New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      10-18-2016, 09:32 AM   #89
jake169
29
Drives: 2011 35is
Originally Posted by fmorelli View Post
For that setup, not quite ... you can only use the front brakes ... you want the front only set.
Filippo
So apparently the front only parts are slightly more expensive than the whole kit.
      10-18-2016, 03:25 PM   #90
fmorelli
fmorelli's Avatar
Drives: Atacama Yellow 35i
I bought mine from Husker. Front only is $1,129. Cheap.
http://www.bmwdirectparts.com/oe-bmw/34110444738
If you want to see a photo of what comes with it, ECS shows it.
Tough to beat for the money. A larger brake setup would be nice for track use, but for spirited street driving this works well.
Filippo
2011 35i MT Atacama ... lots of bits. Full Öhlins TTX custom suspension. Build thread.
Build sheet. Currently finishing suspension, fuel, ignition system with Barry Battle @ 3DMMotorsport.
      10-18-2016, 09:50 PM   #91
dwspen01
Drives: 2009 Z4 35i DCT
I just ordered the M Performance upgrade (34112221445) from ebay for $1,238 but you have to order the rear rotors separately. They offer two different part numbers for the rear rotors (34206797598 or 34206797600). I can't figure out which is the correct rotor for the Z4 with M Performance kit. Has anyone installed the M Performance brake upgrade with the 370mm front rotors? What rear rotors did you install?
2009 Z4 DCT - Hexon RR600, MMP Inlets/Outlets, Wagner EVO 2 Comp FMIC, Fuel-It TBI, Fuel-It Stage 2 LPFP, ER CP, Forge DVs, N20 TMAP, BQ Tune 93/E65, BMS DCI, AR Catless DPs, BMS OCC, RB PVC
      10-28-2016, 12:14 PM   #92
dwspen01
Has anyone installed the 324mm 35is rear brakes on a 35i (stock 300mm)? Wandering if it requires calipers and brackets or just brackets. I know it will require new rotors (324 vs 300).
      11-23-2016, 08:14 AM   #93
Vetracr
32
Drives: 2010 BMW Z4 3.0
Just a quick note to anyone replacing front brake lines with SS lines on an E89 Z4. When bleeding brakes you have to tap upper loop of new SS line to get trapped air from line. When on jack stands loop is above bleeder screw.
      03-13-2017, 09:11 PM   #94
suprtran
suprtran's Avatar
111
Drives: BMWs
Compatibility question
Does anyone know whether these M Performance 345x24 rear rotors will fit with stock 35i (300x20) or 35is (324x20) calipers:
https://getbmwparts.com/partlocator/...catalogid=4462
      04-15-2017, 04:20 PM   #95
Wumian Zhao
Drives: E89 Z4 35i
can i use m235i calipers and rotors in both front and rear? my friend give me his m235i oem calipers pads and rotors.
      05-02-2017, 01:52 PM   #96
pavproch
9
Drives: Z4 3.0i & 330ixT
Speaking the fronts: Yap, these fit. PnP.
Originally Posted by pavproch
N2SHA sport brake package:
rotors 34106797602 (340x30mm, slotted/drilled)
caliper right 34116799466, 2pot blue + ///M badge
caliper left 34116799465, 2pot blue + ///M badge
pads 34116859066
Confirmed.
(Courtesy of Mythbusters.... )
Daily:330ix 6MT - PBX, HR SportSprings, Koni Yellows, OZ Ultraleggera 18", PI+PE, CDV off, UUC sways, M235i SportBrake (front), Cquence rotors (rear), 3.64 diffs, LSD rear
Funcar: Z4 3.0i 6MT - HR SportSprings +sways, OZ Ultraleggera 19", 5.00 diff by Drexler, CDV off, Quaife LSD, M235i SportBrake (front), Cquence rotors (rear)
      06-18-2017, 07:01 PM   #97
funinblue
Drives: 2014 28i MSport 6 spd
2014 BMW Z4  [0.00]
Upgraded the front brakes, finally.
Used M Sport brakes with Slotted/dimpled rotors on 325M 18" wheels. Used the combination shown in the thread;
As advertised, plug and play, no issues.
This thread was great to have, thanks everyone!
2014 SDrive 28i, DSB, 6 spd, Sat Nav, Design Pure Traction MSport, Ext Hyper Orange/Black, Cold Weather, Technology Package, Professional Sound, PDC, Auto Headlights, comfort access
      07-20-2017, 01:06 PM   #98
rif75
France
64
Drives: BMW M4 LCI ZCP and BMW M5 f10
Hello guys,
Just have received my M4 calipers. It's used part with oem M4 rotors so I'll try to put on my e89 and let you know. I ordered a set of 370mm rotors in case of...
BMW M5 ZCP and M4 ZCP. BMW 540i G30 stage 2 with KW street confort, Wagner DP, Remus catback, M sport brakes 395mm front and 385mm rear. MHD tune.
