ZPOST
  TireRack
      05-14-2012, 12:47 PM   #67
Denton
Drives: '11.5 328xiT/6 - '99 M3/2/5
Originally Posted by v3.2mc View Post
you will struggle to get those to fit... the offsets are REALLY aggressive.
you'll also need centering rings.
I won't need the rings since they're E38.
This guy did 215/35 front and 225/40 rear. I don't like stretch but these are my favorite wheels under $3k so c'est la vie.
I'd like to find if I can do a wider tire, front or rear.
http://www.zpost.com/forums/showthre...light=%22style
      05-14-2012, 02:34 PM   #68
v3.2mc
Not a New Member
v3.2mc's Avatar
Drives: with both hands and both feet
2007 ///M Coupé  [10.00]
i thought the e34's, e38's, e39's, and e53's all had 74.1mm hub centers... is this not correct?
apologies if i'm wrong on this.
#1498E86 | Sepang Bronze | Dark Sepang Leather | Carbon Leather Trim
      05-14-2012, 04:10 PM   #69
3002 tii
3002 tii's Avatar
2288
Drives: Z4 M, X5, GX460
e39's don't have the same hub size.
Follow for latest mods
      05-14-2012, 04:23 PM   #70
v3.2mc
Not a New Member
v3.2mc's Avatar
so it's only the e39 5'ers that have the 74.1 hub center?
i must've been high when doing my last wheel research. sorry for the confusion, all.
      05-14-2012, 04:29 PM   #71
3002 tii
3002 tii's Avatar
2288
http://www.bimmerforums.co.uk/forum/...-offset-t7759/
1 Series E81/82/87/88 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 35-45
3 Series E21 = PCD 4x100, centre bore 57.0mm and M12x1.5 bolt thread. ET 12-20
3 Series E30 = PCD 4x100, centre bore 57.0mm and M12x1.5 bolt thread. ET 15-35
3 Series E30 M3 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 27-30
3 Series E36 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 30-47
3 Series E36 M3 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 35-47
3 Series E46 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 30-47
3 Series E46 M3 = PCD 5x120 centre bore 72.5mm and M12x1.5 bolt thread. Fronts ET 30-47, Rears ET 20-27,
3 Series E90/91/92/93 = PCD 5x120, Centre bore 72.5mm and M12x1.5 bolt thread. ET 30-45
3 Series E90/92/93 M3 = PCD 5x120, Centre bore 72.5mm and M12x1.5 bolt thread. ET 34-37
5 Series E28 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 18-25
5 Series E34 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 13-20
5 Series E34 M5 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
5 Series E39 = PCD 5x120, centre bore 74.0mm and M12x1.5 bolt thread. ET 15-25
5 Series E39 M5 = PCD 5x120, centre bore 72.5.0mm and M12x1.5 bolt thread. ET 15-25
5 Series E60/61 = PCD 5x120 centre bore 72.5mm and M12x1.5 bolt thread. ET 15-32
5 Series E60 M5 (Saloon) = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 12-32
5 Series E61 M5 (Touring) = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 12-32
6 Series E24 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
6 Series E63/64 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 14-20
6 Series E63/64 M6 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 12-20
7 Series E32 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 19-26
7 Series E38 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 13-25
7 Series E65/66/67/68 = PCD 5x120, centre bore 72.5mm and M14x1.5 bolt thread. ET 10-25
8 Series E31 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
X3 E83 = PCD 5x120, centre bore 72.5mm and M14x1.5 bolt thread. ET 40-45
X5 E53 = PCD 5x120, centre bore 72.5mm and M14x1.5 bolt thread. ET 40-45
X5 E70 = PCD 5x120, centre bore 74.0mm and M14x1.25 bolt thread. ET 37-53
X6 E71 = PCD 5x120, centre bore FRONT 74.0mm, centre bore REAR 72.5mm and M14x1.5 bolt thread.
Z1 E30Z = PCD 4x100, centre bore 57.0mm and M12x1.5 bolt thread.
Z3 E36 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 30-40
Z3 M Coupe/M Roadster = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
Z4 E85 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread. ET 45-52
Z8 E52 = PCD 5x120, centre bore 72.5mm and M12x1.5 bolt thread.
      05-14-2012, 04:33 PM   #72
v3.2mc
Not a New Member
v3.2mc's Avatar
jesus-tap-dancing-christ!
i'll pay better attention next time... promise!
      05-14-2012, 05:35 PM   #73
Denton
The reason so many aftermarket have 74.1 is to accomodate the stupid E39.
The wheels are NLA and we didn't realize it, so the Style 5s are off unless I find a used set. FML. Off to other ideas, still want a nice set of BBS.
