03-20-2009, 05:52 PM | #1 | |
29
Rep 35
[DIY E92 M3] High-Power White Angel-Eye Lamp
Hello, M3 Fighter Pilots!!
I made "High-Power LED White Angel-Eye" for my E92 M3 Coupe. So, I introduce it to you. This is a comparison between a genuine H8 halogen lamp and my work. This is the inside of genuine head-lamp unit. The "Inner Angel Ring" has a reflector, but the "Outer Angel Ring" has not. It has the "Optical Glass Pipe" which leads the ray from the light source. So, it becomes important that where is the position of the light source. This is "Luxeon K2 with TFFC Cool White" (LXK2-PWC4-0180) which I used. It has 250 Lumen at max current 1,500mA (3.85V). This is a genuine H8 halogen lamp made by OSRAM. Take it apart to the bulb and the base by milling machine. This is the base. It has two small pins in the inside. These are + and - from the H8 wiring. The aluminum bar (diameter 15mm) just fits to the base. Mill and plane the aluminum bar by milling machine. This milling machine has the precision of 0.02mm pitch. These are after milling and planing. Combine the materials. This is a comparison between a genuine H8 halogen lamp and my work. It has same distance between the filament and the base. (In this image, it looks different because of its putting angle, but it has just same distance(34mm).) It is only coupler-on to the H8 wiring, not needs cutting or other processing. This is a case when the light source is not adjusted to the "Optical Glass Pipe". It is often seen at several maker's products. This is my work adjusted to the "Optical Glass Pipe". More details, please see here. (Sorry, it is written in Japanese. Use Altavista or others.) Does anyone fight (compare) about the brightness of the Angel-Eye? Quote:
03-20-2009, 08:15 PM | #5 |
Rep 6,845
Drives: 2018 Audi RS5 coupe
so when can we buy these?
03-20-2009, 08:16 PM | #6 |
Rep 4,567
Hey, Soaristo. You're alive. I don't mean to hijack your thread, but this one demands your attention:
http://www.m3post.com/forums/showthread.php?t=226909 Drop by and give us a hand
'09 E92 M3: Space Gray, Black, Carbon Leather | ZTP 2MK ZPP 2MT 6FL | link 1 / link 2
Mods: M Performance exhaust | ZCP retrofit | Euro airbox | GTS DCT flash | JPN 240 ECU flash | Euro LCI taillights | CRT lip | OEM alarm retrofit | Space Gray bumper plugs | BMW Performance: Mk. II spoiler / Mk. II non-electronic steering wheel / mirror caps / front grilles / side gills / intake louvers / emblem |
03-20-2009, 08:19 PM | #7 |
Rep 6,845
03-20-2009, 08:28 PM | #8 | |
Rep 1,369
03-20-2009, 09:54 PM | #9 | |
29
Rep 35
Too much of one thing is not good.
Hello, kmarei.
The important thing is that where is the position of the light source and how to lead the ray to the "Outer Angel Ring" through the "Optical Glass Pipe". That product has a lot of SMD LEDs, but it seems that it has not enough amount of light.
03-20-2009, 10:04 PM | #10 | |
Critical Care Anesthesiologist
484
Rep 8,828
Drives: SMB F83
kev { divinum est sedate dolorem }
"your friendly neighborhood critical care anesthesiologist" |
03-21-2009, 01:44 AM | #11 | |
29
Rep 35
Hello, Kev.
This is under the sunlight in the shade. It has almost the same brightness as the genuine halogen lamp. (Under the direct sunlight, even though the genuine halogen lamp looks dark.)
03-21-2009, 06:01 AM | #13 |
484
Rep 8,828
Drives: SMB F83
Wow, sweet, that's really good.
03-21-2009, 08:00 AM | #14 |
Rep 6,845
i wonder if we can make a setup with 4 bulbs with say 3 inch wires
so you can pace a bulb at the tip of each ring so the outer ring would be lit up as well as the inner ring |
03-21-2009, 08:06 AM | #15 |
Rep 5,842
Drives: 2006 325xi
The only problem with this is.... when you turn the headlights on then the voltage drops and it is too low for the power regulator to handle, so it throws it out of its recomended voltage. Doing so it cuts down the power to the LED and makes it much dimmer. Have you tried to use this setup when the headlights are on also?
03-22-2009, 05:25 PM | #16 |
Rep 9
Here is other solution.
This way I did the LED angel-eye lighting in my MY09 M3. The LEDs are placed in correct position. But, it is a little difficult to install. http://www.brex.jp/jp/whitering92/ |
03-25-2009, 10:32 AM | #17 |
Rep 471
pictures of the brex unit installed please?
Become a BMW CCA member; please use member #405205 as a reference . Click here to join online
03-25-2009, 11:48 AM | #19 |
Rep 5,483
subscribed
Current:
2019 BMW X5 40i - Carbon Black/Tartufo Individual Leather 2020 Range Rover HSE - Black/Black 2020 Audi R8 V10 Performance Spyder 6MT - Ascari Blue/Black |
03-25-2009, 11:51 PM | #20 | |
135
Rep 1,825
04-18-2009, 03:46 PM | #22 |
Rep 3,152
That is great great work! WOW
Current Mods:
2004 E46 M3cs JB/CSL 2010 E70 X5M AW/BLACK 2011 VW Golf R DSG White/Black IG: @060Motorsports |
