05-28-2015, 01:26 PM | #32 |
Rep 1,794
Drives: F30 328i M 6mt, E36 M3
Shorter gearing does indeed wake these cars up, makes them feel a bit lighter on their feet. I had 3.64s for a bit but when that rear end broke, I did 3.38s, which turned out to be a nice happy medium.
05-28-2015, 07:59 PM | #34 |
80
Rep 234
I'm with Haas on this one. No point in me doing a diff swap if I can't also do an LSD to help keep the power down, especially Iin the corners... My other car is an E30 with an AWESOME 3.73 LSD and there is no comparing how the two cars put down the power. But like Volasko said, putting a LSD into a diff, makes the swap 3-4x more expensive. I started researching putting an M3 diff in the car, but I'm not sure how much a used diff would be, and it seems like you have to chop-up, or at least piece-together a driveshaft. There doesn't seem to be an inexpensive way to do a diff+LSD swap right now...
If I found a solution, I'd probably DIY this, at the same time I did a muffler... |
05-29-2015, 01:23 AM | #35 |
Rep 32
Thanx for the info! This got me to order a 3,64 lump
E90 M-Sport 330i N53 272hp w Dynomax VT Muffler & Mod. OEM airbox w Ramair filter |
08-08-2015, 07:38 PM | #37 |
705
Rep 2,605
Incase anyone wants to see an acceleration video, I think I'm the first to do this!
Edit: This video was taken when my main large DISA valve had failed which doesn't show up in the codes. This wouldn't be accurate. Last edited by Volasko; 04-07-2016 at 07:58 AM.. |
08-09-2015, 12:00 PM | #39 |
Rep 1,794
at 75 2700 with 3.38 and 3000 with 3.64
08-10-2015, 09:54 AM | #40 |
705
Rep 2,605
It's hard to say, I never really trust those phone 0-60 apps and I don't have any fancy GPS data loggers. There is another 2-3 shift needed now to reach 60 due to the different final drive ratio, so I would say its a wash.
08-10-2015, 03:04 PM | #42 |
705
Rep 2,605
It is noticeably improved, every gear feels stronger due to the new final drive ratio. It is to be expected as there is 15% more torque being applied to the wheels. My average economy has gone down which is to be expected but not as much as I thought. I used to average about 625km/tank, now I'm lucky if I reach 600km. Not a huge change but a change none the less.
08-12-2015, 08:49 PM | #44 |
80
Rep 234
My question though - with the extra torque, how does it put the power down, especially in corners? More slip/DSC action now?
I'm still considering this, but I really don't want to sacrifice the highway cruising, and I'm concerned about cornering with the extra torque and no LSD. There's just no way I can justify $2000 for a new LSD/ratio... |