      08-07-2017, 03:39 PM   #99
BQ Tuning
BQ Tuning's Avatar
Drives: N54 E89 Z4 35i M Sport
This ONLY applies to those who have the E89 Z4 sDrive 35i (not the 35is) with 18" or 19" wheels
The E89 Z4 sDrive 35i stock rotors are 330X24 . The Z4 sDrive 35is stock rotors are 348X30
Also the calipers on the 35i vs the 35is are also not the same . In a whole nut shell the 35i got the 330i front brakes
The 6 piston BMW Performance BBK will be the "budget upgrade kit" for the 35i
https://www.ecstuning.com/b-genuine-...m/34110444738/
Of course the brake pad sensor that comes with this BBK is not for the Z4 so you will need the OE or OEM brake pad sensor for the Z4
In addition we added SS lines, and went with the OEM 6 piston brake pads
I have advocated to see if ECS Tuning can put a kit together specifically for the 35i
Those with the 35is yes it would make sense to go with the F30 setup if not on a budget cause this BBK is not necessarily an upgrade for the 35is ie bigger calipers yes, but smaller rotors. The 6 piston BBK shown here is not compatible with a 348x30 rotor. We tested this today and it does not fit.
      08-07-2017, 04:51 PM   #100
Lurcher
Lurcher's Avatar
Drives: 2012 z4
So all the parts needed:
ECS brake kit
front stock brake pad sensors
6 piston brake pads (from 335?)
SS lines
Rear rotors to match
Right?
      08-07-2017, 06:27 PM   #101
fmorelli
fmorelli's Avatar
This is the same rig I'm running on my 35i. I got the 6-pot Brembo BMW front brake kit from Husker Auto Parts for $1,150 or so. I did front and rear SS lines from UUC for $120 (they were correct). In the rear I put Powerstop drilled and slotted rotors for $140, along with EBC yellowstuff pads for $75, giving a bit more bite to round out the setup.
The whole setup works well. I have about 3k miles on it.
Filippo
      08-09-2017, 02:23 PM   #102
BQ Tuning
BQ Tuning's Avatar
ECS brake kit
SS lines
Right?
Yes, here is the link to the OEM brake pads I used for the BBK https://www.ecstuning.com/b-genuine-...t/34116786044/
As for the rear, reference to the above post by fmorelli
Now here is something interesting but extremely expensive for the rear. You can get a set of rear E-big brakes and rotors by PBbrakes for the rear and color you like for the rear calipers with no logo option.
http://pbbrakes.com/brake-kits/bmw/z...brake-kit.html
      08-24-2017, 05:04 PM   #103
rif75
France
64
Hey guys,
There is a picture of my breaks with brand new 370mm rotors
BaaQaf253.00
      04-23-2018, 12:05 PM   #104
jeffp1105
Drives: 2020 Z4 M40i
Sorry to dredge up an old thread. Newbie confusion: the setup described by Lurcher, BQ Tuning and fmorelli both point to sites that indicate these kits aren't compatible with a 2011 E89 35i.
Do I just ignore these warnings? What parts from the kit aren't compatible? Just the pad sensors?
Thanks in advance,
Jeff
2020 BMW Z4 M40i, Black/Cognac/799 Black Wheels
      04-24-2018, 02:08 PM   #105
BaaQaf
Drives: 2012 E89 Z4 35i M Sport
Thanks in advance,
Jeff
The sensor is the only thing that is not compatible in the kit. You will have to get the original sensor. ECTuning just dont know or just dont care to know as it is a possible conflict of interesting with their other 6 piston Big Brake kits for the E89 Z4 35i(s)
I email ecstuning and showing them the proof the kit is plug and play on the E89 Z435i(s) but I guess they ignored it for a strategic sales purpose. My next post will show the reason why.
      04-24-2018, 02:18 PM   #106
BaaQaf
Complete Big Brake Upgrade
ECSTuning just recently released a "complete" Sparta 6 piston Big Brake kit upgrade, front and back, for the E89 Z4 35i(s) models with color select.
This is the boys edition https://www.ecstuning.com/b-sparta-e...123~dk/?pdk=Bw (The BMW OEM 6 piston option is better than this)
This is the MEN edition https://www.ecstuning.com/b-sparta-e...123~dk/?pdk=AQ
This is the rear big brake upgrade assuming it is compatible with our ebrake https://www.ecstuning.com/b-sparta-e...126~dk/?pdk=AQ
      04-24-2018, 05:59 PM   #107
jts1981
jts1981's Avatar
213
Drives: n54
Thanks in advance,
Jeff
What's your budget and goal? I'd recommend looking in PB brakes which maintain the E-brake. I'm running 380mm all around, 8 pot front, 6 rear.
      04-25-2018, 10:45 AM   #108
jeffp1105
Jts1981,
Good questions. My budget is closer to $2K and my goals are purely open lapping on a track but no head to head racing. I've made some engine upgrades but now it's time to address handling and braking. I tend to do things on a time and $$ increment. I liked fmorelli's setup because of the price and it puts most $$ up front but includes some bits for the rear without "braking" the bank, pun intended.
Also, I'm really not sure how or why a $2K+ 6 piston brake setup is so much better than a $1200 6 piston OEM setup so seems to me the BMW setup is the way to go. Any thoughts on this reasoning?
Thanks a lot!
fmorelli161.50
      04-25-2018, 08:05 PM   #109
Lurcher
Lurcher's Avatar
Drives: 2012 z4
Originally Posted by BaaQaf View Post
$4k - damn they are proud... and a crappy blue too...
      05-20-2018, 04:36 AM   #110
fran_br
Drives: FF z4 e89
When i saw the Z4 v8 post i felt in love with the 400mm rotors of the M5 F10.. well.. i only hope that it fit in my wheels
http://e89.zpost.com/forums/attachme...1&d=1526808845
zpost
