BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Canada > Canada Classifieds Section > FS - E92 335is part out
      07-18-2014, 08:58 AM   #1
JJohner
JerryJ
JJohner's Avatar
Drives: 2007 335i E92
Hey i am parting out my salvage car i used for parts for my e92 07 335i.
It is a 2011 n54 e92 m-sport 335is, 57,xxx kms, black interior, and monaco blue in colour.
I have a load of parts i need to get rid of sooner than later; here is a list.
Rear bumper, taillights, exhaust, as well as the front bumper, hood, trunk, headlights, dashboard, interior trim, steering wheel, shifter, wheels, rims, rear view mirror, guages and sunroof are gone
All prices in canadian dollars.
n54 motor - includes pulleys (power steering needs to be replaced, no alternator, no oil filter housing assembley, still has hpfp, fuel injection system, ignition coils, intake box, intake manifold, throttle body, downpipes, turbos & piping, and the starter. Essentially the whole motor, and I'm asking 5500$.
Engine ECU - 300$
manual transmission - 6spd, 57,000 kms, very clean, oil was drained (still a clear bright red when i drained it). 1500$.
passenger front fender - no damage, 250$
Driver door - no damage, shell with window still in, no mirror. 400$
passenger door - one small scratch, " ". 400$
passenger seat - No damage, black leather, heated. 350$
rear seats - no damage, black leather. 350$
radiator fan - no damage, fan only. 120$
sun visors - no damage. 60$ for the pair
washer fluid tank - no damage, no tube, but includes cap. 100$
interior reading lights - Black plastic, no damage. 60$ front, 60$ rear.
light switch control - black, no damage. 100$
rear interior skins/Panels - black leather, no damage, no speakers. 150$ each.
passenger and driver door cards - Black leather, no damage, no speakers. 200$ each.
glove box - black, no damage. 200$
drive shaft - no damage, comes with centre bearing, in great shape. 100$
passender inner fender - no damage, has opening and trim for oil cooler. 75$
wiper motor - Works, no damage. 40$
front headrests - black leather, no damage. 100$ each
rear centre console - black, no damage. 120$
d/s trunk carpet cover - grey, no damage. 40$
Gas cap - 30$
petrol gas tank - 100$
rear package shelf - 100$
shifter foam insert - 50$
seat belt reel covers - 10$
rear upper seat belt (2 in stock) - 60$ each
front seat belt (2 in stock) - 60$ each
amplifier bracket - 10$
steering column bottom trim cover - 30$
rear lower seat belt strap x 2 - 30$ each
entrance covers - 10$ for both
window guides - 25$ each
tunnel heat insulator - 20$
compressor to condensor A/C line - 50$
switch unit steering column - 200$
shark fin & module inside - 100$
mirror glass - auto dim & heat. 220$ for both
oxygen sensors - 75$ each
fuse box junction - 100$
coolant reservoir - 40$
front sub frame - One weld broken, one leg slightly bent upwards, small fix for a frame shop. 200$
emergency brake cables - 80$ for both
steering column - column and linkage to rack. 120$
D/S knuckle/bearing hub - 100$
P/S knuckle/Bearing hub/struct/spring combo - all together. 300$
Oem door sill tread plate (2007 e92) - 80$
oem shift knob and boot (2007 e92) - 60$
i have lots of sensors available as well, i just don't know the names. if you send a pic i can match it up to see what i have available
email me at j.r.johner@gmail.com
      07-18-2014, 09:02 AM   #2
hunginator
hunginator's Avatar
154
Drives: 2012 BMW 135i E82 DCT
do you have the seat belt arm for the passenger side?
      07-18-2014, 10:10 AM   #3
JJohner
JerryJ
JJohner's Avatar
the seat belt butler ? the push arm that delivers the seat belt ?
      07-18-2014, 01:48 PM   #4
xcyx
9
Drives: 2007 328i
yes do you have the seatbelt puller and would it fit an 2007 e92 328i coupe? passenger and driver side
      07-18-2014, 02:23 PM   #5
JJohner
JerryJ
JJohner's Avatar
yup i still have them both, but i am not sure about compatibility with the year and model
      07-18-2014, 05:41 PM   #6
dakoo12
40
Drives: 2013 BMW 335xi F30 Sport
Whats ur gear shifter look like? mine is a little worn out
      07-18-2014, 07:19 PM   #7
Briancanadiano
Brian335tt
Briancanadiano's Avatar
98
Drives: BMW 335i premium package 19"ri
Do you have the exhaust system from the is?
      07-18-2014, 07:24 PM   #8
JJohner
JerryJ
JJohner's Avatar
the oem shifter is in good shape, not much wear and tear, no discolouration on the shifter
      07-18-2014, 07:25 PM   #9
JJohner
JerryJ
JJohner's Avatar
nope, its gone just like it said at the beginning of the thread
      07-18-2014, 08:29 PM   #10
hunginator
hunginator's Avatar
154
Hmm, I have an e92 2010 and I think the seat belt butler arm hasnt ever changed. Someone can correct me if I'm wrong.
      07-19-2014, 01:40 PM   #11
Dmc
Drives: E93
do you have the oil cooler assembly?
do you have the exhaust assembly with 1st and 2nd catalytic converters?
      07-19-2014, 07:27 PM   #12
JJohner
JerryJ
JJohner's Avatar
i only have the downpipes
      07-21-2014, 09:27 AM   #13
FrenchCanadianDude
Drives: 2012 335is, Audi SQ5, Bronco
Trim
Hi,
Do you have this back trim in stock? mine is scratch
      07-29-2014, 02:31 AM   #14
deeezy
Drives: E92 335i
Do you still have the front reading light unit???
      08-01-2014, 03:57 AM   #15
h.ma
Drives: G30 540I
do you have the tail lights?
      08-01-2014, 12:07 PM   #16
jokers_greg
Master of Montego Blue
jokers_greg's Avatar
28
Drives: 2007 BMW 335i
2007 335i  [0.00]
Might be looking at taking the engine/ecu/tranny, just gotta see from my mechanic if he'd be able to perform the swap. Do you also have the diff?
      08-01-2014, 07:16 PM   #17
JJohner
JerryJ
JJohner's Avatar
yea i still have the diff, but i might have it sold right away
      08-01-2014, 07:18 PM   #18
JJohner
JerryJ
JJohner's Avatar
read the thread
      08-01-2014, 09:32 PM   #19
FrenchCanadianDude
I did not received any anwser... Do you have the back trim??
      08-02-2014, 11:24 AM   #20
335i8-50
335i8-50's Avatar
9
Drives: M235xi
Do you by any chance happen to have a logic 7 amp available ? I didn't see anything mentioning it in the thread. Thanks !
335i Black Sapphire / Coral Red
Bastuck exhaust l Cobb AP Stg 1 l Aero lip l Gp Thunder l Painted Reflectors l Escort RedLine / LI Dual
      08-11-2014, 04:55 PM   #21
KamBMW335i
Engineering the World
Drives: 2008 Space Grey 335i
2008 335i  [8.00]
I would like the little retainer on the bottom of the seatbelt rail. It looks like a cylinder around the metal bracket.
This piece>
View post on imgur.com
      08-11-2014, 06:31 PM   #22
JJohner
JerryJ
JJohner's Avatar
no all the trim is gone already.
335, e92, e92 335is coupe, monaco blue, part out
