      08-12-2012, 06:49 PM   #1
mozman
mozman's Avatar
Drives: E92 335i Coupé
Engine ticking noise
Hi
My previous car, a '07 335i, had this loud valve lifter ticking from the engine at idle. It didn't matter if the car was cold or warm, if I let it run at idle for a few moments it started ticking. BMW could never figure out what was wrong or if anything was wrong so I lived with it.
A couple of months ago I sold that car and got a 1M instead. Now this damn car is making the same noise...
So my question to you... Is anyone else experiencing the same noise? Is it normal? I know that some injector ticking is but this is much louder.
My current 1M.
My previous 335i. (Sorry about the VVS (Vertical Video Syndrome) :-))
      08-13-2012, 09:25 AM   #2
///M1
///M1's Avatar
Drives: Many
I had quite a bit of ticking on my '08 135i. Took it to the dealer, turns out there was a recall on certain cars that had fuel injectors off a bad/faulty batch. They replaced 4 of them (dealer based it on their serial numbers and determined if they were from said batch). Noise went away. No such issues on the 1///M.
2011 BMW E82 1///M: AW, all options; Renntech, Akrapovic, Forge, P3, RevoZ CF bits, many mods
1988 BMW E30 M3: Hennarot, S14, stock
2018 Porsche 991.2 GT3: PtS, CXX, LWBS, PCCB
1998 Porsche 993 C4S: Zenith Blue, last aircooled widebody, Bilstein PSS10, Fister II + Fabspeed exhaust
2008 Audi B7 RS 4: Sprint Blue, Audi Exclusive Euro Bucket Interior, Premium+Titanium, many mods
      08-13-2012, 12:24 PM   #3
Hobbe
Hobbe's Avatar
Sweden
Drives: AW E82 1M
Mine is ticking (weak sound) and so are my friends.
We decided that it´s normal
EDIT: I listened to yours, and yup that's the sound.
      08-13-2012, 12:38 PM   #4
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
Both the N54 and N55 engines will make a ticking noise. The sound IS normal. It is from the direct injection. The fuel injectors are under very high system pressure and make some noise, like a diesel does, sort of. IF you think it is bad just run the engine with the plastic valve cover off (like when changing spark plugs) - and you will be shocked by how loud our engines are.
For the 135i's BMW has come out with a SW update for people like you who complain about this injector noise. And it does work - but it also guts the performance of the car. adds lots of turbo "lag" and believe me you do not want that. Some have said that just last week BMW has a new "fix" for this added lag. Because once BMW updates your SW there is no back dating it to a previous SW version. So you are stuck with the latest SW on your car.
Most people who encounter this new SW update with the "lag" end up getting BMW to give them a free PPK or a half price deal. But there is no PPK for the 1M.
Maybe BMW will also offer this SW for the 1M in time. Who knows. But then you would need to buy a M2 to fix that SW update(lag).
      08-13-2012, 01:57 PM   #5
flzrider
Drives: AW 1M
Originally Posted by mozman View Post
Hi
My current 1M.
I think you and I may have the same noise.
I just uploaded a video I took the other night here:
Description: Video taken of my 1M's N54 motor after a 30 minute drive (fully warmed up, A/C off entire drive). I heard the noise as I pulled into the driveway, popped the hood, and pulled my phone out. The noise I am trying to track down is the one that disappears at the 5 second mark. This noise is much louder than the typical ticking noise of a direct injection motor. Right as the noise goes away the engine sounds like it is switching to/from something, similar to an A/C compressor switching on/off (again, A/C was off during this video).
In your 335 video, it appears that the sound goes away at the 38 second mark, correct? Are you just guessing that the noise is coming from the valve train? If so, what makes you think that?
Dackel, check out the video I just uploaded. I think there is a distinction between the usual direct injection noise and this particular noise. Let me know what you think.
      08-13-2012, 03:01 PM   #6
mozman
mozman's Avatar
Thanks for your replies.
Had my injectors replaced (or at least what my dealer told me...) on my 335 and it didn't solve the problem.
Sounds exactly what I'm experiencing.
Yes that is correct. The sound can last from minutes to just a few seconds. If I apply a little throttle it goes away for a few seconds and then comes back.
Just a guess and what I've been told by other people guessing...
The injector ticking is there and I know that is normal but this is x 10 louder.
I spoke to another dealer today and they also told me that this is normal but I have a hard time accepting that on a $70k car.
      08-13-2012, 03:31 PM   #7
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
....Dackel, check out the video I just uploaded. I think there is a distinction between the usual direct injection noise and this particular noise. Let me know what you think.
Ok, that noise in your video is not the injectors and it is NOT normal.
Why not play that video for your SA or shop foreman and see what they say?
G.L.
