Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > New front/rear brake discs for 335i? Need help!
      01-10-2010, 08:03 AM   #1
whn
whn's Avatar
Finland
88
Drives: Range Rover Sport
Exclamation New front/rear brake discs for 335i? Need help!
I want to change my brake discs for something more "race" looking drilled & slotted discs.
What are the best discs available for 335i? and should I also change OEM brake pads for better ones?
btw. when I change the brake discs and pads to something non-oem will that make my brakes sound worse or will the sound be same?
MY12 Range Rover Sport Autobiography
Mods: Coming
E92 335i SOLD!
Mods: Stage 3+, FULLY LOADED
      01-10-2010, 10:07 AM   #2
TSM330i
2006 330i, TSM, Black, manual, sport
TSM330i's Avatar
Drives: '17 C2, GTI, Z4 3.0si Racecar
Do a search. There are quite a few threads on this topic.
2017 Porsche C2 - manual of course
2015 GTI S
2008 BMW Z4 3.0si Coupe - because racecar
      01-10-2010, 11:25 AM   #3
whn
whn's Avatar
Finland
88
Tried but didn't find anything helpful
Mods: Coming
E92 335i SOLD!
      01-11-2010, 09:12 AM   #4
AlanAZ
AlanAZ's Avatar
40
Drives: E90 325i sport manual
StopTech rotors (drilled and slotted) and Cool Carbon pads.
      01-11-2010, 09:28 AM   #5
enrita
enrita's Avatar
Sweden
161
Drives: 335i - Big turbos
+1000 i had those front and back and were good. you also get the inside of the rotor in black which looks nice compaired to the rusty oem ones.
07 335i AT - MOTIV 750 - MHD E85 BMS flash - BMS PI - JB4G5 - Okada Coils - NGK 5992 Plugs - Helix IC - Snow Stg. 3 - Stett CP - Custom midpipes with 100 HJS Cats - Bastuck Quad - PSS10 - QUAIFE LSD - BMS OCC - Forge DVs - AR OC - ALCON BBK - M3 Chassi - Dinan CP - Velocity M rear Toe arms - Advan RZ-DF - LUX H8 - Level 10 AT upgrade
      01-11-2010, 11:04 AM   #6
sworks335i
sworks335i's Avatar
Drives: 2015 F85 X5M
2010 BMW M3  [0.00]
Whats the best place to pick both those items up?
      01-11-2010, 11:30 AM   #7
stressdoc
Moderator
stressdoc's Avatar
Dominica
618
Drives: BMW i8; Toy 4runner TRD pro
I like the dba 5000 two-piece rotor, slotted. Drilled may look cool, but if freude am fahren is your motto, stick to slotted.
      01-11-2010, 12:31 PM   #8
Alpina_B3_Lux
Alpina_B3_Lux's Avatar
263
Drives: Audi R8 LMX, BMW M550i xDrive
2009 335i  [8.90]
I went with EBC brake discs (Turbo Groove, dimpled + slotted) along with Cool Carbon pads and Goodridge steel lines. I'm quite happy with it, more details in the link in my sig.
Alpina_B3_Lux
Audi R8 LMX, BMW M550i xDrive (G30 LCI); gone: Alpina B3 3,3 (E46), BMW 335i, Audi R8 V10 manual, Audi R8 V10, BMW M235i, BMW 550i F10
      01-11-2010, 01:00 PM   #9
AlanAZ
AlanAZ's Avatar
40
I got the Cool Carbon pads at Bavauto, and **********s carries the StopTech rotors at a good price.
Slotted rotors will be nosier than plane or just drilled. If non-oem pads are installed correctly, there's no squeal or additional noise.
      01-11-2010, 01:13 PM   #10
whn
whn's Avatar
Finland
88
So can you hear the braking noise inside the car now when you are using stoptech rotors w/ CC pads?
I want to change my rotors but I dont want to raise the braking noise when comparing to oem so should I first change the oem rotors to Stoptech drilled rotos?
