03-31-2021, 02:36 PM | #1 |
21
Rep 66
335i xDrive lowering springs?
Debating between going with the Eibach 05-22 kit (same as ACS?) or going with the RWD part number E10-20-031-02-22. I'm looking for about a 1 finger gap all the way around. Alternatively can go with the H&R Xdrive springs but those seem to drop more than the RWD Eibach.
Any issues running the RWD springs? Does anyone have any xDrive pictures with the 405Ms using the ACS springs or the Eibachs? |
03-31-2021, 10:25 PM | #3 |
Rep 417
From reading many posts: Eibach for Xdrive E10-20-031-06-22
Not a big drop but great driveability and not too stiff.
'16 M4 bone stock
'13 335ix Msport BM3 stage1 - MAD FMI - FTP CP - Bilstein B4 (SOLD) '85 635csi M30 turbo race car (SOLD) |
johnung4531.00 |
04-01-2021, 07:57 AM | #4 |
Rep 470
Hi OP
I dunno if you have non EDC suspension, if you don't, I suggest going for coilovers or struts/springs combo such as Koni/eibach for example. Springs only on non EDC suspension seems to lead to premature wear of the struts. I think it's important to see the bigger picture and not only chasing closing that ugly xdrive gap. hope it helps |
alohasurftoad3121.00 exE36M3489.50 |
04-02-2021, 08:29 PM | #5 |
Rep 26
I recently had Eibach xdrive springs installed with Bilstein B4 EDC and it raised the front end by 1/2in.
2013 335i xdrive (pwg): BMW MPE, BMS Chargepipe, BMS Wheel Spacers 10/12, BM3 tune, M performance Calipers, Qi wireless charger, Bilstein B4 EDC suspension, Eibach Pro Springs + F80 bumpstops, Zimmermann Formula F rotors, Active Autowerke FMIC
04-02-2021, 10:28 PM | #6 |
21
Rep 66
Ordering either the 05-22 or RWD eibach springs. I will measure and post results when I order and install the springs.
Here is a summary of the lowering spring drops, which might be useful for anyone looking to drop their f30 335i xDrive: H&R Sports xDrive: 1.6" F & 1.5" R Eibach E10-20-031-06-22: 0.8" F & 0.6" R Eibach E10-20-031-05-22: 1" F & 0.6 R (This part number lists 1" & .8" drop in the front depending on the website, rear springs are the same as the 06-22). I also believe these springs are the same as the xDrive ACS springs. Eibach RWD E10-20-031-02-22: 1.4" F & 1.6" R. Guessing the drop number is from the standard RWD suspension which is the same height as xDrive suspension. The springs seem to drop less than the H&R xDrive ones do in the front. Last edited by Kooner23; 04-02-2021 at 10:51 PM.. |
04-02-2021, 10:31 PM | #7 |
21
Rep 66
Do you happen to know the part number of the spring you used? FaRKle made a post of the Bilstein B6 & B8s raising the front in comparison to the OEM struts & shocks. However, don't think he said anything about the Bilstein B4s
04-03-2021, 06:05 AM | #8 | |
Rep 26
Purchased from Tire Rack a few months ago, best price at the time.
04-03-2021, 10:08 AM | #9 |
Rep 461
Confused...how does installing a lowering spring raise the car? And how just the front?
Eibachs are made to lower the front a bit more than the back. |
04-03-2021, 10:42 AM | #10 |
Rep 5,396
It's not the spring that is raising the car in the examples. It is the strut/shock being installed. Pressurized dampers can do that it regardless of the spring
04-03-2021, 10:51 AM | #11 | |
Rep 5,396
For those with BMW Adaptive suspension, the electronic front struts and rear shocks can handle lowering springs and don't get destroyed as easily as standard struts and shocks. You may need to swap out bump stops for shorter F8x bump stops. Bilstein makes replacement B4-Damptronics if stock BMW Adaptives begin to leak fluid. The upgrade model is their B6-Damptronic. It's heavier duty and contains more Bilstein technology. |
04-03-2021, 10:53 AM | #12 |
Rep 461
So the car will always be raised regardless of the damper installed? Or is this just a bilstein or just a edc damper phenomenon?
Is this a symptom of it being a "new" damper? It will settle down into stock position after a few miles? |
04-03-2021, 10:55 AM | #13 |
Rep 5,396
Reverse rake isn't caused by aftermarket springs. Reverse rake is built-in to the stock xDrive suspension by BMW. Eibach is the aftermarket spring manufacturer who tries to eliminate some reverse rake by dropping the front more than the rear in their spring sets.
04-03-2021, 11:00 AM | #14 | |
Rep 5,396
04-03-2021, 05:12 PM | #15 | |
Rep 26
johnung4531.00 |
04-04-2021, 03:47 PM | #16 |
Rep 461
04-04-2021, 05:08 PM | #17 | |
Rep 5,396
That's assuming that the shocks and springs are all installed and seated correctly |
04-05-2021, 03:40 PM | #18 |
99
Rep 98
Kooner23 ,
I also went through all the research and ended up with a set of 05-22... Couldn't be happier...just the right amount of drop. Gets rid of the xdrive gap and low enough enhances the look/performance, but not slammed. The eibachs also ride really nice for street driving. |
04-05-2021, 11:19 PM | #19 | |
Rep 1,029
Drives: 2019 440xi Gran Coupe
Who has these in stock? Eibach E10-20-031-06-22 |
04-05-2021, 11:51 PM | #20 |
99
Rep 98
04-06-2021, 01:49 AM | #21 |
21
Rep 66
04-06-2021, 01:54 AM | #22 | |
21
Rep 66
eibach, f30, h&r, springs |
