ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > General BMW Z4 Forum
  TireRack
      01-27-2018, 11:56 AM   #1
XMetal
XMetal's Avatar
Drives: Anything
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
My oil analysis and rod bearings changed
I just had my bearings changed and wanted to share my findings with this great forum in order to provide additional data points on these finicky S54 engines. Attached is the accumulation of all the past Blackstone reports to date. The Blackstone oil analysis, works, for the most part if you want to keep an eye on bearing wear. Looking back, I should have done oil analysis way earlier than my first one at ~28K miles. My thought was that the engine shouldn’t have any issues with so few miles, especially on one of the final iterations of the S54 (mine was the last few hundreds S54 built). So, you can see my shocked face when I saw the lead reading on my first report at ~28K.
The car is mostly a weekend car with some commute to work (approx. 30-minute commute). Very few, if any, short trips. Always let the car get up to temp prior to seeing 4K+ rpm.
  • The first 2 reports you see is for Castrol TWS 10W60. Lead readings were extremely high for a low mileage car.
  • Then I switched to Redline 5W50 (at 2015) to see if the lower viscosity oil (plus different formulation) will help, which it didn’t.
  • Figuring that I will soon need to do bearings anyway, I decided to experiment with various additives to see if anything will help (I’m an engineer so I like experimentation and data collecting ). Since Redline 5W50 didn’t make a whole lot of difference, I went back to Castrol TWS Edge 10W60 (due to better availability in my neck of the woods) adding ZDDP to it – that is what you see on the 4th report (at 2016). No improvement with the added ZDDP either.
  • Next up is Castrol TWS Edge 10W60 with Liqui Moly MOS2 moly additives (at 2017). This shows a very slight improvement, but not enough to definitively say it did anything to help.
  • Final experiment is Castrol TWS Edge 10W60 with Liqui Moly Ceratec additives (most recent at 2018). This was the most surprise to me that any additives may actually help with bearing wear! However, with Lead dropping to a normal level now, either the Ceratec additives are doing an awesome job as advertised or that enough of the lead layer had already worn away that there is less of it left on the bearings to wear off to appear in the oil analysis? So, this is still inconclusive, at least in my case. I may use it again in the future if I ever see lead creeping again. So, this is very promising.
A couple of things that stood out to me regarding these oil analysis:
  1. My bearings are showing copper, so why didn’t the analysis show any increased level in copper since the initial 28K mile analysis? Blackstone didn’t seem to have an answer for this either.
  2. Lead readings had seen a slight decreasing trend. To most people, and even, from Blackstone’s comments, one would think the engine is doing better; but in reality, it’s actually not. I believed the main reason that lead is trending lower is because there are less lead to wear away on the bearings themselves.
This further emphasize that these analysis only work if you use it to look at their trends. Someone who has never done an oil analysis and suddenly decides to do one at, say, 100k miles to see a very low lead readings can get a false sense of security thinking everything is all well.
In any case, the decision had been made to have the bearings change out at ~55K miles due to a long streak of high lead readings no matter what the outcome was on the last report. The pictures speak for themselves. Definitely glad I had them replaced, but was very surprised to see their conditions for a well-loved and maintained (annual or ~5k mile oil changes) non-tracked car that is under 60K miles. I had decided to go with WPC simply because those had been around longer and not a single complain (that I know of) with them thus far. Lang Racing Development offered both WPC and BE Bearings for the same price - He doesn’t favor one over the other.
With the VANOS already updated with Beisan stuffs and now bearings, I’m hoping that it won’t need touching for another 100K other than valve adjustments and basic maintenance.
After all that, these reports raised another issue – rising sodium levels. I’m hoping sodium is part of the additives that I had been adding to the oil on the last 3 analysis – we’ll find out on the next report as I’m not running any additional additives on my current oil after the bearing change. I don’t think it’s antifreeze because I’m not losing any. I’m not sure why the report indicates a 0.23% antifreeze when Blackstone can’t conclude if the rise in sodium is caused by antifreeze due to the lack of potassium present? That 0.23% antifreeze is most likely “moisture” in the oil that they’re referring to since the sample was taken cold. Anyway - Any ideas what may cause a rise in sodium other than from antifreeze or oil additives?
Appreciate 4
Azeka1285.50
KevinM2935.50
      01-27-2018, 05:11 PM   #2
steffenme1
steffenme1's Avatar
103
Drives: 2007 Z4 MCoupe
Wow... great write up! Thanks so much for sharing.
Those bearings were looking awful rough, I'm sure it's worth a lot of peace of mind to have them replaced.
XMetal1143.50
      01-28-2018, 10:22 AM   #3
SaltyNC
SaltyNC's Avatar
370
Drives: 2006 BMW Z4M Roadster
Xmetal,
It sounds like we are following similar paths. I didn't try a different weight oil, but I did try Ceratec on my last oil change. In fact, it is in the car right now and will be changed within the next 100 miles. Our mileage is about the same. I suspect I will find the same bearing wear that you have.
