03-23-2016, 11:55 AM | #23 |
9
Rep 66
03-23-2016, 12:03 PM | #24 |
Rep 4,341
03-23-2016, 12:35 PM | #25 |
67
Rep 309
It was easy. It was way harder to install the charge pipe and air box.
2024 X3 M40i
2011 1M Coupe VO (Sold) 2015 MB GLK 250 Blutec Deez (Sold) 2001 S54 M Coupe (Sold) 1998 M3/4 (Sold) |
03-23-2016, 01:36 PM | #26 |
We've landed on the moon!
1449
Rep 906
Drives: 2011 1M (AW)
Yep, it was easy. Had to take down the cross brace and the pipe will come with a longer bolt to attach it's center support. Fitment was perfect.
03-24-2016, 06:14 PM | #27 |
1mGator
144
Rep 567
03-31-2016, 09:08 PM | #30 | |
Rep 2
Right is Right
Hi Guys, I got an email from Rich and he will be mailing me a cheque! Yes it took a while but he was very fair with a minimal restocking fee. I will continue to do business with Rich, I'll just have to be patient. In the end he is a good guy just very busy. As for the sound, not sure what others have found. I have catless 3 inch DPs going to a factory mid and the street axle back. This gives a very nice aggressive high pitch at higher rpm and growls at low. it doesn't drone but on the highway it can be pretty loud, what it sounds like other times is why i keep it. as for the mid pipes, I tried 2 setups. first was my catless DPs with mad dad mid and street. sound was cool but i got intense resonating at 2000 and 3100 rpm, it was unbearable and would get me pulled over in seconds. I then tried taking off the street axle back and putting on my factory axle back. It was quieter but still got the really bad resonating. So i put back my factory mid and the street, it was a wonderful combination, Loud and aggressive but no resonating and little to no drone. what have others noticed? are you running stock DPs? |
04-05-2016, 06:39 AM | #31 |
BMW for Life
138
Rep 210
Drives: 08 e93 M3 HT
Garage List 2015 Alfa 4C [9.00]
1998 BMW M3 Coupe [0.00] 2005 BMW Dinan Coop ... [0.00] 2008 BMW E93 M3 HT ... [0.00] 2011 BMW 1M [10.00] 1971 Alfa 1750 GTV [10.00] 2003 Porsche C4S [0.00] 2003 BMW Alpina Z8 [0.00] 1998 BMW M3 4 door [0.00] 2007 BMW Alpina B7 [0.00] 2002 BMW e46 M3 [0.00] |
Did it myself in 30 minutes. It is really very simple. I love the change of the sound.
04-18-2016, 05:13 PM | #33 |
144
Rep 99
Just got mine the other day from another forum member. Installed over the weekend. As others have stated, very easy to do. Make sure you have the replacement gaskets and nuts ready to go. The upper nut on the right pipe took a little creative tooling to get to when installing since the pipes are bigger. I had to put the socket on the nut, and then put an extension through the 2 pipes and connect. The socket was too big to fit between.
Other from that, make sure you have an external torx socket for the hanger bolt. Again, since the new pipes are wider, the stock bolt isn't long enough to put the hanger back on. I believe the Maddad should have a longer one, but if you didn't get one, you'll need a M8x1.25 60mm bolt. Super happy with the sound. I'm normally used to really loud exhaust, but I'm ok with this one. Much more aggressive than stock. You'll get a slight overrun, burble as well. Here's a DIY I found before for the N55/N54 pipe, but it doesn't really show the hanger location or the cross-member. http://www.1addicts.com/forums/showthread.php?t=797160 |
10-08-2017, 04:14 PM | #35 | |
Thread killer
646
Rep 1,896
But, in the spirit of followup, in the Republik of Kalifornia, a Maddad midpipe will technically fail visual. Don't ask me how I know... |
bodega_bladerunner155.50 |
10-12-2017, 10:58 PM | #38 | ||
10
Rep 287
Now, doing headers on e46 every 2 years in totally different in complexity and efforts, but man, that sound is transforming the car, thinking if I should just go for it... |
10-13-2017, 06:45 PM | #39 |
2619
Rep 2,819
Drives: e82 1M, f87 M2cs
Fortunately, living in Democratic People's Republic of California is voluntary.
1M track toy mods: BMS chargepipe, BMS OCC, ADE FMIC, ADE motor mounts, MadDad/Lightweight Ti exhaust, ADE custom oil thermostat/cooler, custom MHD tune, F10 550i clutch, Ohlins R+T, Vorschlag camber plates, M3 'vert FSB with Turner endlinks, Stoptech Trophy BBK.
01-20-2022, 08:47 PM | #42 |
Rep 9
I am in SoCal area (LA) and ended up with Berk midpipe and SuperSprint muffler. MadDad was not available and you need minimum 6 orders to be placed. Hence why I decided on the Berk Midpipe and am happy with it.
