      03-25-2019, 02:14 PM   #89
mexicobmw
Mexico
56
Drives: car
I am about to get this cluth kit , did you get it sorted?
regards
      03-25-2019, 03:22 PM   #90
diegorst
Peru
16
Drives: ‘11 BSM 1M | ‘14 Caterham 485S
regards
Yes! The clutch was finally installed last week. The problem before was that my flywheel had had been worked on before so the clutch didn't fit.
I ended up ordering a new OEM Dual-Mass Flywheel and after it arrived last week they installed it along with the new clutch and it was a perfect fit.
I picked up my car and was able to drive for a few kms home and the difference was amazing. Unfortunately I wasn't able to do a proper test drive because just when I got home I stubbed my foot and ended up with a broken toe and haven't been able to drive since then...it'll be one more week at least before I can drive again.
The good news is that the clutch fits!
Diego RdS - Lima, Perú
2011 /// 1M Coupe - BSM
      03-25-2019, 09:25 PM   #91
mexicobmw
Mexico
56
Drives: car
regards
Thanks for the reply! Sounds great I will order the clutch kit.
Regards
      05-19-2020, 03:37 PM   #92
christofis135i
Drives: 2011 135i White/Red
Maybe someone here can help me out. With the 550i clutch route with new DMFW and my mechanic says it doesn't fit. He said the clutch doesn't fit properly and is spaced towards the back of the car. The clutch disk does not make contact with the flywheel.
clutch: 21207603248
Flywheel: 21207640733
      05-20-2020, 09:28 AM   #93
CarJunkie
CarJunkie's Avatar
Drives: e82 1M, f87 M2cs
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
The clutch part number is correct, but its the wrong flywheel.
1M flywheel part number is 21-20-7-619-659
Maybe they ordered the 550i flywheel? The only 550i part you should use is the clutch itself, everything else is from the 1M. If your original DMFW isn't toast, you may be able to re-use it and complete install.
1M track toy mods: BMS chargepipe, BMS OCC, ADE FMIC, ADE motor mounts, MadDad/Lightweight Ti exhaust, ADE custom oil thermostat/cooler, custom MHD tune, F10 550i clutch, Ohlins R+T, Vorschlag camber plates, M3 'vert FSB with Turner endlinks, Stoptech Trophy BBK.
      05-20-2020, 09:31 AM   #94
CarJunkie
CarJunkie's Avatar
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
Here is a picture of invoice....this is everything I ordered for the job:
      11-07-2023, 08:05 AM   #95
dee0007
39
Drives: BMW 1M, BMW X5 G05
Do i need the screws for the fly wheel if im not changing the fly wheel? and why did you change the fly wheel how do you known you need to change it?
Also would you suggest i get a new slave cylinder ?
      11-07-2023, 06:19 PM   #96
PRTSB1M
Drives: AW3 1M
The flywheel surface wears along with the clutch. You may be able to resurface the flywheel, but after 10+ years and it being a 1M most owners replace instead of resurface. You'll at least want a new input shaft/pilot bearing (in the center of the flywheel) which will probably need to be pressed in, so you will need new bolts either way.
Yes, replace the slave cylinder while you're in there, and the pivot pin.
ayao643.00
