TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > Bimmerlabs 330i Tune DIY Step by Step
      08-04-2020, 11:52 AM   #89
hassmaschine
Drives: "NBO" 330i
That sounds odd. Which "stock file" are you flashing? There's one that was an unmodified 330i file I was using for testing, I think I will remove that - but you should be able to start with the stock 330i file (downloaded as .bin), modify it and then upload it so you can get the batch flash. What happens if you flash the stock ZB#? My wife took the E90 on a road trip, so I can't test it myself right now.
KClemente104.50
      08-08-2020, 04:28 PM   #90
irish07
Drives: E90 LCI 328xi
Did you use something like tunerpro or built your own mappacks in winols?
      08-08-2020, 04:29 PM   #91
hassmaschine
Drives: "NBO" 330i
No, I don't use winols. Most of it is my own software, but I do sometimes use TunerPro because my own program isn't ready yet.
      08-15-2020, 06:40 PM   #92
E92William
Drives: 2008 E92 328xi
2008 BMW 328xi  [0.00]
Flashed 330i tune and swapped one of my 3 stage manifolds with refreshed disas in this forum member's e92 m sport. At first it ran weak while throwing codes for all 4 o2 sensors, we checked the connectors and all and the codes stayed then we reset adaptations and the codes went away for now it seems. The car still has a SES with no codes except for the 2fa3 which my car has too and shouldn't trigger the light. The car began to run way better after resetting and I hope it gets to how it should be after a bit of driving.
Is the service engine light on normal after resetting adaptations? Is resetting engine adaptations required for the car to run right after the tune/swap I didn't do it on mine and have had no issues.
      08-16-2020, 10:55 AM   #93
nsjames
Drives: 08 328xi Touring
I never saw a SES light after flashing mine.
installed manifold.
flashed it.
drove away without issue.
      08-16-2020, 01:19 PM   #94
E92William
Neither did I at all but I didn't reset anything. Reminds me of my N54 days when you'd have an SES and no codes. I think it'll go away though since the car is driving much better now without codes.
      08-16-2020, 05:30 PM   #95
sprp85
Drives: S54/N52
2006 E46 M3  [0.00]
2007 E91 328i  [0.00]
So in short, is this tune recommended for non 3SIM'd cars as well?
And DISA codes for no DISAs actually present will remain in the system until they are installed with 3SIMs?
      08-16-2020, 06:03 PM   #96
E92William
You'll get disa codes for them missing but nothing else. I had it on my car without the manifold for a while and it was noticeably better
ryanful51.00
      08-16-2020, 07:43 PM   #97
bluewater328
Drives: 2011 bluewater 328i LCI sedan
I wouldn't recommend doing it without the 3IM installed. So even with a adaptation reset you got a SES? And we didn't mean SAS, right? Cause SAS happens sometimes and you just reset it.
But more to point, after codes were cleared you still had the SES light?
      08-16-2020, 08:14 PM   #98
E92William
I had it without the 3 stage it ran very good of course I understand it's not ideal for what it's tuned for. The car has a service engine soon light after resetting adaptations but no codes in the DME at all except for the one you get with the 330i tune. The 4 o2 codes went away. The light wouldn't go away by clearing. I'll check with him in a few days and scan the car again
      08-16-2020, 10:49 PM   #99
ryanful
ryanful's Avatar
51
Drives: 16 X5,06 e91 325ix,03 Mini R50
I am running the 330i tune without the DISA manifold installed in my 2006 325xi. I have better power, faster revving sharper throttle response and significantly better torque And NO CEL or SES lights.
I will (hopefully) have the time to to install the manifold this week (need to inspect and test the DISA valves first, before pulling the single stage manifold)
      08-21-2020, 03:05 AM   #100
AlexKoast
AlexKoast's Avatar
92
Drives: e92 TiAg 335i 6MT
Just came across this thread and starting poking around on bimmerlabs website too. Thank you E92William for posting the video (i too would have shat a brick seeing those errors come up!) and hassmaschine for the website and support. Are there any tunes available for the 330i to delete out O2 sensors? I'm considering going catless in the next little bit since I'm reaching that mileage where they need to be replaced.
Current: e92 335i 6MT FBO + e90 330i 6MT | Former: e46 330ci 5MT | IG: @Axel.Koast
      08-21-2020, 08:58 PM   #101
bluewater328
Hey hassmaschine Did you do something new to MSV80 3IM ver 0.9.07? I got the new IAT installed and went to reflash the NoMAF version. Saw that there was a new version 0.9.07 (from my original 0.8.97) and when everything was done and I had cleared the mass trouble codes...I noticed I hadn't gotten the 2FA3 code. Not that it wasn't a big deal to clear once we knew how (or that it was a real problem to begin with), but interesting that it doesn't come up.
...or is that just some sort of personal site update marker and I just got a weird placebo effect :P
      08-22-2020, 12:09 PM   #102
KClemente
KClemente's Avatar
Drives: E90 335i
I've tried both stock files back when they were up for the 330. I used a bimmergeeks cable this time around and it's still the same unfortunately.
RSA Delete followed by stock flash (7623405) and it still results in a crank no start. I'm not the one to say anything about it but its similar to a checksum error.
For the tune file I created, I used WinOLS to find hex addresses for specific maps I want and port it over to tunerpro on an xdf I created. I normally work on MSD80/81 so it's pretty similar terminology.
If i use the vanilla winkfp without any batch flashes, I would have to flash the stock ZB# 2-3 times in order for the car to fire up. It must be flashed at least 2 times even though the first flash goes through without any error.
