I cloned my MSV70 DME
09-18-2014, 02:14 PM | #23 |
Rep 7,215
poked around some more. Found the vanos maps (includes target angles as well as intake/exhaust spreads) and intake valve lift. Unsurprisingly, the VVL table is the largest at 20x20. max lift on the 330i is 9.7mm - anyone know the mechanical limits? the load axis is actually RF calculated from VANOS instead of the MAF. it's not easy to wrap your mind around.
might start with playing around with the rev limit. it has an "over rev" watch at 7200. I'm thinking that's as high as you'd want to push it safely. I want to play more with how the rev limit happens than the RPM itself. |
09-18-2014, 03:22 PM | #25 |
Freight Dawg
104
Rep 2,103
Wow! Hats off! I have a couple of questions. I want to put some issues to rest regarding the 325i and 330i. ECU-wise, what is the difference between the 2 programs? Even as of today, tuners can't achieve more than stock 330 power levels on a 325 with a tune and and 3-stage intake manifold. Speculation suggested that there was some variable(s) the engine tuning software could not accessed that "unlocked" the 330 maps. One forum member had a very brief appearance here and suggested that one of the variables was in the CAS module. What I'd love to do here is get a stock 330 engine map to work on a 325 with the 3 stage intake manifold.
--Marcelo
'06 Arctic Metallic 325i | Sport Package | 6MT | Dinan Stage III suspension | Dinan exhaust | 330i manifold swap! Click here! | Active Autowerke tune | 135i Brake Calipers | Deiselboost caliper brackets | E46 M3 front rotors |
09-18-2014, 04:50 PM | #28 |
Mike: Everyone's Pal
2044
Rep 2,972
Drives: F80 M3
if you made the lift to 9.9, what kind of improvements would you see?
Alpine MSS Stage 2+ E30 tune|MST Intakes|VRSF Single Mid Pipe|Agency Power Intercooler|VTT Full solution crank hub fix |
09-18-2014, 05:20 PM | #31 |
2044
Rep 2,972
Drives: F80 M3
09-18-2014, 05:22 PM | #32 | ||
Rep 7,215
the difficulty lies in the complexity of the tunes. There's a mind boggling number of variables, curves and maps, and exactly how they work together is unclear. I think what would be more feasible would be to flash the entire DME except for the secret key/vin/etc for the CAS with a dump from a 330i. The trick is going to be finding which sectors on the different memory chips have the relevant info. you could probably copy/paste all the variables from a 330i to a 325i but that would be tedious and risky due to the level of complexity. Also I'm pretty certain you can't flash a 328i DME with 330i code, because they are a different architecture entirely. But I do wonder if you could plug in a 330i DME into a 328i.. I'd have to study wiring diagrams. you'd still have to get it to play nicely with the CAS, but that's essentially the same issue as the 325. Good to know. It's easy enough to test! now I just need money/time to hit up the dyno and test things one at a time. Quote:
0.2mm of lift probably isn't going to make a huge difference in power though. 10.5mm or 11mm would probably see gains but that would require cams. It would be interesting to compare a dump from a 325i. if anyone has one, send it my way! |
09-18-2014, 05:40 PM | #33 |
Rep 9,004
09-18-2014, 05:42 PM | #34 |
Rep 9,004
09-18-2014, 05:45 PM | #35 |
Rep 9,004
I'd love to see what you can do and a true custom tune will make more than an off the shelf tune, but how much is the question. I'll be watching thia thread.
09-18-2014, 09:10 PM | #36 |
Rep 1,491
Where do you live..? I'm bringing my car to you for a tune lol
Black Wrapped Roof, BFG Rivals, Dinan Camber plates, M3 Steering wheel, Matte Black kidney Grills, H&R Sport springs,
Sparco assetto gara,Pagid sport Brakepads,STOPTECH Slotted Rotors, DISA STG3,EURO BOX |
09-19-2014, 10:23 AM | #38 |
Resident Tamed Racing Driver
298
Rep 4,697
Good project. Hopefully you have a donor engine or two in case something goes awry.
2005 E46 M3 Interlagos/Cinnamon with Sunroof Delete
09-19-2014, 11:19 AM | #39 |
Rep 7,215
I'm not going to blow my engine, lol, but thanks for the concern.
a member sent me a 325i dump, thanks! also, I looked in the 4kb eprom, the VIN is written in there (or at least the serial #). I'm thinking the secret key is as well. theoretically you could flash the CPU and external memory with an entire 330i file on the 325i and have the same tune. i'll need to test by taking the original donor ECU and flashing just my 4kb eprom, then see if it starts. |
09-19-2014, 11:42 AM | #40 |
Combined Applications Group
1061
Rep 680
I have a 323I 2.5L 08 N52K with a factory 3 stage
Please if you have a moment give me a step by step on how to copy the dump and I will send it to you. Where did you get the BDm header? I want to know how much BMW cripples the maps and valve depth from factory. Thx |
09-19-2014, 11:53 AM | #41 |
Rep 7,215
325i intake valve map:
330i intake valve map: low load is basically the same but part load and full load are completely different. at first I thought the 325i was more aggressive but now that I see it, it basically peaks out at about 80% load. I guess partly to make up for the lack of the 3 stage manifold? this is really just scratching the surface though. this will take months of effort to figure out, I don't even know what the effects of this map and many others truly are. I have to stop for today but I'll post more as I find it. oh yeah, the left axis is rf (relative filling) and the top axis is of course RPM. the units are in mm. |
sinner-15.50 |
09-19-2014, 11:57 AM | #42 | |
Rep 7,215
there are easier ways to download the stock tune over OBD but BDM is the only way to "clone" a dme including the ISN, and it's also much faster. |
09-19-2014, 12:05 PM | #43 |
1061
Rep 680
I see,
I am not really looking to clone it I just want to add valve depth, remove 6500 rpm limit and bump it to 7000 and remove top speed limiter. Thx Hass |
