BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > 440i Stock Tune Feels Quicker than MPPSK Tune
proTUNING Freaks
      02-24-2022, 09:58 AM   #1
toniree93
Drives: 1999 M4
I have a 2019 440i Gran coupe with the Resonators removed, and axle back Remus exhaust installed. I DO NOT have the MPPSK Exhaust.
When I flash my car with the BM3 MPPK tune, the car feels more “sluggish”, less quicker, and the fuel throttle response sometimes gets “jumpy” - hard to explain but it’s as if I’m letting on/off the gas 10 times in a second.
The second I flash back to stock (non MPPK) the car feels amazing.
Does not having the MPPK exhaust cause the tune to not “fit” the car correctly?
      02-24-2022, 12:22 PM   #2
Skyhigh
Skyhigh's Avatar
1890
Drives: BMW F36
No. That's definitely not it.
First of all I notice you state "MPPK tune". I am not familiar with the BM3, but that's most likely a mistake, as the respective 40i product is called MPPSK.
What fuel are you using? 98RON is "recommended" with MPPSK. This said, it still doesn't explain your issue. MPPSK works just fine with 95RON, you just may not achieve the max available performance.
"Large increases in cost with questionable increases in performance can be tolerated only in cars and women."
      02-24-2022, 01:14 PM   #3
toniree93
Drives: 1999 M4
@Skyhigh I’m running California 91 Octane
      02-24-2022, 02:24 PM   #4
Samir72
Samir72's Avatar
433
Drives: 340i
The MPPK tune was only available for the F30 335i, so no doubt if running it on a 40i it will have issues
As you definitely notice the improvements from standard to MPPSK on a 40i
And is a full cat back exhaust system
      02-24-2022, 02:31 PM   #5
Red-i
80
Drives: 2018 340i
Bm3 says mppk actually. And it's an option for my b58 340.
      02-24-2022, 07:22 PM   #6
G.Newt
Drives: CT4-V Blackwing 6MT
You need to post a log.
2022 CT4-V Blackwing 6-speed
SOLD: 2016 340i xDrive 6-speed
DAW v2.5 turbo E40 | Dorch S2 | VRSF DP | MST intake | AWE catback | 335is clutch | CSF heat exchanger | RK Autowerks intake manifold | Orange M Perf Brake Kit | KW Street Comfort coilovers | GTS taillights V2
      02-25-2022, 10:03 AM   #7
toniree93
Drives: 1999 M4
Here is a log I took with above setup and BM3 MPPK tune: https://www.bootmod3.net/log?id=62183c4bc090c64249f9cf24
340i, 440i, bm3, bootmod3, mppk, mppsk
