New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      06-18-2015, 10:11 AM   #67
ttuner
ttuner's Avatar
68
Drives: z4
2011 BMW Z4 35i | FBO | VTT Stg 2+ (EK, 20T clipped)| Motiv PI| Motiv Tuned | Fuel-IT Stg 2 + inline fuel pump | Spec Stg 3+ clutch | MFactory flywheel | 606whp 575Lbs |
      06-19-2015, 01:24 AM   #68
hiltonfa
hiltonfa's Avatar
South Africa
13
Drives: 2011 3.0 Sdrive
Originally Posted by ttuner View Post
Love the look great upgrade.
      07-03-2015, 05:12 AM   #69
pavproch
9
Drives: Z4 3.0i & 330ixT
Well, I know these are no OEM, but....
Yesterday got a Postal package from the U.S. of A..... Cquence slotted/dimpled zinc plated REAR rotors for e89 30i (300x20mm, a straight replacement for OEM rotors).... if not anything else, fronts and rears will be looking the same now....
Will post pics, once swapped...
Daily:330ix 6MT - PBX, HR SportSprings, Koni Yellows, OZ Ultraleggera 18", PI+PE, CDV off, UUC sways, M235i SportBrake (front), Cquence rotors (rear), 3.64 diffs, LSD rear
Funcar: Z4 3.0i 6MT - HR SportSprings +sways, OZ Ultraleggera 19", 5.00 diff by Drexler, CDV off, Quaife LSD, M235i SportBrake (front), Cquence rotors (rear)
      07-07-2015, 04:33 AM   #70
pavproch
9
Well, rear slotted/dimpled rotors Cquence went in .... PnP....(same size as OEM´s...
having the car jacked, I gave in 5mm front and 10mm rear spacers....
      09-04-2015, 12:47 PM   #71
jorgevelez1587
Drives: 2009 BMW Z4 sDrive 3.0i
Is this the kit that would fit the Z4 E89? Mine is a 3.0... Would it fit my car plug n play?
      09-12-2015, 01:18 PM   #72
CedarZ4
Drives: G05 M50i, Tesla M3P
Yes, that is the one.
For those who have done the swap... are you using the OEM M-Performance pad with the OEM E89 rear pads? How is the brake balance and bias? Mixing and matching pads is generally not the best thing to do
      09-29-2015, 04:36 PM   #73
CedarZ4
Bump - are the brake sensors that came with the F30 kit PnP for the E89 as well, or would we need to purchase the E89 specific ones and use it with the pads?
      02-26-2016, 08:10 PM   #74
jts1981
jts1981's Avatar
213
Drives: n54
Has anyone swapped the rear and eliminated the e brake? Just curious how they like it, if they miss the e brake?
GC LITES / BQ TUNE / MHD / FUEL IT BT ECA / WALBRO 525 LPFP / KW V3 / E9X M3 CONTROL ARMS / TURNER REAR CAMBER ARMS / RE BUSHINGS / H&R SWAYS / LUXON STRUTBAR / VRSF 7.5" FMIC / ER CP / TIAL BOV / VTT IN/OUTLETS / AFE PRO5R INTAKE / AR C.L. DP / BMS OCC / RB PVC / CF LIP + SIDE + SPOILER + DIFFUSER / IND REFLECTORS / BLK GRILLS / STUBBY / PB BBK / Forgestar F14 F: 19x9 et35 R: 19x10 et38/ Michelin PSS F: 245/35/19 R: 275/30/19
      02-27-2016, 08:47 AM   #75
pavproch
9
Originally Posted by pavproch View Post
Just got curious, will 18" rims go over these 340/30mm rotors+ M235i performance calipers? I think so, as the gap between the caliper and 19" rim seems to be quite wide, but...
Is there anyone to know?
(Well, I believe it is called laziness, I think.... It would take me to have both cars jacked and a wheel swapped between them to know the answer for sure - the other car of mine - 330ix - runs on 18".....)
