TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > NA Engine (non-turbo) / Drivetrain / Exhaust Modifications > Converting N52 2 stage manifold into 3 stage.
      07-01-2022, 02:57 PM   #199
F31B48
F31B48's Avatar
278
Drives: BMW G21 E61 LCI
Originally Posted by dindf View Post
As mentioned in this post (https://www.e90post.com/forums/showthread.php?t=1011409)#1, I might use another car's VIN number (NK40006)
, I was thinking that ZB#7572903 should be used, because this VIN has special tuning of TCU (GKE211_A7572904_E90-E91_Teaser.0da 047G250P463Z) You can go to Bimmerlabs to see his explanation
(It enables the current gear display in Kombi, and by fixing the sport mode shift behavior)
I just flashed ZB 7572903 to my car now. Will see what it does when i drive it later.
Edit. After driving the car i can't say it's any different to what i already had. It doesn't display current gear in kombi, except in manual mode. It does have 7000rpm shift point.
dindf0.00
      07-30-2022, 07:32 AM   #200
Greger
Australia
Drives: BMW X5 BMW E92
nice thread. lots of information. I just installed Small Disa and now ready for RSA delete what Im chasing(used just 328 MSV80 vin to get my RSA delet files and 325i tune from user cheerio.
Have some idle problem after installing the DISA and had code 2d06 so will need to find this leak.
Dont feel much difference in power change but its all done and need to find vacuum leak and maybe it drives better.
      08-04-2022, 07:05 AM   #201
dindf
E90 323 /E92 335
dindf's Avatar
Taiwan
Drives: E90 323i 2006/E92 335i
Hi my friend: I sent you a message please take a look thank you
Thx Can help
      08-06-2022, 06:51 PM   #202
rjahl
rjahl's Avatar
996
Drives: Z4 35is
2012 Z4 35is  [0.00]
Are you still running the my ZF trans file?
      08-07-2022, 07:55 AM   #203
dindf
E90 323 /E92 335
dindf's Avatar
Taiwan
Hi: I have the trans file you gave me on my computer,and Do you still have the F31B48 (2006-E91-323i-325i) program you assisted before? If there is still an archive, can you give me a copy, I would like to study >< can you send it to me
Thx Can help
      08-07-2022, 09:29 AM   #204
dindf
E90 323 /E92 335
dindf's Avatar
Taiwan
Rubber Mountings
Just last weekend, I had 11 Rubber Mountings refurbished on my Rear axle, and they were all about to break down and were very loose, and these Rubber Mountings have been updated to drive better.(Attach OEM Number)
Thx Can help
      01-03-2023, 12:21 AM   #205
Faded Designs
Drives: BMW 323i E90 2010 M Sport
I am looking to flash my msv80 from the 323 tune to the 325 tune. The number on the physical label is 7609656. The engine is N52B25AE. The last 7 Digits of Vin are NM63719.
I'm okay with how to do the flash but have no clue how to find the correct file to upload or edit.
Thanks in advance.
      01-21-2023, 06:34 PM   #206
F31B48
F31B48's Avatar
278
Thanks in advance.
Read post #89, page 5 of this thread.
      03-17-2023, 07:26 AM   #207
mictang
22
Drives: E90 325i
Hi cheerio, Would you mind go into a little more detail on how were you able to resolve the 2FA3 code? Just a simple programming?
Oh and for anyone else is looking at this, I flashed a RSA delete on EU 325i (N52B30 engine swapped), and changed the powerclass byte to 2 on 328i to 330i map. Car runs good.
      03-28-2023, 08:50 PM   #208
SnowGlobe
19
Drives: Mazda MX-5
Yes, that works. I even had a project file named for this. My memory is really failing me. LOL
Attached is the Bimmerlabs ZIP file with the modified 325EU tune. Powerclass set to 0. This should run on an unlocked MSV70 controlling the 2.5 Liter N52 323 EU.
Reviving an older thread.
According to realoem it appears Canadian 323i's are equipped with both DISA adjusters from the factory. Maybe cold weather related.
https://www.realoem.com/bmw/enUS/sho...diagId=11_3756
I'm assuming I'd be safe to just flash the software for a pre-LCI European 325i, with the powerless you've modified here? This should give me the European pre-lci 325i tune, which is for the N52B25 with the 3 stage manifold ~ 215 hp
ECU version on Canadian cars is MSV70
      06-10-2023, 05:45 AM   #209
Trooper 888
Drives: BMW E92 323i coupe 2 Door
BMW E92 323i M spec 2007
Hi Guys...
I would love to update and convert my BMW 323i 2007 M Spec to 325. After a little research i found that the engine has a connector for the second disser flap on the left side of the manifold.
However i can not figure out where to get files to update the ecu or how to do it, I would appreciate any pointers i am from Australia QLD. Thanks
PS
I think i will need MSV70 DME device and the connecting cable i cant find any research please help THANKS
      07-06-2023, 03:57 AM   #210
NZE90
Drives: 325i
Originally Posted by Trooper 888 View Post
Hi Guys...
PS
      08-08-2023, 07:59 PM   #211
MAGORISKO
Drives: BMW E90 325I N52
Do you have someone melody for n52 325i with tri stage manifold? Thanks a lot 🙂
ornicar136.00
      09-28-2023, 06:11 PM   #212
NZE90
Drives: 325i
Just wanted to add some info to this thread. When flashing the N52B25 325i trans software, i found that this DIDN’T raise the max rpm to 7000rpm, it still stayed at 6500. To get the 7000rpm limit you need to flash with N52B30 trans software. I used ZB 7572901
      12-18-2023, 05:31 PM   #213
fespinoza831
Drives: e90, e46, e66
I tuned my 2008 328i MSV80 with a the 328 to 330 tune from BL. After the tune I get the 2FA4 error code, my CAS shows klasse_1 and my 6BMOT shows wert_00. I tried several guides that say you can edit those value but they all failed. Could this be solved by modifying the power class on the tune? If so how can I do this?
      02-01-2024, 08:21 AM   #214
Lehan
Drives: BMW E90 323i BMW F25 xdrive28i
What does the disa have to do with the tune?
Hey everyone I am new to this forum. I have a few questions I didn’t understand.
I understand I can tune my 323i to 325i but do I have to do the disa upgrade?
Also would a disa upgrade without a tune make any difference on my 323i?
Thanks!
      04-22-2024, 08:53 AM   #215
Lehan
Hi I used this with the bimmerlab rsa delete, also put on a 325i transmission flash, but my rev still seems to be limited at 6600
