XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > General BMW X1 (E84) Forum
      12-05-2022, 09:06 PM   #23
Rick Castro
Drives: bmw x1
hello my name is rick i had the same problem, i fix mine this past november, if you are interested in getting it fixed, contact me
      12-05-2022, 09:44 PM   #24
Rick Castro
Drives: bmw x1
if you still need help, contact me and i can help you
      05-31-2023, 11:52 AM   #25
proteus290
proteus290's Avatar
Drives: 2014 BMW X1 35I Ultimate
Originally Posted by e36addict View Post
Yes I had to remove the complete head liner and sunroof cassette assembly. I have a black headliner so I replaced both fabric sliding parts due to the material peeling off, and the plastic sliding parts for the shades. Those come in a kit, PN 54-10-2-993-888. I also work at a BMW dealer, so I got cost on these parts, which saves a bit.
new item to fix inner rear sunshield black cloth covered panels, rear cloth unrolled into rear slot pulled it out of their pano sunroof is closed procedures and options to fix?
austin area anyone done htis repair before?
Seems Black cloth just peeled off, foam is ruined and crumbling front inner sunshield has same issue cloth is coming off apart and cloth is soft and saggy ,rear inner black sunshade looks like crap now ,how to fix?
BMW kit to fix is a pair of new nylon slides, both new panels are 250 and 278 each retail , u tube?
both cloth panels have delaminated as adhesive is failing
Please advise
      07-05-2023, 06:36 AM   #26
Sonic222
Drives: BMW X1
Sunshade stuck
Originally Posted by Rick Castro View Post
sunshade ,i can help you if you still need help.contact me
Hi please help me if you can my sunshade is stuck in open position and doesn’t move. When I try to initialise it I get an anti trap warning and the front part of moon roof tilts up but then nothing else. I can hear a click noise when I press the close button. Any help would be appreciated.
      08-02-2023, 06:39 PM   #27
dhasen
Drives: 2016 BMW X1
Have the parts, need help on installation
I had to rebuild mine last weekend. Cost me about $400 in parts and 3 or so hours of my time.
How did you manage to complete yourself, do you have a video or instructions you can share?
      08-14-2023, 01:20 PM   #28
itsaaronbarry
Drives: Bmw X1 2015
Unhappy
Does anyone have a good fix yet? This exact thing just happened to me as well.
Thanks!
      09-04-2023, 01:41 PM   #29
imBlasted
Drives: 2014 BMW E84
From what I have found, the cheapest solution is to decode the sunroof. Via coding; disable the comfort open sunroof and disable the sunroof button completely. This way the sunshade/liner cannot accidentally be moved back into the roof. I live in South Florida and have chosen this option as it’s generally too hot for the sunroof to be open.
The more expensive way requires removing the entire headliner (need two people for the job). The sunroof has to be disassembled and then there are some small plastic pieces that are broken inside the sunroof cassette. They have to be replaced for the non sliding sunshade panels.
The dealer charges a lot be cause they need to guys and have to disassemble/reassemble a large amount of the interior.
      09-05-2023, 12:01 PM   #30
cwickberg
32
Drives: X1 35i MSport Ultimate,
I just pulled fuse #25 to disable
      09-05-2023, 12:46 PM   #31
imBlasted
Haha well fine then, but I wouldn’t have gotten to play with ProTool
      09-05-2023, 03:25 PM   #32
cwickberg
32
Protool is a great app to code...I use it for my X1 and Z4
      02-04-2024, 07:01 PM   #33
ckennethcarlson
ckennethcarlson's Avatar
Drives: 2014 bmw x1 e84
[QUOTE=Rick Castro;29604228]sunshade ,i can help you if you still need help.contact me
I’m new here (opened an account today!) and the app won’t let me message you, Rick - but I’d love to get your advice on my sun shade issue. I need to earn the right to message users - so I’m going to start posting etc but maybe if you message me, I can reply to it?? I’d appreciate any advice at all on the topic. Thank you!
      02-12-2024, 04:25 PM   #34
silvrbreez
silvrbreez's Avatar
217
Drives: 335i
Same issue here with the slides not operating but the glass does. A local small euro service shop wouldn't touch it, and neither would a local upholstery and glass place with sunroof experience. Waiting for a quote from the dealer, but Fuse #25 is pulled for now to disable the switch.
2015 F30 335i | Glacier Silver Metallic ///M Sport | Journal
2014 E84 X1 sDrive28i
      03-15-2024, 11:50 AM   #35
tnoonan64
Drives: BMW X1
2016 bmw x1
I just picked this vehicle up last week.......one side of the black sunroof shade is sagging...is there a quick fix for this issue?
xbimmers