      02-28-2016, 03:41 AM   #76
pavproch
9
As it seems no one knows, I had to do it.
18" rim fits, something like 3/8" gap (caliper-rim) left
      03-06-2016, 02:56 PM   #77
mrkoven
65
Drives: 2016 Z4 35i
^ are those fronts PnP for e89? do you know the p/n?
Mineral White FBO MHD Stage 2+
Focal & ARC Audio
      03-08-2016, 06:28 AM   #78
pavproch
9
yes, it is a straight PnP
I think I already listed all M253i sport barek package (S2NHA) components p/n somewhere
      03-08-2016, 06:30 AM   #79
pavproch
9
Yap! I did...
S2NHA sport brake package:
rotors 34106797602 (340x30mm, slotted/drilled)
caliper right 34116799466, 2pot blue incl. ///M badge
caliper left 34116799465, 2pot blue incl. ///M badge
pads 34116859066
      03-08-2016, 06:43 PM   #80
mrkoven
65
Drives: 2016 Z4 35i
thanks, it looks good
Focal & ARC Audio
      08-13-2016, 09:45 PM   #81
fmorelli
fmorelli's Avatar
Drives: Atacama Yellow 35i
This thread has beaten front brakes to death. What's the compatibility for the rear brakes, bolt-up wise (ignoring ebrake - assume no ebrake on the car)?
Since it is an E46 rear end, I'm wondering if the trailing arm brake mount points and such are all standard E46?
Filippo
2011 35i MT Atacama ... lots of bits. Full Öhlins TTX custom suspension. Build thread.
Build sheet. Currently finishing suspension, fuel, ignition system with Barry Battle @ 3DMMotorsport.
      08-18-2016, 02:52 PM   #82
jake169
29
Drives: 2011 35is
Just a heads up, getbmwparts now has the F30 BBK in yellow for only 1250$. So if anyone is interested and was waiting for the price to go down, like me, now u Know.
      08-18-2016, 03:31 PM   #83
fmorelli
fmorelli's Avatar
Husker is well under that price, which is where I bought mine.
And if you want to save even more, there is a guy on eBay selling a set dirt cheap, new and unused - kit looks complete and virginal:
http://www.ebay.com/itm/NEW-BMW-Brem...dXq7aL&vxp=mtr
Filippo
      08-18-2016, 04:24 PM   #84
jake169
29
Drives: 2011 35is
Filippo
Thanks for that info Filippo. The ones at getbmwparts is the F30 M BBK kit.
      08-18-2016, 09:54 PM   #85
fmorelli
fmorelli's Avatar
Good point ... if you are looking for the 4-pot setup in the front, this is a great price for this BMW part number. It also includes rear calipers (without rear rotors) ... and yellow at that price - the other colors tack on $600.
Curious if anyone knows if the rear calipers bolt up at all (aside from the emergency brake issue).
https://www.getbmwparts.com/partloca...gid=4462&tab=1
Filippo
      08-29-2016, 06:47 PM   #86
jake169
29
Drives: 2011 35is
Just got mine installed, love them!!!
      10-17-2016, 06:43 PM   #87
dwspen01
Drives: 2009 Z4 35i DCT
Is this the right brake kit that is PnP for the e89? Front and rear? Yellow is ~$600 cheaper than the other colors!
https://www.ecstuning.com/News/BMW_F...015/ES2771730/
2009 Z4 DCT - Hexon RR600, MMP Inlets/Outlets, Wagner EVO 2 Comp FMIC, Fuel-It TBI, Fuel-It Stage 2 LPFP, ER CP, Forge DVs, N20 TMAP, BQ Tune 93/E65, BMS DCI, AR Catless DPs, BMS OCC, RB PVC
      10-17-2016, 08:28 PM   #88
fmorelli
fmorelli's Avatar
For that setup, not quite ... you can only use the front brakes ... you want the front only set.
Filippo
zpost