Did Lang have any opinion on Ceratec? My thought is that I know I need the bearings replaced and will be doing it soon. Since the most common failure is spun bearings, I was hoping if there was metal on metal contact (which clearly there is), it would slip over the Ceratec coating and not have enough friction to spin the bearing.
Now that you have new bearings, will you continue to use Ceratec? Since the WPC bearings have the slicker surface and the BE bearings have the coated surface, I don't know that it is necessary or helpful, but I suppose Ceratec has other benefits other than the bearing shells.
I was reading Loctite's literature the other day, and they have a product called 648. It may be that the Loctite would add too much thickness, but I wonder if anyone has ever tried adding that to the underside of the bearing shell where it interfaces with the rod.
When I do my rod bearing swap, I'll post photos and results, as well.
Salty
2006 BMW Z4M Interlagos Blue/Black
Aux Port|LED Interior|LED Strip Trunk|Underseat First Aid Box|Stubby Antenna|Intravee II|BMW Oil Change Kit|Top Down Side Panels|Vibra Technics Engine Mounts|Rogue Trans Mounts|Engine Mount Bolts Upgrade|RS Windblocker|Euro Front Plate|M5 Illum Shift Knob|Supersprint Powerloop Exhaust|Gruppe-M Intake|RPI Scoop|Black Grills|19x8.5 ET35 F 19x9.5 ET22 R Sportline 8s PSS| Besian Vanos|CDV Delete
      01-28-2018, 10:24 AM   #4
SaltyNC
SaltyNC's Avatar
370
Oh, and did the bearings feel slicker that had been run with Ceratec?
Thanks!
Salty
      01-28-2018, 10:25 AM   #5
SaltyNC
SaltyNC's Avatar
370
Oh, and what bolts did you go with? Man, I'm full of questions...or something.
Salty
      01-28-2018, 11:31 AM   #6
XMetal
XMetal's Avatar
Drives: Anything
2018 Audi S3  [0.00]
2004 X5  [8.50]
Originally Posted by SaltyNC View Post
Xmetal,
Salty
Lang doesn’t have an opinion on Ceratec. All he said was that Liqui Moly is trying to sell that to him at the moment. He was skeptical (as was I) that any additives would do anything to help bearings wear.
I don’t have any additional additives in my current oil since I’m trying to isolate where the added sodium is coming from. I may use a Ceratec treatment in the future - they do advertised that it should last 30K or so. As long as wears are kept within check, I would like to stay away from any additional additives if possible because I don’t really want to mess around too much with the oil’s chemistry as originally intended by the manufacturer - Oil companies don't spend billions on R & D for nothing. My other reasoning was that if Ceratec was so effective as an anti-wear agent, why isn't it already in Liqui Moly's oil? Then again, may be Liqui Moly's oil already contain some Ceratec in it??? With that said, Lang did put Liqui Moly 10W60 in my engine after the bearing swap
Thanks!
Salty
The bearings feel normal like any components that have an oil film on it.
Salty
I went with the OE bolts per Lang’s suggestion. He didn’t try to push any other options
SaltyNC369.50
      01-28-2018, 12:22 PM   #7
kaybat
kaybat's Avatar
Drives: '06 Z4MR, '14 Cayman S
'06 Z4M  [0.00]
now i'm second guessing myself. I recently did blackstone test with ceratec(28k)and my results were perfect. wish i has tested before adding it...
Ken B.(BMWCCA/PCA/ZSCCA/SCCA)
      01-28-2018, 09:30 PM   #8
KevinM
KevinM's Avatar
2936
Drives: 2002 M5;2007 M Coupe;2020 M2C
2020 M2 Competition  [10.00]
2007 E86 M coupe  [8.38]
2002 E39 M5  [9.00]
Thanks for posting your experience. I'm at 30K and watching my lead levels...
2020 F87 M2C Hockenheim Silver/MT
2002 E39 M5 Sterling Gray/Caramel
2007 E86 Z4M Coupe Silver Gray/Black
2021 Kia Telluride (hauler)
XMetal1143.50
      01-29-2018, 10:57 AM   #9
Azeka1
Azeka1's Avatar
286
Drives: E86 M Coupe
Thanks for taking the time to post all of this excellent information! I am going to get mine done at 60K next month now, regardless of an oil analysis.
1995 E36 M3 | BMW CCA Club Racer - IP #34 | Gray / Blue / Orange | 261WHP | 2,700lbs
2013 E92 M3 Competition 6MT Slick Top | AW / Fox Red |
2006 E86 M Coupe | Silver Gray / Imola | JRZ RSTWO | APR Aero | Sparco Seats/Belts | Weichers Cage
Gone: 2017 Audi Q7 | 2011 E93 328i 6MT | 2014 Audi A6 | 2010 VW CC 2.0T | 2011 G37 S Coupe 6MT | 2004 G35 Coupe | SW20 MR2 Widebody Turbo
XMetal1143.50
      01-30-2018, 12:40 PM   #10
wss4
35
Drives: 2008 Z4 M Coupe
Great info! I had my bearings replaced around 50k miles and they looked very similar to yours, although I was driving the car at the track occasionally. I was always diligent about oil changes and engine warm up.
