02-24-2014, 10:19 PM | #5809 | |
General
10523
Rep 41,104
So, what you need to do then is as follows: Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on REM => Click on "Detect CAF for SWE" => Select CAFD cafd_000007a1.caf.005_033_001 => Select OK => Right-Click on REM (the ECU itself not the underlying CAFD) => Select CODE.
02-25-2014, 06:34 AM | #5810 | |
Rep 7
Another question : do you happen to have the pinout for the USB2 port on the NBT? I VO-coded 6NS, and I ordered cable 61119322445 (nr. 1 here), which I think runs between USB2 on the NBT and the base plate in the armrest. Instead of connecting to the base plate I'm going to try and solder on a female USB2-port so I will have 2 USB ports in my armrest, one for the iPod for music, and one for the iPhone for apps. Do you think that will work? |
02-25-2014, 06:45 AM | #5811 | |
Rep 83
Re split view, I don't know that I've ever used that, I'll look into it. Last edited by ardyer; 02-25-2014 at 06:47 AM.. Reason: grammar |
02-25-2014, 06:49 AM | #5812 | |
General
10523
Rep 41,104
02-25-2014, 02:01 PM | #5813 |
Rep 83
Okay just played the system and I don't think I have the split screen option. I followed the instructions in the manual and there was no option for it. Is that part of the navigation package? If so I don't have nav either.
02-25-2014, 03:30 PM | #5814 |
Rep 3
no connection
Hi guys...
I can't connect to my car any more. Thought my cable is broken, but I received another one today and I still have the same problem. When I connect it takes about 2 minutes until a connection seems to be established (network logo with exclamation mark appears right of the taskbar), but zgwsearch.exe doesn't find any connection and e-sys doesn't either. Any idea what the problem might be? Ben |
02-25-2014, 07:01 PM | #5815 |
General
10523
Rep 41,104
Yes. Without Navigation, there is no reason to split the screen. Regardless, I would expect RDS to remain on, and I am surprised yours isn't.
02-25-2014, 07:09 PM | #5816 | |
General
10523
Rep 41,104
PC Lan Adapter should get a fallback IP address of 169.254.xxx.xxx (Make sure it is using DHCP and does not have a Static IP address assigned to it) ZGW_Search does not matter. If you have 169.254.xxx.xxx IP Address, try and connect to the car.
02-25-2014, 07:58 PM | #5817 |
Rep 83
Thanks for the information, sounds like this requires further research. And there doesn't seem to be a coding fix.
02-26-2014, 06:14 AM | #5819 |
General
10523
Rep 41,104
You cant send or receive PM's yet. When you can, send me one with what you need.
02-26-2014, 08:18 AM | #5821 |
General
10523
Rep 41,104
After account is 24 hours old, you can use PM function.
02-26-2014, 08:27 AM | #5822 |
Rep 5
e-sys 3.23.4
ok..
just to let you know.. i have the psdzdata v51.3 files, about 28gb of it .. is that all i need after i get a compatible e-sys version or do i need any other files with it? may be the ediabas or something... sorry for my silly ques...i am just wondering if all ediabas files are same or is it version specific? |
02-26-2014, 08:40 AM | #5823 |
General
10523
Rep 41,104
You do not need EDIABAS at all. You need only E-Sys with working Token solution and PSdZData.
02-26-2014, 10:49 AM | #5825 | ||
Rep 7
If anyone's interested I can make a thread with some pictures, I now have the iPod classic connected to the armrest USB for my music library, and a lightning connector by the ashtray to connect my iPhone for music/apps. |
02-26-2014, 10:55 AM | #5826 |
Rep 5
e-sys 3.23.4 or higher
hi shawn
guess iam ok to receive pm's now.. would u be kind enough to pm me the link to e-sys and psdzdata files tht would work best to code f30 and f10.. thanks |
02-26-2014, 03:39 PM | #5827 |
Rep 1
Hi,
I've just ordered this cable: http://codecard.lt/electronics/tools.../prod_651.html Hopefully this will suit my 2013 330d, can someone PM me info on the correct software I need to start coding my car? Thanks for your help. |
02-26-2014, 05:08 PM | #5828 |
General
10523
Rep 41,104
PM sent.
02-26-2014, 05:08 PM | #5829 | |
General
10523
Rep 41,104
PM sent.
02-26-2014, 07:46 PM | #5830 |
General
10523
Rep 41,104
For those with CIC Head Unit's (PREMIUM Map), an early gift from BMW this year just landed:
Road Map North America PREMIUM 2014-2: Available now only in 3 x 8 Gb USB / DVD version, although a single 16 Gb USB can be made to work if need be.