      06-02-2012, 02:03 PM   #74
cruisingdog
Drives: Z4 2.5i Black
z4 2.5i Wheel Size
I'm looking at replacing my wheels once my rubber has gone! Does anyone know the specs for the standard factory Z4 2.5i 2005 wheels? I'm assuming they are 17" wheels but haven't found any info on them.
BTW, I'm looking at these as a replacement. Any good advice is welcome.
link
Thanks.
      06-02-2012, 11:00 PM   #75
3002 tii
3002 tii's Avatar
2288
link
Thanks.
tirerack.com
ps please no chrome...
      06-04-2012, 06:16 AM   #76
CloudyLP640
Drives: RS
Front wheels are 18x9 + 42 with a 245/40/18 tire.
Car has to be slammed on KW V3 coilovers.
Whats is the smallest spacers that will allow me to clear the coilover perch without poking too much in front.
Basically, I wanna run low, So I need the perfect compromise between clearing the perch and the fender...
No camber plates involved.
      06-04-2012, 08:57 AM   #77
3002 tii
3002 tii's Avatar
2288
5mm is usually a safe bet to clear the perch, but I think the problem is your tire choice. 245/40 is really tall compared to the stock 255/35 (about 0.6" taller) so you will most likely rub on the liner, especially w/o camber.
      06-06-2012, 06:28 AM   #78
Abelovic-Rösler
Abelovic-Rösler's Avatar
Ireland
Drives: Saphirschwarz E85
A question of fit.
I currently have Bridgestone Potenza RE-11s on the 18" Si wheels, staggered. I came across a set of Black Polish BBS CH-Rs yesterday and would like to continue to another set of RE-11s on those. Aside from the relatively short tyre life, they've been outstanding however, they're not available in the suggested tyre size for my car, given the new wheel sizes.
New wheels:
BBS CH-R BPO
19x8.5 ET 32
19x9.5 ET 35
BBS Suggested tyre sizes:
235/35/19
265/30/19
Q: Would it be alright to bump the rears to 275/30/19, to accept the Bridgestones? If not, I'll be mounting Michelin Pilot Super Sports, though losing my discounted pricing at Bridgestone. Is anyone else in use of 275s on the 19x9.5 rear with a similar offset? I don't want spacers or anything silly, I'd just like for it to fit, albeit properly.
      06-06-2012, 07:37 AM   #79
3002 tii
3002 tii's Avatar
2288
Originally Posted by Abelovic-Rösler View Post
A question of fit.
I currently have Bridgestone Potenza RE-11s on the 18" Si wheels, staggered. I came across a set of Black Polish BBS CH-Rs yesterday and would like to continue to another set of RE-11s on those. Aside from the relatively short tire life, they've been outstanding however, they're not available in the suggested tire size for my car, given the new wheel sizes.
New wheels:
BBS CH-R BPO
19x8.5 ET 32
19x9.5 ET 35
BBS Suggested wheel size:
235/35/19
265/30/19
No offense but you consider spacers to be "silly" but I would say so is running a 275 in this situation.
      06-07-2012, 09:30 AM   #80
Abelovic-Rösler
Ireland
Ugh. Not helpful...
The manufacturer's suggested tyre sizes yield a limited number of available fitments however, shifting to a 275 would increase the list of both possible and preferred options. THIS is why I'm asking. I already know 275s will fit on 9.5s, Mr. Dubs.
http://http://www.dupontregistry.com/AUTos/wheelzone/Wheel-Gallery-details.aspx?wzid=3269
The question was, "Would these tyres, being slightly wider, fit on our car, without the NEED for spacers and at the listed rear offset?"
I apologize if my wording distracted you. Given the opportunity, I know how eager some can be for to get a good zing on the boards.
Someone else???
      06-08-2012, 08:16 AM   #81
pokeybritches
pokeybritches's Avatar
Drives: ESS/G-Power Z4M, VF Z4, 996tt
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
http://www.1010tires.com/WheelOffsetCalculator.asp
You'll have 2mm more inner clearance, and the wheels will stick out 28mm more.
According to Tire Rack you'll be adding 0.7" of tread width and 0.6" of diameter going from a 255/35/18 rear tire to 275/30/19 tire. I would be concerned with the outside rubbing, but it may work.
Zpost isn't like prison where you have to beat up someone right when you show up . We're not like other boards.
VF Engineering Z4 3.0i, ESS Z4M, G-Power Z4M, 996 Turbo
      06-08-2012, 09:17 PM   #82
3002 tii
3002 tii's Avatar
2288
Ugh. Not helpful...
The manufacturer's suggested tire sizes yield a limited number of available fitments however, shifting to a 275 would increase the list of both possible and preferred options. THIS is why I'm asking. I already know 275s will fit on 9.5s, Mr. Dubs.