Interestingly enough, my car now has around 95k miles (but 75k miles on the replacement engine and 35k miles on the set of VAC coated bearings), and I am showing elevated copper with no increase in lead. I don't know the composition of the other engine bearings, but I imagine it is now either the camshaft, small end connecting rod, or main bearings that are wearing. This is assuming the VAC bearings are still lead over copper, just with an additional coating.
XMetal1143.50
      01-30-2018, 09:56 PM   #11
SaltyNC
SaltyNC's Avatar
370
Thanks for the info, Xmetal, and glad you didn't spin a bearing.
Salty
      01-31-2018, 12:11 AM   #12
XMetal
XMetal's Avatar
Drives: Anything
2018 Audi S3  [0.00]
2004 X5  [8.50]
I wouldn't worry too much if you had good results at just 28K. Just continue to be diligent with oil changes and analysis.
Please post your results if and when you decides to do your bearings. Any/All data points will help everyone
kaybat125.50
      02-20-2018, 04:17 PM   #13
Azeka1
Azeka1's Avatar
286
Drives: E86 M Coupe
Hi Everyone - Having my rod bearings done this week and my mechanic TYSpeed just sent me these pictures. I do not have a photo of all the bearings at the moment, but here are two of them. Maybe could have gone a little longer but better safe than sorry and will post better pictures of all bearings when I get the car back.
60K Miles and roughly 20 track days. Replacing with the WPC kit from ECS Tuning.
      02-20-2018, 09:51 PM   #14
XMetal
XMetal's Avatar
Drives: Anything
2018 Audi S3  [0.00]
2004 X5  [8.50]
Those actually look really good! Now let see the rest of them
      02-21-2018, 02:28 AM   #15
Finnegan
Dog Listener
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Wow. It's bearing season! Seems like we're all hit the ~50k mark and getting them done. I posted these on another thread but same use as your car and similar miles. Left is top, right bottom. Regardless of doing data collection or type of use I'm concluding this is a 40-60k (max) mile maintenance/insurance item.
      02-21-2018, 09:15 AM   #16
XMetal
XMetal's Avatar
Drives: Anything
2018 Audi S3  [0.00]
2004 X5  [8.50]
Finn,
Good call on the bearings. I'm very surprise to see how bad our bearings are compared to E46M3s with similar miles. Our engines are supposed to be the latest and greatest iterations, but data show otherwise. What bearings did you end up going with?
      02-21-2018, 07:46 PM   #17
Azeka1
Azeka1's Avatar
286
Drives: E86 M Coupe
Updated picture. Actually they did not look so good! Again, 60K miles and around 20 track days. Glad I saw your post and pulled the trigger.
XMetal1143.50
      02-21-2018, 10:16 PM   #18
Finnegan
Dog Listener
Finnegan's Avatar
Finn,
WPC treated. There's no definitive answer on those vs. BE and so many variables that it's rather moot IMO. The true fix is to regrind the crank and expand the journals. But if I recall the cost of that it's the equivalent of three bearing replacements.
Your point is well taken on ours vs. the E46. These are out of my Z3M (new acquisition) with 84k miles. (Did this and the subframe upon purchase.) Worn, but, there's 2x the miles of the Z4M bearings in the post above and 25 track days on these.
My developing theory is after the initial S54 bearing debacle sourcing of bearings and downstream processes were tightly controlled. (Clearly there are intrinsic design issues, but that wouldn't explain the model specific longevity differences.) That may have diminished with time and/or stocking levels of bearings, or with the plant doing the assembly. Was the S54 of the Z4M assembled in Georgia or Germany?
XMetal1143.50
      02-21-2018, 10:17 PM   #19
XMetal
XMetal's Avatar
Drives: Anything
2018 Audi S3  [0.00]
2004 X5  [8.50]
Wow those do look bad. Very happy to see another one being saved
      02-21-2018, 10:30 PM   #20
Finnegan
Dog Listener
Finnegan's Avatar
Yikes.
      02-21-2018, 11:06 PM   #21
Boosted 1
Where Does He Get Those Wonderful Toys?
Boosted 1's Avatar
Drives: 07 M coupe, Gx470, M2 PE
Finnegan My window sticker says
Country of origin engine and transmission: Germany
final assembly point Spartanburg SC, USA
      02-21-2018, 11:46 PM   #22
Finnegan
Dog Listener
Finnegan's Avatar
My window sticker says country of origin engine and transmission: Germany
final assembly point Spartanburg SC, USA[/QUOTE]
Thanks!
That eliminates a possibility. The diligence over time post crisis mode is still viable. Not provable. But typical in terms of human behavior.
zpost
