Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > 2007 BMW 328i Coupe lowered?
      03-24-2014, 06:46 PM   #1
CAB-Power
2007 BMW 328i Coupe
CAB-Power's Avatar
Drives: 2007 328i Coupe
2007 BMW 328i  [9.50]
I'm going to put 19' rims and I want to lower it but I never done it before with any of my previous cars so I have no idea of what to use and how much is going to cost me.
If anyone could post a before-after picture with part names and pricing or any other information that I could use to get mine done would be great!
Thanks.
      03-24-2014, 08:26 PM   #2
mbanks21
1268
Drives: 2015 335i MSport
Literally a thousand different choices. You can change out just the springs, or upgrade shocks and springs, or adjustable coilovers are the most common options. Springs start around $250, shocks and springs around $700-800, coilovers from $1000-2000+. What are you looking to get out of this?
      03-24-2014, 08:39 PM   #3
Riick
Drives: BMW
I daily drive in Florida. Flat roads, no curves. I wanted to keep the ride quality as close to stock as possible so I went with H&R sport springs. Drops a little over an inch. Just enough to look aggressive but not look like a teenager going through puberty.
Hard to install? No simple, but does require some special tools to take apart the ball joints on the front suspension. There's an install guide on the forum here but it's completely wrong. If you never spring swapped a car before I'd put BMW on the harder list of car's I've done due to the front end oddity of taking the struts out, better off paying a reputable shop or a buddy that's handy with cars. You can do the rear in minutes it's a piece of cake, 2 bolts.
      03-24-2014, 09:55 PM   #4
CAB-Power
2007 BMW 328i Coupe
CAB-Power's Avatar
Banks, I just want a little more aggressive look at a fair cost. I think Riick is right on the money there. That's exactly what I want to do. Something "simple" but that will look & perform good without taking it too far.
Thanks guys!
P.S. Your car looks awesome! ...are those 19'? what kinda tires ur using? and did you left the stock brakes, disks and calipers?
Sorry bout bombarding u with questions lol
      03-24-2014, 10:02 PM   #5
mbanks21
1268
Check out Bilstein or Koni sport shocks with H&R or Eibach springs. You'll lower about 1.2" front and 1" rear. Cost is around $7-800 not counting install. I did my own coilover install, it wasn't that bad. Start to finish is around 6-7 hours but that was with adjusting height numerous times to get it right. Here's mine with ST Coilovers, got them used for under $700
      03-24-2014, 10:07 PM   #6
CAB-Power
2007 BMW 328i Coupe
CAB-Power's Avatar
I'm thinking just doing the springs, seems a lot more reasonable in price or is the difference that much better with the shocks?
      03-24-2014, 10:15 PM   #7
mbanks21
1268
You can do springs only but keep in mind it might not ride too comfortably and it will wear the shocks out quicker. Lots of people do it though.
      03-25-2014, 08:05 AM   #8
Riick
Drives: BMW
19in rims. Stock brakes (for now, going BMW performance). Hankook Ventus V12 tires.
      03-25-2014, 08:14 AM   #9
Delta0311
Drives: 2011 BMW 335xi E92 2016 228xi
Mind as well do it right and get a shock/spring combo. Otherwise you will be replacing your struts and shocks a lot sooner than you would want to.
      03-25-2014, 08:58 AM   #10
CAB-Power
2007 BMW 328i Coupe
CAB-Power's Avatar
Good to know, I will look into it. I'll post some before/after pics when its done. It'll prolly be a while tho.
Thank you all for the quick responses! This forum is awesome!
      03-25-2014, 09:37 AM   #11
TheSt|G
Resident Tamed Racing Driver
TheSt|G's Avatar
Drives: 911, 130is, E39 M5, E36 M3
Definitely do both at the same time. The stock struts are not designed for that ride height and will wear out quickly. In the end, it will be more expensive as you will have to do effectively the same work twice.
Most of the performance upgrade is in the struts as well.
2005 E46 M3 Interlagos/Cinnamon with Sunroof Delete
      03-25-2014, 11:10 AM   #12
CAB-Power
2007 BMW 328i Coupe
CAB-Power's Avatar
Well then I guess that pretty much sums it all, thanks TheSt/G. (My wallet did not liked ur comm tho lol)
      03-25-2014, 11:56 AM   #13
TheSt|G
TheSt|G's Avatar
Your wallet will in the long term!
Koni is also having a serious sale at the moment. Check out THMotorsports(I think they are running the best prices). They are ~25% off normal pricing. Just snagged a set of Yellows for my fiance.
      03-25-2014, 12:19 PM   #14
CAB-Power
2007 BMW 328i Coupe
CAB-Power's Avatar
Will check them out, thanks for the tip!
      05-06-2014, 09:54 AM   #15
CAB-Power
2007 BMW 328i Coupe
CAB-Power's Avatar
What size tires are you running Riik? I'm about to put my 19's and haven't decided if I'll go with 225/35/19 or 235/35/19 also with V12 tires.
328i, coupe, lowered, modifications, price
