      07-14-2021, 12:13 AM   #243
spxxx
Boost
spxxx's Avatar
1355
Drives: 135i M-Sport
Originally Posted by AndyW View Post
So, it looks like my DCT temps are too high now that I am pushing the car with the PS2 turbo. This is also causing coolant temps to go up. I noticed you added a hefty trans cooler. I presume you put in in series with the factory one? If so, before or after? I presume before so that it pre-cools before hitting the coolant?
It looks like there is room for a PS cooler sized cooler below the actual PS cooler so I am thinking of getting a junk one off ebay and trying to fit it up. Any advice appreciated.
I do run a trans cooler mounted right behind the right kidney grill, it's a Setrab 13 row AN8 I believe and there's plenty of room in there if you grind down the air ducts for the kidney grills.
F80 M3 TrackBoi, Z4MC GarageBoi, 1M Clone StreetBoi
AndyW673.50
      07-26-2022, 08:45 PM   #244
Raimund
Raimund's Avatar
204
Drives: 06 330i
Originally Posted by spxxx View Post
Yeah there aren't a lot of options for the sunroof delete. I would love a composite 1M front end to run 275 square tires My current 25lbs battery was $48 at Walmart haha I'll probably go with a Deka battery around 350cca as the car is still used for occasional weekend cruises.
Can you please share which battery you bought? 25lb is perfect
I don't check PM, DM me on Instagram @rai_n52
22RPD Vendor - 2006 330i - N54 Intake Manifold l N54 Throttle Body l Gruppe-M Intake l MILVS l 22RPD E85 Tune l S65 Injectors l HZ Racing Headers l TCKLINE SA Coilovers l M3 Front Arms l VWETISH Diff Brace l 3,91 Differential
      07-26-2022, 09:18 PM   #245
spxxx
Boost
spxxx's Avatar
1355
Antigravity H6 40ah... It's actually closer to 17lbs
I recently sold this car and built a pretty aggressive track E92 M3.
      07-27-2022, 01:26 PM   #246
Raimund
Raimund's Avatar
204
Drives: 06 330i
Sorry I meant the $48 walmart one haha
I'll have to check out the m3, congrats on the buy
      07-27-2022, 01:36 PM   #247
spxxx
Boost
spxxx's Avatar
1355
Haha ohh man that was forever ago... Those died pretty quickly if I recall correctly. I moved to the Deka AGM battery, purchased through eBay. Think it was 20lbs and ~$150 but lasted way longer.
Raimund204.00