Mods: Coming
E92 335i SOLD!
      01-11-2010, 02:26 PM   #11
SV Concepts II
SV Concepts II's Avatar
Drives: E90 M3
Location: 1460 White Oaks Rd. Suite F Campbell, CA 95008
If you find the stoptechs a bit too pricey. We carry the Frenetik premium line of replacement rotors which offer a your custom choice of cross drilling/slotted/dimpled and color finishes as well.
      01-11-2010, 04:20 PM   #12
Alpina_B3_Lux
263
2009 335i  [8.90]
I know the question wasn't addressed to me, but I think I can give you an answer nevertheless: As written above, slotted rotors will always be noisier than the OEM ones as the latter have a level surface. If you're not going fast, you can hear an increased braking noise as the pads build up friction against the rotor. It's not annoying or loud or anything, just noticeable. If you don't want any noise at all, stay stock.
BTW and just to avoid confusion, I'm not talking about any squealing or something similar. When the CC pads are installed correctly, there shouldn't be any such squealing at all. I have them on for some thousands of km now, and even in extreme cold (-15 degrees Celsius) there was no squeal.
Alpina_B3_Lux
      01-11-2010, 08:13 PM   #13
AlanAZ
AlanAZ's Avatar
40
The slots are more abrasive against the pads - helps keep the pad material fresh - but does contribute more brake noise. Honestly, you'll notice the difference when you make the change, but after a few thousand miles you won't notice it any more, but you'll not want to live with the way the brakes were before. Before the brakes are initally grabby, then not much until you lean on them. After the change, the brakes are beautifully linear, and seem to go on for ever with not that much effort. The factory brake feel is disappointing to me, and I upgraded the rotors and pads on both my E46 (Zimmerman drilled/Pagid street) and E90, and both times had excellent feel and braking.
Increased noise is a function of the slotted rotors, not the pads. If you want Quiet, than plain or just drilled rotors with Cool Carbon pads is the way to go.
      01-12-2010, 12:39 AM   #14
whn
whn's Avatar
Finland
88
where I can buy stoptech drilled rotors? I found only BBK's
Mods: Coming
E92 335i SOLD!
      01-12-2010, 09:03 AM   #15
TheMadDutchman
Drives: 2004 330i ZHP
Check with harold@hpautowerks. Ask him about Stoptech's new pad compound
      01-13-2010, 01:32 PM   #16
whn
whn's Avatar
Finland
88
zzz.. anyone?
Mods: Coming
E92 335i SOLD!
      01-15-2010, 03:29 PM   #17
AlanAZ
AlanAZ's Avatar
40
whn meet browser; browser whn
http://www.pzmotorsports.com/Store/P...55257&Make=BMW
This is the first I found, probably others at better prices.
      03-30-2012, 11:47 AM   #18
Likwid
Drives: 2007 M5
I know this is an old thread, but still pertinent. Is anyone still using the Stoptech rotors? How have they held up? Are they made in China like a lot of the aftermarket rotors? Any problems with warpage?
      04-02-2012, 12:59 PM   #19
Themythx
Themythx's Avatar
Drives: 2008 335i
Ive been researching the same thing lately and stop tech seems to be whatever one is saying. If i find anything different ill let you know but about 80% led that way, forum wise.
      04-02-2012, 04:01 PM   #20
SpartanGA
SpartanGA's Avatar
Drives: 2018 BMW M4 Comp F83
I have very good luck with R1concepts in 550. Not sure if they make rotors for e90
      07-11-2014, 08:11 AM   #21
CowboysTaylor21!
Drives: 2007 335i
2007 335i e90  [0.00]
I am using them currently. Just installed them 2 months ago. They work great and look great too. I didn't buy CC pads at first and went with some pads from ebay and they squeeeeled like shit. After switching to better pads i hear no noise and the stopping power i sclearly better than stock
335, brake discs e90 e92, brake upgrade
