      09-08-2016, 03:40 PM   #1
hot-j
98
Drives: 1M
Better 1M clutch?
What are people using for a clutch upgrade on thier 1M's? I am running a stage 2+ ots cobb tune, and don't plan on adding more power. The car is a daily driver, so I don't want chatter but a stiff pedal is okay.
      09-08-2016, 04:20 PM   #2
CarJunkie
CarJunkie's Avatar
Drives: e82 1M, f87 M2cs
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
I just bought a BMW F10 550i clutch and pressure plate, should get installed in October. It holds more torque (550i has up to 500 ft-lb depending on trim level) and feels stock according to those who have used it.
      09-08-2016, 05:03 PM   #3
hot-j
98
Drives: 1M
I read about that one.... this one sounds similar
https://www.ecstuning.com/BMW-E82-1_M_Coupe-N54_3.0L/Drivetrain/Clutch/ES3103518/
      09-08-2016, 09:35 PM   #4
MightyMouseTech
MightyMouseTech's Avatar
4338
Drives: 13 135i 6MT LeMans Blue MSport
Wait, so the 550 clutch will work with the 1M flywheel?
      09-09-2016, 08:14 AM   #5
CarJunkie
CarJunkie's Avatar
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
Yup.
      09-09-2016, 09:33 AM   #6
MightyMouseTech
4338
Originally Posted by CarJunkie View Post
Yup.
Hmm, now to find out if the 1M flywheel will fit my N55 135i.
      09-09-2016, 11:19 AM   #7
CarJunkie
CarJunkie's Avatar
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
I don't think that is possible. There is another thread on that topic.
      09-09-2016, 12:52 PM   #8
hot-j
98
Drives: 1M
I am also considering single mass flywheel options. Anyone?
      09-10-2016, 06:27 PM   #9
phunky_monkey
57
Drives: VO 1M, Radical SR3
Think this might be a great option considering I've just fried my clutch! Is it this kit? 1M is not listed as compatible: https://www.ecstuning.com/BMW-E82-135i-N54_3.0L/Drivetrain/Clutch/ES1897635/
Thanks mate.
      09-12-2016, 02:59 PM   #10
Mrated
Drives: BMW 1M
2001 Mazda Miata  [0.00]
2011 BMW 1M  [0.00]
I installed the F10 M5 Clutch into mine (ECStuning.com - ES#: 1897635), put about 800 miles on it, and took it onto lime rock park for HPDE event, so far so good! I also installed the ECS Performance Clutch Fork Pivot Pin (ES#: 2992391). I am still using the original flywheel as the shop said it was okay to reuse. I inquired with the dealership about the install they wanted to charge me for a software upgrade, and the clutch replacement with parts and installation it would of cost me $2300 + tax. I also talked with local performance shops and decided to go with a local shop instead. Hope this info was helpful. Best of luck!
ayao643.00
      09-12-2016, 03:14 PM   #11
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
Don't. You will have all sorts of strange noises at idle. There is a reason why BMW went with a DMFW.
      09-12-2016, 04:39 PM   #12
phunky_monkey
57
Awesome, thanks mate!
I enquired with FCP Euro RE compatibility and they noted that the 550i clutch wasn't compatible and pointed me towards the 1M factory clutch. Great to know it does fit, I'll go ahead and order one.
Cheers
      09-13-2016, 12:52 PM   #13
Mrated
Drives: BMW 1M
2011 BMW 1M  [0.00]
Yea it's a very common change, and its a direct replacement, also a correction from before it is the 550 clutch, I am not sure why I said M5, but the part number I put is the one I installed. Shops that haven't done it before will be hesitant and won't want to misguide you, but shops that have done it before know its just a upgraded part. It was the main factor why I did not go with a dealership replacement, it was going to be more expensive and they would not use the 550i clutch.
Grey Dove124.50
      09-13-2016, 08:18 PM   #14
phunky_monkey
57
You're a superstar mate, thank you very much for your help.
I ended up ordering it today from FCP, along with bell housing bolts, bronze clutch fork pivot, release arm spring and a rear main seal just in case.
Pretty happy to have a factory solution without having to resort to a grabby twin plate or noisy single mass flywheel. Now fingers crossed my flywheel looks ok
      09-17-2016, 10:00 PM   #15
hot-j
98
Drives: 1M
I run a CAE shifter so I already have lots of noise at idle. I went with a clutch masters 350 with single mass AL flywheel. I'll let u guys know how it turns out.
      09-18-2016, 09:33 AM   #16
CarJunkie
CarJunkie's Avatar
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
Wow. I would love to know how launching and rev matching shifts works out.
      09-19-2016, 12:12 AM   #17
phunky_monkey
57
Yeah keep us updated, I'd be interested to see what you think
      09-19-2016, 11:58 PM   #18
hot-j
98
Drives: 1M
Oh, and I didn't say it but I have a CDV Delete too. And 034 motorsports 50 derometer engine mounts, ucc urethane trans mounts and delrin solid diff mounts. Oh and ucc clutch pedal.
      10-17-2016, 02:27 PM   #19
HP Autosport
Supreme Allied Commander
Drives: F80 M3
Clutch Master's clutch has been great with positive feedbacks.
      10-18-2016, 04:06 PM   #20
hot-j
98
Drives: 1M
http://www.1addicts.com/forums/showt...6#post20725076
      10-18-2016, 05:07 PM   #21
HP Autosport
Drives: F80 M3
Never had any issues with Clutch Master clutches. Did you tell them you them you have an E82 1M not a 135i?
      10-19-2016, 11:43 AM   #22
hot-j
98
Drives: 1M
Of course.