The question was, "Would these tires, being slightly wider, fit on our car, without the NEED for spacers and at the listed rear offset
Someone else???
A lot of tires will fit a 9.5 but that's not the point. A 275/30 not only sticks out as pokey described but it also runs 0.4" taller. Then you have the issue of the added weight and more understeer due to the excess width in the rear. Poor fitment combined with worse handling and slower take off in exchange to get the preferred tire model is where I was going with this. You're better off using proper sizes in a different tire because you really gain nothing by going with a 275 imo.
      06-09-2012, 07:00 AM   #83
Abelovic-Rösler
Ireland
I know; I just wanted them to work!
...but you're probably right, Mr. Dubs.
You'll notice we've sided with France so far as tyres...
Yyyup. BBS CH-R BPO Motorsports in Michelin Pilot Super Sport 265s.
We'll be posting pics whence we've all well and a mounted, then.
Truce in the forest?
«OMNIA RELINQT SERVAT REMPB»
      06-11-2012, 06:23 AM   #84
3002 tii
3002 tii's Avatar
2288
You'll notice we've sided with France so far as tires...
Truce! =D
Btw be careful with the fronts. I suspect you may rub with the 235, most likely will need camber.
      07-19-2012, 01:15 PM   #85
pmmjarrett
Retired Paratrooper
pmmjarrett's Avatar
Drives: 2006 BMW Z4 3.0i Sport
I've been playing with Autocad 2002 making some simple drawings looking into swapping staggered stock 17" 105s with 225/45 and 255/40 for staggered 18s with 245/40 and 275/35
Red lines are the outline of the tires
Magenta lines are the outline of the wheels
Yellow lines are just working lines I used to establish track width, which also allowed me to establish the approximate hub to hub dimensions using stock specs for track width and wheel ET. Also use them to visualize the differences in clearance between different tires and wheels.
Tire specs I used were Nitto Motivo
Wheel specs were for Voxx Maglia 18x8.5 ET40 and 18x9.5 ET40
Zip file contains my simple CAD drawings if someone wants to play with them. I'm not an engineer or draftsman. Just had enough schooling in Autocad almost 18 years ago to be dangerous LOL.
Z4 stggr tire and wheel drawings.zip
Front
Name:  Z4 voxx maglia front 18 stggr tires.jpg
Wheels are 0.023" closer to the inner fender and 0.523" closer to the outside of the fender.
Tire sidewall is 0.117" closer to the inner fender and 0.663" closer to the outside of the fender
Tire diameter is 0.75" larger which is 0.375" (3/8") larger from the center of the wheel.
Overall tire width increases 0.78"
Front track width increases 0.546"
Rear
Name:  Z4 voxx maglia 18 stggr rear tires.jpg
Wheels are 0.11" closer to the inner fender and 0.89" closer to the outside of the fender.
Tire sidewall is 0.17" FURTHER AWAY from the inner fender and 0.61" closer to the outside of the fender
Tire diameter is 0.59" larger which is 0.295" (just under 5/16") larger from the center of the wheel.
Overall tire width increases 0.44"
Rear track width increases 0.78"
I think this setup could work rather well without spacers. It's what I'm planning to try soon when I gather up a little more "Momma don't know" play money.
      07-19-2012, 01:39 PM   #86
3002 tii
3002 tii's Avatar
2288
^^ and I thought my Excel spreadsheet was a bit involved. Just keep in mind tires often run wider than advertised value.
      07-19-2012, 09:06 PM   #87
pmmjarrett
Retired Paratrooper
pmmjarrett's Avatar
Yep. Thank you. I like to look at pictures and not just numbers..... And I'm retired so I really have nothing better to do than play with CAD and math to keep the mind sharp. Prolly spend all day tomorrow tweaking the drawings since I'm waiting for parts for the lawnmower my wife broke today
I was looking for something that was fairly close to factory specs on the inside without huge differences on the outside that would allow me to shim it out a wee bit if needed for inside clearance or if wanted. I'd like to keep the alignment at factory specs and if needed I think my heat gun could take care of any minor rubbing and trying to avoid rolling the fenders.
I'm street use only with decent roads around me and generally a fairly conservative driver but occassionally like to drive a bit sporty on a twisty country road. Mostly I just love the look of a lot of meat tucked under the car. If I ever track it, it would be to run the Texas mile once just to see what she could do and mabey try an autocross someday.
      07-21-2012, 08:21 AM   #88
Denton
Terrible pic but ended up with 18x8.5 BBS RXIIs all around. Trying to remember the offset...will update when I check my records. Want to say 32ET.
245/40-18 Hankook Ventus V12 Evo tires. No rubbing...rears can stand to go another 10mm out with spacers, will do that soon.
zpost
