N54 Boost Follow Up
04-27-2024, 08:20 AM | #1 |
Rep 5
N54 Boost Follow Up
Hi everyone. This is a follow up for my last post regarding my 30FF issue. The 30FF was the result of the new non OEM boost solenoids so would recommend people avoid those. Buy right or buy twice... Now back with my original solenoids I'm faced again with the 30FE over boost at higher loads. Not sure if this is due to the solenoids or map related. Wastegates move free under vacuum. Could someone check this log as I'm new to this platform so still learning what a healthy log looks like. Do people think this over boost is a solenoid issue and I sure buy some OEM replacements or something else? Boost seems to be at 6.2 where the target is around 6 so doesn't seem to be over boosting by much at all. Also seen the throttle position looks strange if anyone can confirm this, maybe a bad sensor?. Thanks for the help
https://datazap.me/u/charlese9x/30fe?log=0&data=3-20 Last edited by charlese9x; 04-27-2024 at 08:29 AM.. |
04-27-2024, 09:15 AM | #2 |
648
Rep 2,015
Common mistake on the boost and boost target interpretation. The real boost made is a parameter called boost mean, which is measured by the tmap on charge pipe.
The boost indicated on the log is the result after the poor throttle tries its best to close and curb the boost mean down to its target. So sure it better be close to target. Hence in this case the throttle had to close down quite a bit to 21% and looks strange as remarked to meet the target. The actual boost mean is much higher, could be 8psi or more in this case (saying this because the throttle had to retreat so much) So is that overboosting enough? The throttle is the gate keeper.
335i e92 TPC 19Ts
04-27-2024, 10:07 AM | #3 | |
Rep 5
https://datazap.me/u/charlese9x/30fe...data=3-4-15-18 |
04-27-2024, 01:58 PM | #5 | |
125
Rep 261
Drives: 2007 335i Jb4 & perf. mods.
04-27-2024, 02:49 PM | #6 |
Rep 5
No I bought new solenoids that were supposedly direct replacements under the same part number but were not Pierburg. Learned my lesson doing this. Going to send them back and order 2 new Pierburg solenoids. You were right though the new solenoids did introduce a low boost issue so they were the weak link.
04-27-2024, 03:31 PM | #7 | |
125
Rep 261
04-29-2024, 06:33 AM | #8 |
Rep 5