Note: I don't believe it's my tune file as the car still won't start up even with batch flashing the stock file.
Cars give me headaches.
      08-26-2020, 08:46 PM   #103
javeci01
Drives: 2007 328i
When I was trying to do the RSADelete, WinFPK crashed. Now my car will crank, but not start. Am I able to recover from this or did I just brick my car?
      08-27-2020, 11:00 AM   #104
nsjames
everything is recoverable.
post the error messages you sent me, but I responded in the PM with the instructions to import the datens into winkfp, which is what your errors are related to.
basically winkfp doesn't know how to talk to the module because the datens aren't installed correctly.
      08-27-2020, 11:44 AM   #105
Mantraxalos
78
Drives: 2006 330i Manual
2007 Z4 3.0i  [0.00]
2006 330I  [0.00]
I replied to your pm. I just flashed the stock dme with winkfp and it started again. I still have the 3.0i loaded on my Z4. I will soon try updating again to the 3.0si file as I want my full 255hp .
The only issue I'm still having with the zed is inpa doesn't display the zusb numbers for any modules in case it fails to flash.
      08-27-2020, 12:57 PM   #106
javeci01
Drives: 2007 328i
Thanks for the replies guys!
Below is the error message.
[C:\EC-APPS\NFS\BIN\MSV80.ctl] [19.08.2020, 21:47:31]
[MULTIFLASH]
MF_FG_NUMMER=
MF_PABD=12msv80.ipo
MF_PSGBD=12MSV80.prg
MF_SG_ADR=12
MF_NAAB_DATEI=
MF_PROGRAMM_DATEI=MSV80_RSADelete_0049QK0MI20S.0pa
MF_DATEN_DATEI=
MF_DIAGNOSEPROTOKOLL=
HW interface activted.
PABD set.
P-SGBD set.
INFO000=Error: Error 106: Error on setting ECU-Adress. Please check: Interface, PABD, P-SGBD
INFO001=Error: Error 2000: Error LFCDHDIA.CPP (12msv80.IPS/IPO) CDHapiResultText 1 Error in EDIABAS or in ECU description file (SGBD) SYS-0010: Initialization error 12MSV80
INFO002=Error: Error 2000: Error COAPI2.CPP coapiRunCabd 6 Error in EDIABAS or in ECU description file (SGBD) SET_ECU_ADDRESS
INFO003=Error: Error 2000: Error COAPIKF.CPPcoapiKfSetGlobalPabdSgbdEcuAddr 5 Error in EDIABAS or in ECU description file (SGBD) Run SET_ECU_ADDRESS Job
Error: ECU-Address could not be set!
ERG=Programming not ok. Fatal Error
Batch mode ended
Press any key to continue . . .
It sounds like I can flash the stock tune with WinFPK and the car should be ok? Are there any issues with this as the RSA Delete crashed while flashing?
I will try this out later today, just do not want to keep going down a further rabbit hole and creating more problems.
      08-27-2020, 01:21 PM   #107
bluewater328
[MULTIFLASH]
MF_FG_NUMMER=
MF_PABD=12msv80.ipo
MF_SG_ADR=12
MF_NAAB_DATEI=
MF_DATEN_DATEI=
PABD set.
P-SGBD set.
Batch mode ended
Did you see this?
      08-27-2020, 04:32 PM   #108
javeci01
Drives: 2007 328i
Thanks bluewater, will try this first.
      08-27-2020, 07:42 PM   #109
javeci01
Drives: 2007 328i
I imported the daten files to winfpk per the instructions provided by nsjames. It started to flash, got to 15% and then I got the following error message.
[MULTIFLASH]
MF_FG_NUMMER=
MF_PABD=12msv80.ipo
MF_SG_ADR=12
MF_NAAB_DATEI=
MF_DATEN_DATEI=
PABD set.
P-SGBD set.
ECU-Address set.
Data and/or program and/or NAAB file set.
Program will be programmed.
INFO000=Error: Error 211: Error on flash programming!
INFO001=Error: Error 2089: PABD 05MSV80 Programmieren 2544 switching programming mode failed 12MSV80, DIAGNOSE_MODE (ECUPM): ERROR_ECU_SECURITY_ACCESS_DENIED__SECURITY_ACCESS_ REQUESTED
INFO002=Error: Error 2084: PABD 05MSV80 FlashSchreiben 1448 Flash download failed 12MSV80, FLASH_SCHREIBEN (...): ERROR_ECU_INCORRECT_BYTE_COUNT_DURING_BLOCK_TRANSF ER
INFO003=Error: Error 2084: PABD 05MSV80 Programmieren 3247 Flash download failed 12MSV80, FLASH_SCHREIBEN (...)
INFO004=Error: Error 2084: Error COAPI2.CPP coapiRunCabd 6 Flash download failed SG_PROGRAMMIEREN
INFO005=Error: Error 2084: Error COAPIKF.CPP coapiKfProgSgDevelop 4 Flash download failed
Batch mode ended
Any ideas?
      08-27-2020, 08:12 PM   #110
bluewater328
[MULTIFLASH]
MF_FG_NUMMER=
MF_PABD=12msv80.ipo
MF_SG_ADR=12
MF_NAAB_DATEI=
MF_DATEN_DATEI=
PABD set.
P-SGBD set.
ECU-Address set.
Batch mode ended
Any ideas?
Am I reading into the wrong thing? You sure you have the right file? Maybe just leave this in the other thread.
EDIT: I see it worked out in the other thread. Glad to hear it.