Dackel
      08-13-2012, 03:40 PM   #8
Das Ein
Das Ein's Avatar
Drives: '16 Audi TTS, '17 500 Abarth
I have that same ticking. Had it in my 135i as well. I notice it only when I go on a longer drive (highway driving). Then stop at a drive-through window, letting the car idle near a wall with the window down. Bliping the throttle makes it go away for a few seconds...then it comes back.
      08-17-2012, 09:46 AM   #9
Twinsturbo
Sweden
23
Drives: M2 Competiton AW MT
I heard this sound for the first time yesterday and i recorded it and sent it to My dealer. They then sent it further(BMW Sweden), they said that i should call the assistance asap if the sound did return and then they would have to tear it apart too search for the reason of the sound. But now i'm not sure that i want to let them do that.. But if this is their reaction maybe something IS wrong with our cars!? My guess is that it could be an injector that is creating the sound..
      08-17-2012, 05:05 PM   #10
mozman
mozman's Avatar
Can't you let them do that and let us know if they find the reason so I can visit your dealer?
Funny thats how BMW Sweden is reacting and the two dealers I've spoken to just says it's "normal".
Många svenskar här nu.
      08-17-2012, 05:56 PM   #11
flzrider
Drives: AW 1M
Upload the video to youtube so we can see/hear it.
      08-17-2012, 10:02 PM   #12
CarJunkie
CarJunkie's Avatar
Drives: e82 1M, f87 M2cs
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
My engine idle sounds exactly like the OP's, and has from day 1.
      05-04-2013, 09:31 AM   #13
chbc
Drives: BMW 128i 2011
2011 BMW 128i ticking sound from engine.
Is this ticking sound normal when engine is started in park? it seems to be an intermittent issue, sometimes (one day or another) it makes this noise. This was recorded after driving for about 30 miles, let it sit for about 10 minutes. The other time I heard this was when the car was parked overnight. Thanks.
      05-04-2013, 09:44 AM   #14
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
The noise in your video is with the engine OFF ? Its hard to tell bc of all the other background noise. IF so... its probably your electric water pump going bad. They should not make any noises like that.
I would have a dealer check for any waterpump failure codes. Normally you get a code thrown shortly before the pump dies. But you would never know bc you do not get any warning lights, until you are left stranded on the side of the road.
      05-04-2013, 09:46 AM   #15
chbc
The engine is on. If it's off I don't hear the noise. I'm taking it to the dealer today for diagnosis. Thanks!
      05-04-2013, 11:06 AM   #16
bdaddylo
bdaddylo's Avatar
Drives: 2017 F80 M3
Sounds like the valves are ticking. This is common on the S50 engine in the e36 M3. I autocross with several e36Ms and this ticking develops after their runs while idling. Usually, the owners just rev their engines for 10 to 20 seconds and it goes away. Maybe the top of the engine isn't getting enough oil?
_______________________
1991 E30 M3/Brilliantrot
2017 F80 M3/AW
      05-04-2013, 12:12 PM   #17
chbc
Thanks for the responses! I took it to the dealer today for a brief diagnosis, the technician thinks it's a gas tank pressure release valve that is making the noise. They say it's safe to drive. Since they are too busy today for to do further diagnosis, they rescheduled me out to close to 3 weeks out for a loaner vehicle, they'll do the fix then, and 30k mile service, plus battery cable recalls.
I'll report back in about 3 weeks.
Thanks!
-- Benjamin
      05-04-2013, 07:37 PM   #18
urbanstorm
Drives: 2011 BMW 1M
I have heard mine do this before as well.
Engine at operating temp.
Idling with HVAC/Seats/Radio off
A blip of the throttle, it will go away and come back.
You are not alone.
Robert
      05-10-2013, 12:22 AM   #19
G2G
Sold: E46 330CI, E90 320dA with 270000km
G2G's Avatar
Austria
9
Drives: 1M
2015 BMW 118d  [0.00]
2011 BMW 1M  [10.00]
Mine does the same from time to time!! I think its normal under certain conditions...
But for me it sounds very metallic so how could it be the direct-injector?!
      05-20-2013, 04:02 PM   #20
the_steff
Wales
Drives: 135i
Flzrider - my N54 135i makes the exact same noise and it starts and stops independent of engine revs, I'd be interested to find out what is causing it.
      05-24-2013, 03:36 PM   #21
chbc
Got the answer. They said it is the check valve or gas pressure release value that is making the noise. They say it's normal. I guess it's ok, since I don't hear it when I'm in the car.
      05-24-2013, 07:21 PM   #22
G2G
G2G's Avatar
Austria
9
Drives: 1M
2011 BMW 1M  [10.00]
good to hear! although I haven't heard it for at least the last 5000 km...now mine is on 30800 km!!!
